Home » Eclipse Projects » Eclipse 4 » Unable to get SWT Flex examples (want to port GEF app to web)(CVS error: java.io.IOException: proxy error: Forbidde)
icon5.gif  Unable to get SWT Flex examples (want to port GEF app to web) [message #517224] Fri, 26 February 2010 16:01 Go to next message
Ken Fasano is currently offline Ken FasanoFriend
I'm running
e4 Compatibility Platform 0.9.0.I20091120-1200
with
Eclipse e4 ActionScript Developer Tools (Incubation) 0.9.0.v20090609-1530-47L-9oB55W5I5O28OE5
on
Windows XP
following the instructions on how to set up the SWT port for Flex:
http://www.eclipse.org/e4/development/readme/readme_e4_0.9.h tml#R-Demos-Flex
4.2.3 SWT Flex examples
I have gotten to the step "Get the demos", but am unable to
access the CSV server. I get the following error:
Could not connect to :Pserver:anonymous@dev.eclipse: I/O exception occurred: ProxyHTTP: java.io.IOException: proxy error: Forbidden
I get the same error if I select "Generate E4 sample project" from the E4 menu item.
Besides Flex, what other options are there for porting a SWT/GEF desktop to the web (e.g. Dojo, Silverlight), and where can I get instructions on how to set these up in E4?
Also, are the ActionScript Developer Tools available in 1.0M3? When I try to install software from the online p2 repo link in 0.9, I get the SWT>Action Script installation, but not on 1.0M3.
Thanks!
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517483 is a reply to message #517224] Sun, 28 February 2010 16:08 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Ken Fasano wrote:
> I'm running e4 Compatibility Platform 0.9.0.I20091120-1200
The last version that flex was known to work with was the 0.9 release,
which would be around the v20090630-1500 to v20090729-1930 timeframe ...
I'm not sure how compatibly a November build (I20091120-1200) would be
with them.
> with
> on
> Windows XP
> Could not connect to :Pserver:mailto:anonymous@dev.eclipse: I/O
":Pserver:mailto:anonymous@dev.eclipse:..." would be totally invalid.
Is that just an artifact of pasting the error message into your post?
The ActionScript tools are in 0.9, but not in the 1.0 stream. See
http://dev.eclipse.org/mhonarc/lists/e4-dev/msg02180.html
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517534 is a reply to message #517483] Mon, 01 March 2010 08:32 Go to previous messageGo to next message
Originally posted by: qualle2008.gmail.com
A so interesting project is dead. That is why I came to e4.
> with them.
>> with
>> 0.9.0.v20090609-1530-47L-9oB55W5I5O28OE5 on
>> Windows XP
>> Forbidden
> ":Pserver:mailto:anonymous@dev.eclipse:..." would be totally invalid. Is
> PW
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517712 is a reply to message #517483] Mon, 01 March 2010 19:28 Go to previous messageGo to next message
I can download everything from home. There are two documents that are almost identical:
and
http://wiki.eclipse.org/E4/SWT/Running_the_demos
The main difference is that the first wants a download from a branch, R0_9, and the second doesn't mention this. Either way, I get the errors described below.
I've got e4, version 0.9, with ActionScript Developer, Flex (with -Dflex.sdk=C:/Flex in eclipse.ini), Java 1.6, and the following items listed in Package Explorer:
org.eclipse.draw2d
org.eclipse.e4.swt.releng (I've imported the project sets)
> org.eclipse.swt (not compiling)
org.eclipse.swt.e4
org.eclipse.swt.e4.examples
org.eclipse.swt.e4.jcl
>org.eclipse.swt.examples (not compiling, dependent on org.eclipse.swt)
I've followed the instructions down to "Get the demos". I've renamed .classpath_flex to .classpath in the org.eclipse.swt.examples project..
When I build (or clean with Build Automatically on), I get 19 errors, of which 15 are
Package 'org.eclipse.swt.awt' does not exist in this plug-in /org.eclipse.swt/META-INF line 12 Plug-in Problem
Package 'org.eclipse.swt.examples.accessibility' does not exist in this plug-in MANIFEST.MF /org.eclipse.swt.examples/META-INF line 10 Plug-in Problem
(and 13 more like #2;)
Draw2d, swt.e4.examples, and swt.examples "cannot be build until [their] prerequisite org.eclipse.swt is built, and, finally
The project was not built since the source file /org.eclipse.swt
/Eclipse SWT/flex/org/eclipse/swt/widgets/Widget.java could not be read Shocked
That's because the directory org.eclipse.swt/Eclipse SWT has no flex subdirectory (although it has cairo, carbon, cocoa, etc., including Win32 - I'm compiling on WinXP (ugh).
Is this simply a missing file? Or did I screw up at an earlier step?
Anything anyone can suggest would be greatly appreciated.
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517720 is a reply to message #517712] Mon, 01 March 2010 15:18 Go to previous messageGo to next message
So you imported all of the projects from
org.eclipse.swt.e4.flex-incubation-0.9.zip and then used the PSF to get
the demo/examples?
PW
Paul Webster
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517723 is a reply to message #517720] Mon, 01 March 2010 20:23 Go to previous messageGo to next message
So you imported all of the projects from org.eclipse.swt.e4.flex-incubation-0.9.zip...
Yes, "Existing Projects (org.eclipse.swt.e4.flex-incubation-0.9) into Workspace > Select archive file", which adds org.eclipse.swt and org.eclipse.swt.e4.jcl
and then used the PSF to get the demo/examples?
yes, "Import Project Set" on org.eclipse.e4.swt.releng/e4.swt.as.demo.psf
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #520113 is a reply to message #517224] Thu, 11 March 2010 08:42 Go to previous message
Marton Sigmond is currently offline Marton SigmondFriend
Member
I can confirm that following the above instructions led to compilation errors.
I tried it on Ubuntu x86_64, and WinXP.
I tried the 0.9, the 1.0M3, and the 1.0M4 builds.
No success yet.
Marton
Best Regards,
Marton Sigmond
Senior Software Engineer
Previous Topic:The way XWT should work
Next Topic:XWT. How to set absolute (null) layout?
Current Time: Wed May 23 07:22:00 GMT 2018
Powered by FUDForum. Page generated in 0.02343 seconds
