Home » Eclipse Projects » Eclipse Platform » "View descriptor not found"
"View descriptor not found" [message #503585] Mon, 14 December 2009 20:05 Go to next message
Originally posted by: yoduderoo.netscape.net
How can I debug "View descriptor not found" ? I am doubly, triply,
quadruply sure that the view id passed in addView() (called during the
perspective's createInitialLayout() method) is really the view id of the
view to which I refer and that view is declared in its plugin. In fact,
it works in my workspace but not in the binary despite the very same
plugins being present in the binary.
Nevertheless, I get "View descriptor not found" (stack trace attached at
end).
Any tips appreciated.
Thanks, y
!ENTRY org.eclipse.ui 4 4 2009-12-14 20:57:53.854
!MESSAGE Exception in
org.eclipse.ui.internal.FolderLayout.addView(String):
org.eclipse.ui.PartInitException: View descriptor not found:
foo.UserAttrGraphView
!ENTRY org.eclipse.ui 4 4 2009-12-14 20:57:53.869
!STACK 1
at org.eclipse.ui.internal.FolderLayout.addView(FolderLayout.ja va:75)
foo.BarPerspectiveFactory.createInitialLayout(BarPerspective Factory.java:29)
Re: "View descriptor not found" [message #503654 is a reply to message #503585] Tue, 15 December 2009 08:51 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
On 15/12/09 1:35 AM, Yodude wrote:
> end).
Does the view class has a default constructor?
- Prakash
Platform UI Team, IBM
Blog <http://blog.eclipse-tips.com>
Twitter <http://www.twitter.com/Eclipse_Tips>
Re: "View descriptor not found" [message #503949 is a reply to message #503654] Wed, 16 December 2009 10:26 Go to previous message
Yes, the view class had a default constructor.
I was driven half-mad and finally created a new plugin and copied the
sources over. Then it worked. Never understood what the problem was.
Thanks, y
>> end).
> - Prakash
Previous Topic:CVS Console not showing any output
Next Topic:Creating a Custom Eclipse Compare Editor
Current Time: Thu Apr 19 19:47:11 GMT 2018
Powered by FUDForum. Page generated in 0.02266 seconds
