Home » Modeling » Epsilon » Autocompletition (Total Nub)(Automatic completition "not found")
Autocompletition (Total Nub) [message #494060] Wed, 28 October 2009 22:20 Go to next message
Horacio Hoyos is currently offline Horacio Hoyos
I am a newcomer to both modeling and Epsilon. My prior, and short, experience is with oaw. I was trying to do a small ETL example to initiate my work in Epsilon.
The issue is that in oaw once I defined a variable of a metamodel "type", I could use the '.' (dot) to navigate throught the properties of that varaible. I tried doing the same on ETL but the editor is not giving me any options when either using the '!' or the '.'.
Any pointers?
Horacio Hoyos
Horacio Hoyos Rodriguez
EngD Student
University Of York
Re: Autocompletition (Total Nub) [message #494149 is a reply to message #494060] Thu, 29 October 2009 07:21 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Horacio,
Epsilon languages such as ETL are not statically typed (there are pros
and cons to this) and as such, code completion is not available in the
editors.
Dimitris
Horacio wrote:
> Hello,
> Any pointers?
> Horacio Hoyos
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Autocompletition (Total Nub) [message #494178 is a reply to message #494149] Thu, 29 October 2009 09:34 Go to previous messageGo to next message
Thanks for the clarification.
For me no typos, "faster" writing and Epsilon functions/methods hints are definitively among the benefits. Any chance this will happen in the future? In the time being is there any "dirty" (hopefully easy) way to git this functionality?
Horacio Hoyos
EngD Student
University Of York
Re: Autocompletition (Total Nub) [message #494328 is a reply to message #494178] Fri, 30 October 2009 06:05 Go to previous message
Hi Horacio,
The main reason why we haven't added static type-checking is so that we
can keep the infrastructure lightweight and agile. This has enabled us
to add novel features such as extended properties, integration with
Java, support for models without metamodels etc. with little effort and
side-effects.
I understand and appreciate the benefits of code completion and semantic
error highlighting but we really don't want to lose this flexibility, so
we'll have to think of a good way to harvest the best of both worlds.
Unfortunately, there doesn't seem to be easy/dirty way to do this (but
please let us know if you can think of any), so this will most probably
require significant changes to Epsilon. We don't have any plans for this
for the near future but it's definitely something worth considering in
the long run.
Dimitris
P.S. For further reading on the pros/cons of static vs. dynamic
languages please Google "static vs. dynamic languages"
P.S.2 The EPackage registry view
( http://www.eclipse.org/gmt/epsilon/doc/articles/epackage-reg istry-view/)
might be able to compensate to an extent for the lack of static typing.
Dimitris
> Horacio Hoyos
Re: Autocompletition (Total Nub) [message #582403 is a reply to message #494149] Thu, 29 October 2009 09:34 Go to previous message
Horacio Hoyos
EngD Student
University Of York
Re: Autocompletition (Total Nub) [message #582419 is a reply to message #494178] Fri, 30 October 2009 06:05 Go to previous message
Hi Horacio,
side-effects.
the long run.
Dimitris
Dimitris
> Horacio Hoyos
Previous Topic:Autocompletition (Total Nub)
Next Topic:[Eugenia] Subdiagrams
Current Time: Wed Jun 19 15:56:33 EDT 2013
Powered by FUDForum. Page generated in 0.01777 seconds
