Home » Eclipse Projects » Buckminster » site.p2.zip action does not produce zipped site in Hudson
site.p2.zip action does not produce zipped site in Hudson [message #532288] Fri, 07 May 2010 19:14 Go to next message
Alex Kravets is currently offline Alex KravetsFriend
I've been building successfully my RCP with Buckminster and Hudson, but recently when executing site.p2.zip action on Hudson update site is not build. Product is build fine using create.product.zip though. Also, when I try to build locally in IDE update site is created.
Can anyone suggest what can be causing this?
thanks,
Alex
[Updated on: Fri, 07 May 2010 19:21]
Report message to a moderator
Re: site.p2.zip action does not produce zipped site in Hudson [message #532306 is a reply to message #532288] Fri, 07 May 2010 21:02 Go to previous message
Got it, problem was with buckminster.output value in my properties file, I was using same local path on my machine and server. Thus it was building locally and not on the server.
Previous Topic:Director-installed headless buckminster broken on OSX
Next Topic:finding out dependencies when building a product
Current Time: Sun May 27 16:04:53 GMT 2018
Powered by FUDForum. Page generated in 0.01798 seconds
