Home » Modeling » M2T (model-to-text transformation) » [XPAND] EvaluationException
[XPAND] EvaluationException [message #487322] |
Tue, 22 September 2009 18:36 |
--------------060801020505060105000804
from time to time if I run some workflows manually from workspace,
suddenly I got an EvaluationException : null
this happens on different lines
80753 ERROR AbstractExpressionsUsingWorkflowComponent - Error in
Component generator of type org.eclipse.xpand2.Generator:
the only help was to restart eclipse
any idea ?
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
<html>
<head>
</head>
from time to time if I run some workflows manually from workspace,<br>
suddenly I got an EvaluationException : null <br>
this happens on different lines<br>
<br>
Component generator of type org.eclipse.xpand2.Generator: <br>
ekke
independent software architect
blog: http://ekkes-corner.org
Re: [XPAND] EvaluationException [message #488494 is a reply to message #488454] |
Mon, 28 September 2009 21:52 |
--------------010802030703030201080604
Content-Type: text/plain; charset=UTF-8; format=flowed
Manfred Klug schrieb:
> Quote:
>> suddenly I got an
>> EvaluationException : null this happens on different lines
> I can confirm the Problem. But without a stacktrace of the root
> exception, I see no way to diagnose the problem.
same for me - no stacktrace
only solution: restart eclipse
good to know that I'm not the only one
skype: ekkes-corner
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:h9qsu8$cqr$1@build.eclipse.org" type="cite">Quote:
<br>
<blockquote type="cite">from time to time if I run some workflows
manually from workspace, suddenly I got an
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
same for me - no stacktrace<br>
only solution: restart eclipse<br>
<br>
good to know that I'm not the only one<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------010802030703030201080604--
ekke
Re: [XPAND] EvaluationException [message #488748 is a reply to message #488494] |
Wed, 30 September 2009 06:19 |
--------------060307080000020105030809
just happened again - this time in a 'small' workflow,
but after running some other workflows before
have to restart eclipse
should I open a bugzilla ?
29973 ERROR AbstractExpressionsUsingWorkflowComponent - Error in
org::ekkescorner::oaw::cartridge::java::Naming.ext[11938,87] on line
268
'{"int","byte","short","boolean","long","float", "double","char"}.contains(t.name)'
org::ekkescorner::oaw::cartridge::java::Naming.ext[12155,19] on line
274
't.isJavaPrimitive()'
org::ekkescorner::oaw::cartridge::java::Naming.ext[5678,15] on line
145
'isPrimitive(dt)'
org::ekkescorner::oaw::cartridge::java::Naming.ext[12647,5] on line
289
'p.type.fqn()'
org::ekkescorner::oaw::cartridge::jpa::EntityAttribute.xpt[2 025,26]
on line 48
'isAssociationAsAttribute()'
org::ekkescorner::oaw::cartridge::jpa::EntityAttribute.xpt[1 641,37]
on line 36 'EXPAND persistentAttributeRoot FOR
pa'
org::ekkescorner::oaw::cartridge::jpa::EntityClass.xpt[1410, 43] on
line 31 'EXPAND
EntityAttribute::entityAttributeRoot'
org::ekkescorner::oaw::cartridge::jpa::Entity.xpt[290,74] on line 11
'EXPAND
org::ekkescorner::oaw::cartridge::jpa::EntityClass::entityCl assRoot'
org::ekkescorner::oaw::cartridge::jpa::Root.xpt[2597,19] on line 58
'EXPAND
Entity::Root'
org::ekkescorner::oaw::cartridge::jpa::Root.xpt[2237,90] on line 47
'EXPAND classRoot FOREACH
allOwnedElements().typeSelect(uml::Class).select(e|e.isMyCla ss())'
org::ekkescorner::oaw::cartridge::jpa::Root.xpt[1160,160] on line 26
'EXPAND DatenRoot FOREACH
allOwnedElements().typeSelect(uml::Package).select(e|e.owner .metaType.==(uml::Model)).select(e|e.name.matches(getJPAMode lPackageRoot()))'
[23,76] on line 1 'EXPAND
org::ekkescorner::oaw::cartridge::jpa::Root::Root FOR entityDataModel'
>> Quote:
>>> suddenly I got an
> skype: ekkes-corner
skype: ekkes-corner
<html>
<head>
</head>
just happened again - this time in a 'small' workflow,<br>
but after running some other workflows before<br>
<br>
have to restart eclipse<br>
<br>
should I open a bugzilla ?<br>
<br>
EvaluationException : null<br>
line 268
'{"int","byte","short","boolean","long","float", "double","char" }.contains(t.name)'
ekke
Re: [XPAND] EvaluationException [message #488751 is a reply to message #488748] |
Wed, 30 September 2009 06:49 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Ekke,
please file a ticket and provide detailled information about the Xpand
version and the Eclipse version, start params etc. It would be great if
you could attach a reproducable example although I guess that this issue
cannot be reproduced reliably.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
> 268
> 274
> 145
> 'isPrimitive(dt)'
> 289
> 'p.type.fqn()'
> on line 48
> pa'
> line 31 'EXPAND
> 'EXPAND
> 'EXPAND
> Entity::Root'
>>> Quote:
>>>> suddenly I got an
>> skype: ekkes-corner
> skype: ekkes-corner
Re: [XPAND] EvaluationException [message #488756 is a reply to message #488751] |
Wed, 30 September 2009 07:10 |
--------------050208090600060801040703
Sebastian Zarnekow schrieb:
> Hi Ekke,
> if you could attach a reproducable example although I guess that this
> issue cannot be reproduced reliably.
> Sebastian
I'll update to 0.8.0 and see if it still happens - then I'll file a ticket
there's no easy reproduceable way - because it happens after some runs
of workflows and then it happens in different workflows at different
lines of code
I'll let you know
btw: happens on 3.5 or 3.6, osx, java 6, and workflows using uml + emf
and a tree of cartridges
skype: ekkes-corner
<html>
<head>
</head>
<blockquote cite="mid:h9uv2d$avp$1@build.eclipse.org" type="cite">Hi
Ekke,
<br>
<br>
<br>
<br>
<br>
Sebastian
<br>
</blockquote>
ticket<br>
<br>
lines of code<br>
<br>
I'll let you know<br>
<br>
and a tree of cartridges<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
--------------050208090600060801040703--
ekke
Current Time: Fri Apr 19 19:41:44 GMT 2024
Powered by FUDForum. Page generated in 0.03113 seconds
