Home » Eclipse Projects » Eclipse 4 » How do you integrate existing 3.5 RCP views into a Modeled UI?
How do you integrate existing 3.5 RCP views into a Modeled UI? [message #505016] Thu, 24 December 2009 08:44 Go to next message
David Wynter is currently offline David WynterFriend
I love Modeled UI, it would be particularly useful for designing the app
layout and std parts, if you could integrate GMF developed designers and
more complex parts within the e4 Modeled UI app layout. In addition if I
could grab an Editor part generated from EMF and reference that from
within Application.xmi that would really help. But it is unclear to me
whether this is possible. Is it possible?
Even if we had to 'wrap' the 3.5 part in a layer that made it satisfy
any e4 specific interface required may be an acceptable approach.
David
Re: How do you integrate existing 3.5 RCP views into a Modeled UI? [message #506019 is a reply to message #505016] Tue, 05 January 2010 13:56 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
There's a lot of IEditorPart lifecycle that is not currently supported
in the 1.0 e4 work we're doing. I'll be working with Boris to start
enhancing the compatibility layer more with what is needed to support
3.x views and editors.
On of the deliverables for 1.0 is to host a clean 3.x editor or view in
a modeled workbench (for some value of "clean" :-)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:A problem in rcp+xml project
Next Topic:XWT + DataBinding +HashMap
Current Time: Mon Apr 23 11:54:08 GMT 2018
Powered by FUDForum. Page generated in 0.02127 seconds
