Empty name to be accepted in the TextCellEditor [message #502945] |
Thu, 10 December 2009 12:04 |
saurav sarkar Messages: 428 Registered: July 2009 |
Hi All,
I have a text cell editor.I want the behaviour of the text cell editor may contain an empty name.But on the empty name we get the following error.
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
at org.eclipse.jface.viewers.TextCellEditor.doSetValue(TextCell Editor.java:228)
at org.eclipse.jface.viewers.CellEditor.setValue(CellEditor.jav a:855)
at org.eclipse.jface.viewers.EditingSupport.initializeCellEdito rValue(EditingSupport.java:96)
at org.eclipse.jface.viewers.ColumnViewerEditor.activateCellEdi tor(ColumnViewerEditor.java:194)
at org.eclipse.jface.viewers.ColumnViewerEditor.handleEditorAct ivationEvent(ColumnViewerEditor.java:443)
at org.eclipse.jface.viewers.ColumnViewer.triggerEditorActivati onEvent(ColumnViewer.java:680)
at org.eclipse.jface.viewers.ColumnViewer.handleMouseDown(Colum nViewer.java:664)
at org.eclipse.jface.viewers.ColumnViewer.access$0(ColumnViewer .java:660)
at org.eclipse.jface.viewers.ColumnViewer$1.mouseDown(ColumnVie wer.java:89)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:179)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Can we have some way to stop the exception popping up
Thanks and Regards,
Saurav
My Blog http://codifyit.blogspot.com/
Follow me: http://twitter.com/sauravs
FUDForum. Page generated in 0.03263 seconds
