Home » Modeling » Epsilon » ETL: creation of arbitrary number of target traceable elements
Re: ETL: creation of arbitrary number of target traceable elements [message #489060 is a reply to message #489059] |
Thu, 01 October 2009 12:10 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Esther,
Yes, collection types (Bag, Sequence etc.) are supported as target types
of ETL rules so you should be able to do this.
Dimitris
Esther wrote:
> Hi Dimitris,
> I need to define ETL rules that create an arbitrary number of
> target elements (not known a priori), and I need to be able to
> access those created elements in the body of the rule by using
> the operation "equivalents".
> Is that possible, e.g. by defining that the target element of
> the rule is a Bag, or by including the created elements in the
> trace so that the "equivalents" operation return them?
> If this is not possible, perhaps I could store in a variable
> all these created elements, and then build my own operation
> "myEquivalents"... Would that be possible, and how?
> Thanks & cheers,
> Esther
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: ETL: creation of arbitrary number of target traceable elements [message #489149 is a reply to message #489060] |
Thu, 01 October 2009 15:55 |
Esther Messages: 8 Registered: July 2009 |
Junior Member |
Thanks a lot.
Also, is there a method, similar to "equivalents", that returns
the target elements in which a source element has been transformed,
but without invoking any rule in case the source element has not
been transformed yet? I know how to do it by accessing transTrace,
but is there another way?
Thanks again,
Esther
Dimitris Kolovos escribió:
> Hi Esther,
> Cheers,
> Dimitris
> Esther wrote:
>> Hi Dimitris,
>> Thanks & cheers,
>> Esther
Re: ETL: creation of arbitrary number of target traceable elements [message #489153 is a reply to message #489149] |
Thu, 01 October 2009 16:05 |
Hi Esther,
There is no built-in function for this but as you mentioned, you can
indeed trace target->source elements by querying the transformation trace.
Dimitris
Esther wrote:
> Thanks a lot.
> Thanks again,
> Esther
>> Hi Esther,
>> types of ETL rules so you should be able to do this.
>> Cheers,
>> Dimitris
>> Esther wrote:
>>> Hi Dimitris,
>>> Thanks & cheers,
>>> Esther
Re: ETL: creation of arbitrary number of target traceable elements [message #581234 is a reply to message #489059] |
Hi Esther,
Dimitris
Esther wrote:
> Hi Dimitris,
> Thanks & cheers,
> Esther
Re: ETL: creation of arbitrary number of target traceable elements [message #581255 is a reply to message #489060] |
Junior Member |
Thanks a lot.
Thanks again,
Esther
> Hi Esther,
> Cheers,
> Dimitris
> Esther wrote:
>> Hi Dimitris,
>> Thanks & cheers,
>> Esther
Re: ETL: creation of arbitrary number of target traceable elements [message #581273 is a reply to message #489149] |
Hi Esther,
Dimitris
Esther wrote:
> Thanks a lot.
> Thanks again,
> Esther
>> Hi Esther,
>> Cheers,
>> Dimitris
>> Esther wrote:
>>> Hi Dimitris,
>>> Thanks & cheers,
>>> Esther
Current Time: Thu Apr 25 19:31:23 GMT 2024
Powered by FUDForum. Page generated in 0.03759 seconds
