Home » Eclipse Projects » Rich Client Platform (RCP) » How to register a context menu for a MultipageEditorPart?
How to register a context menu for a MultipageEditorPart? [message #515253] Thu, 18 February 2010 09:52 Go to next message
Patrick is currently offline PatrickFriend
Member
Hello! Smile
What is the correct way to register a context menu for a MultipageEditorPart?
I'm not using any viewers, just normal swt Composites for the editor pages. I want to implement an own context menu, when rightclicking on the page.
Thanks in advance
Re: How to register a context menu for a MultipageEditorPart? [message #515383 is a reply to message #515253] Thu, 18 February 2010 10:54 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
How are you currently doing it? It seems to me that when you add a
page, you would create the MenuManager, use that to create the context
menu for that page, and then register that MenuManager+selection
provider to register for a context menu.
You might have to make sure that the Menu parent is the Control that you
are going to add it to using setMenu(*).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Enable "Save As" command
Next Topic:Feature-based product build enabling p2
Current Time: Sun Jan 21 20:56:38 GMT 2018
Powered by FUDForum. Page generated in 0.01956 seconds
