Home » Modeling » Epsilon » DEFINE TWO DIFFERENT SIZED COMPARTMENT IN THE SAME ELEMENT
DEFINE TWO DIFFERENT SIZED COMPARTMENT IN THE SAME ELEMENT [message #496134] Sun, 08 November 2009 22:44 Go to next message
marco  is currently offline marco Friend
Member
hi
I have the following problem.
I have an element (rectangular) with two compartment of equal size.
http://img258.imageshack.us/img258/3777/size.jpg
I want have a bigger compartment and a smaller one.
for example the first 4 / 5 of the total size of the rectangle and the second 1 / 5 of the total size of the rectangle.
http://img188.imageshack.us/img188/1783/size2r.jpg
I can solve this problem?how?
THANKS
MARCO
Re: DEFINE TWO DIFFERENT SIZED COMPARTMENT IN THE SAME ELEMENT [message #496135 is a reply to message #496134] Sun, 08 November 2009 22:57 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Marco,
This is not supported natively by Eugenia. I hope you get an answer to
your question in the GMF forum soon.
On a side note, I'd recommend refraining from using all upper-case
letters in titles (or anywhere else) as this is often perceived as
shouting (see http://www.dur.ac.uk/its/usenet/guidelines/ for more
useful guidelines on posting to newsgroups).
Dimitris
marco wrote:
> hi
> THANKS
> MARCO
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:Model Elemenet Types: "!" vs. "::"
Next Topic:DEFINE TWO DIFFERENT SIZED COMPARTMENT IN THE SAME ELEMENT
Current Time: Thu May 24 12:14:23 GMT 2018
Powered by FUDForum. Page generated in 0.01820 seconds
