Home » Modeling » OCL » How to count associative classes in a UML model
How to count associative classes in a UML model [message #518203] Wed, 03 March 2010 13:36 Go to next message
pkojo is currently offline pkojoFriend
I want to check whether model contains associative classes or not.
context Model
inv: allOwnedElements()->select(oclIsTypeOf(Class)->exists(c|c.ownedType = oclIsTypeOf(Association)))
please let me know, where I am making mistake.
Re: How to count associative classes in a UML model [message #518375 is a reply to message #518203] Wed, 03 March 2010 22:24 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
On 03/03/2010 13:36, Gilbert wrote:
> context Model
It is far from clear what you are asking.
Your title is "count", but your description and code are "check". May be
this is your mistake.
Or does the invariant malfunction in some way that you have not explained?
Ed Willink
Re: How to count associative classes in a UML model [message #518510 is a reply to message #518375] Thu, 04 March 2010 10:42 Go to previous messageGo to next message
sorry I want to count, want to know is this a correct way to count associative class.
context Model
inv: allOwnedElements()->select(oclIsTypeOf(Class)->exists(c|c.ownedType = oclIsTypeOf(Association))) ->size()
regards,
gil
Re: How to count associative classes in a UML model [message #518653 is a reply to message #518510] Thu, 04 March 2010 17:00 Go to previous message
Hi Gil
It's still not clear what you want or what is failing.
However:
An invariant is a statement/expression that is always true of its
context, it is therefore a boolean.
....->size()
is not boolean
....->isEmpty()
or
....->size() = 0
is.
Try expressing your intent in semi-formal English.
"It is invariably true that the model does not contain any classes that
are association classes."
Then you may understand the problem you are trying to solve and may then
be able to transliterate it into OCL.
Ed Willink
> associative class.
> context Model
> regards,
> gil
Previous Topic:Single OCL constraint for multiple properties
Next Topic:validate the dynamic instances of my ecore metamodel with OCL
Current Time: Sun Feb 25 14:18:56 GMT 2018
Powered by FUDForum. Page generated in 0.02419 seconds
