Excel export in 2.5.0 app fails but developer works - JAR files differ [message #512364] |
Thu, 04 February 2010 19:00 |
I have BIRT 2.5.0. I deisgned a report that runs in the web viewer and exports successfully to Excel from the designer. However, when I try to export that same report from my application it generates all sorts of errors with this as the only indicative one:
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:232)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(ReportEngineService.java:1461)
... 49 more
Caused by: java.lang.IndexOutOfBoundsException: Index: 3, Size: 3
at java.util.ArrayList.RangeCheck(ArrayList.java:547)
at java.util.ArrayList.get(ArrayList.java:322)
at org.eclipse.birt.report.engine.emitter.excel.DataCache.addDa ta(DataCache.java:71)
I then discovered that the emitter JAR files for the RCP designer have the same version number but different file sizes from those in the runtime package.
Is that relevant or should I be looking elsewhere?
Richard
Re: Excel export in 2.5.0 app fails but developer works [message #512580 is a reply to message #512364] |
Fri, 05 February 2010 14:35 |
No, the app is Java code using Hibernate and a number of things.
I did subsequently rule out the JAR file differences (although I don't understand why they exist) - I substituted the JARs from the runtime package and the report still works correctly in the designer.
I got a workaround. The report has a grid at the top with image elements. If I mark the grid rows containing images as visibility = false for XLS, the report exports just fine. Notably, if I only mark the image elements as visibility = false, the export still fails.
I'm going to have to look up some resources and figure out how to put together a simple application framework so that I can replicate things like this using the Derby database since I can't send the application code from our company.
Re: Excel export in 2.5.0 app fails but developer works [message #512615 is a reply to message #512580] |
Fri, 05 February 2010 16:08 |
Richard,
Can you open a bug for this?
Jason
FUDForum. Page generated in 0.03223 seconds
