MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #52301] |
Fri, 03 September 2004 19:04 |
Originally posted by: robinnt.us.ibm.com
I have created an XSDSchema and am trying to add a global element
(XSDElementDeclaration) to it when the MissingResourceException is thrown as
shown. I can see that the plug-in org.eclipse.xsd has a plugin.properties
file in the eclipse\plugins\org.eclipse.xsd_2.0.1 directory. I am using the
xsd-SDK-M200407211027 build.
java code throwing the exception:
schema.getContents().add(anElement);
java.util.MissingResourceException: Missing properties:
at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 17)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:687)
at org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2020)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1465)
org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching (XSDSchemaImpl.j
ava:1448)
at org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1747)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentIm
pl.java:1122)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(Notificati
onChainImpl.java:113)
onChainImpl.java:101)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingList
Impl.java:288)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 84)
Has anyone seen this problem and know what is wrong?
Thanks.
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #52328 is a reply to message #52301] |
Fri, 03 September 2004 21:02 |
The problem turned out to be that the xsd.resources.jar file was not in the
classpath. After adding it to the classpath the error was gone. Should the
xsd.resources.jar have been listed in the plugin.xml file?
"Robin Noble-Thomas" <robinnt@us.ibm.com> wrote in message
news:chaeva$aqt$1@eclipse.org...
as
the
> at
> at
> at
> ava:1448)
> at
> at
> pl.java:1122)
> at
> at
> at
> Impl.java:288)
> Thanks.
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #52406 is a reply to message #52328] |
Sat, 04 September 2004 12:43 |
--------------010809000009010709080408
Content-Type: text/plain; charset=us-ascii; format=flowed
Robin,
The xsd.resources.jar is needed only for standalone execution so it
shouldn't be in the plugin.xml.
>>Hi,
>as
>the
>>at
>>at
>>at
>>ava:1448)
>>at
>>at
>>pl.java:1122)
>>at
>>at
>>at
>>Impl.java:288)
>>Thanks.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Robin,<br>
<br>
shouldn't be in the plugin.xml.<br>
<br>
<br>
Robin Noble-Thomas wrote:<br>
<blockquote cite="midchaltq$l4t$1@eclipse.org" type="cite">
<pre wrap="">The problem turned out to be that the xsd.resources.jar file was not in the
"Robin Noble-Thomas" <a class="moz-txt-link-rfc2396E" href="mailto:robinnt@us.ibm.com"><robinnt@us.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:chaeva$aqt$1@eclipse.org">news:chaeva$aqt$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->as
</pre>
<pre wrap="">shown. I can see that the plug-in org.eclipse.xsd has a plugin.properties
</pre>
</blockquote>
<pre wrap=""><!---->the
</pre>
<pre wrap="">xsd-SDK-M200407211027 build.
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:687)
</pre>
<pre wrap="">at
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2020)
</pre>
<pre wrap="">at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1465)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching (XSDSchemaImpl.j
</pre>
<pre wrap="">ava:1448)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1747)
</pre>
<pre wrap="">at
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentIm
</pre>
<pre wrap="">pl.java:1122)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(Notificati
</pre>
<pre wrap="">onChainImpl.java:113)
</pre>
</blockquote>
</pre>
<pre wrap="">onChainImpl.java:101)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingList
</pre>
<pre wrap="">Impl.java:288)
Thanks.
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010809000009010709080408--
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #591335 is a reply to message #52301] |
as
the
> at
> at
> at
> ava:1448)
> at
> at
> pl.java:1122)
> at
> at
> at
> Impl.java:288)
> Thanks.
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #591372 is a reply to message #52328] |
Ed Merks Messages: 33140 Registered: July 2009 |
Robin,
>>Hi,
>as
>the
>>at
>>at
>>at
>>ava:1448)
>>at
>>at
>>pl.java:1122)
>>at
>>at
>>at
>>Impl.java:288)
>>Thanks.
<html>
<head>
<title></title>
</head>
Robin,<br>
<br>
<br>
<br>
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
<pre wrap="">at
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
<pre wrap="">at
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
Thanks.
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.03366 seconds
