Home » Eclipse Projects » EPF » Creating guidances and publishing from code
Creating guidances and publishing from code [message #50687] Wed, 28 May 2008 11:21 Go to next message
Originally posted by: qdeme.yahoo.fr
I can't find a way to create a new guidance in the resource set of my
Method Plug-in and link it to other objects. There's no documentation
concerning the use of the EPF library, and searches on the web gave no
usable answer.
How can I create a new guidance ? (it's apparently impossible to use :
Guidance g = new Guidance(), for example)
Another question : I can't find any documentation about publishing from
the code neither. I'd like to use the "Publish" function of EPF in an
Eclipse plug-in I made, in Java. How does it have to be used ?
Thank you for your answers
Re: Creating guidances and publishing from code [message #52641 is a reply to message #50687] Thu, 14 August 2008 09:13 Go to previous message
Originally posted by: veerabadrachari.gmail.com
Have u created content packages using code under a particular method
plugin. If yes, Could u please pass on the code to me.
I am trying to do this and I am not able to this.
Thanks in advance
Re: Creating guidances and publishing from code [message #590097 is a reply to message #50687] Thu, 14 August 2008 09:13 Go to previous message
Thanks in advance
Previous Topic:Customizing EPF: Unable to create Content Package for a plugin through Code
Next Topic:no xmi file generated when creating a new method element...
Current Time: Wed Apr 25 08:56:05 GMT 2018
Powered by FUDForum. Page generated in 0.03269 seconds
