Re: Use Date/Time for X-Axis Marker Value [message #514790 is a reply to message #514668] |
Tue, 16 February 2010 11:24 |
That is correct. Marker lines use the category index not the data
value. You can dynamically match the two in the afterDataSetFilled
event. I just wrote up a Birt-Exchange entry for this. Take a look:
http://www.birt-exchange.org/devshare/designing-birt-reports /1158-setting-marker-line-based-on-date-parameter/#descripti on
Jason
drwg wrote:
> I need to add a vertical marker on the x-axis based on a date/time and
> event took place, however, the x-axis market appears to only accept an
> integer value making it difficult to accurately place the marker as the
> date range varies each day.
> How do I enter the marker value as a date-time value? The format option
> appears to recognise the axis as a date-time but the value only acceots
> integers.
> Thanks
FUDForum. Page generated in 0.02607 seconds
