[Tribix 2.5.1] xls is lock, can't release. [message #512825] |
Mon, 08 February 2010 06:09 |
TZ Messages: 3 Registered: February 2010 |
Junior Member |
here is my test code . even after Platform.shutdown(), i can't delete or modify the xls in explorer.
version: org.uguess.birt.report.engine.emitter.xls_2.5.1.201001221050 .jar
Code:
package com.symbol.elvisapp.report;
import java.io.File;
import java.util.logging.Level;
import org.apache.log4j.PropertyConfigurator;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformFileContext;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.ScriptDataSetHandle;
import org.eclipse.birt.report.model.api.SlotHandle;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
* Test Case for Birt
public class TestBirt {
protected Logger logger = LoggerFactory.getLogger(this.getClass());
private String rootPath = this.getClass().getClassLoader().getResource("").getPath();
private String birtHome = "ReportEngine";
private String birtLogPath = "report" + File.separator + "log" + File.separator;
private String birtTemplatePath = "report" + File.separator + "tpl" + File.separator;
private String birtOutputPath = "report" + File.separator + "output" + File.separator;
private IReportEngine engine;
public TestBirt() {
PropertyConfigurator.configure(getClass().getClassLoader().getResource("config/log4j.properties"));
initReportEngine();
private void initReportEngine() {
try {
logger.info("Init BirtHome:{}", birtHome);
EngineConfig config = new EngineConfig();
config.setBIRTHome(rootPath + birtHome);
config.setLogConfig(rootPath + birtLogPath, Level.WARNING);
IPlatformContext context = new PlatformFileContext(config);
config.setPlatformContext(context);
logger.info("to startup platform");
Platform.startup(config);
logger.info("finish startup platform,to create factory");
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
logger.info("finish create factory,to create engine");
engine = factory.createReportEngine(config);
logger.info("finish create engine");
} catch (BirtException e) {
logger.error("Init Birt fail,{}", e.toString());
public void test() {
try {
logger.info("open TestReport.rptdesign");
// a simple report from birt
IReportRunnable reportRunnable = engine.openReportDesign(rootPath + birtTemplatePath
+ "TestReport.rptdesign");
ReportDesignHandle rdh = (ReportDesignHandle) reportRunnable.getDesignHandle();
ScriptDataSetHandle sdsh = (ScriptDataSetHandle) rdh.findDataSet("MyDataSet");
logger.info("create task");
IRunAndRenderTask task = engine.createRunAndRenderTask(reportRunnable);
EXCELRenderOption excelRenderOption = new EXCELRenderOption();
excelRenderOption.closeOutputStreamOnExit(true);
excelRenderOption.setOutputFormat("xls");
excelRenderOption.setOutputFileName(rootPath + birtOutputPath + "TestReport.xls");
task.setRenderOption(excelRenderOption);
logger.info("to run task");
task.run();
logger.info("finish run task,to close task");
SlotHandle sh = rdh.getDataSets();
task.close();
logger.info("finish close task, to destroy engine.");
engine.destroy();
logger.info("finish destroy engine,to shutdown platform");
Platform.shutdown();
logger.info("finish shutdown platform");
//sleep to test delete
Thread.sleep(5000);
logger.info("exit");
} catch (EngineException e) {
e.printStackTrace();
} catch (InterruptedException e) {
public void testDataSet() {
new TestBirt().test();
FUDForum. Page generated in 0.02680 seconds
