Home » Eclipse Projects » Eclipse 4 » XWT. TreeViewer with TreeColumn.
XWT. TreeViewer with TreeColumn. [message #526947] Tue, 13 April 2010 14:43 Go to next message
Konstantin Scheglov is currently offline Konstantin ScheglovFriend
Following code causes exception.
It seems that by some reason "headerVisible" is trying to apply to TreeColumn instead of Tree itself.
Same code, with replacement of word "Tree" with "Table" works without any problem.
<Shell xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt">
	<Shell.layout>
		<RowLayout/>
	</Shell.layout>
	<TreeViewer x:Style="BORDER">
		<TreeViewer.tree headerVisible="true" linesVisible="true">
			<TreeColumn text="New Column" width="100"/>
		</TreeViewer.tree>
	</TreeViewer>
</Shell>
java.lang.IllegalArgumentException: object is not an instance of declaring class
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty.setValue(BeanProperty.java:72)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1610)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(ResourceLoader.java:1388)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoader.java:1056)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1643)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:622)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:658)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement(ResourceLoader.java:363)
	at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core.java:606)
	at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:646)
	at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:633)
	at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java:835)
	at org.eclipse.e4.xwt.XWTLoader$1.run(XWTLoader.java:768)
	at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:762)
	at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:714)
	at org.eclipse.e4.xwt.XWT.open(XWT.java:416)
	at test.MyTest.main(MyTest.java:21)
Konstantin Scheglov,
Google, Inc.
[Updated on: Tue, 13 April 2010 15:06]
Report message to a moderator
Re: XWT. [message #527124 is a reply to message #526947] Wed, 14 April 2010 07:48 Go to previous message
Yves YANG is currently offline Yves YANGFriend
The tests on Tree is limited. Please fill a bug and we will take care of it
ASAP.
yves
"Konstantin Scheglov" <Konstantin.Scheglov@gmail.com> wrote in message
news:hq1vv2$1t8$1@build.eclipse.org...
> problem.
> <Shell.layout>
> <RowLayout/>
> </Shell.layout>
> </TreeViewer.tree>
> </TreeViewer>
> </Shell>
> class
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty .setValue(BeanProperty.java:72)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttrib ute(ResourceLoader.java:1610)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(Res ourceLoader.java:1388)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoad er.java:1056)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttrib ute(ResourceLoader.java:1643)
> at
> at
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:622)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:658)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement( ResourceLoader.java:363)
> at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core. java:606)
> at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java: 835)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> Instantiations, Inc.
Previous Topic:Default alignment of labels
Next Topic:XWT. Support for TableColumnLayout.
Current Time: Thu Jan 18 21:43:53 GMT 2018
Powered by FUDForum. Page generated in 0.01428 seconds
