Home » Eclipse Projects » BIRT » how to define as data source a passed jdbc connection
how to define as data source a passed jdbc connection [message #484392] Mon, 07 September 2009 11:19 Go to next message
Diana Mising name is currently offline Diana Mising nameFriend
Member
I am very new to BIRT and I want to create a sort of "hello world" report.
I'm trying to see how difficult it would be to switch our company's
reporting app from jasper to BIRT.
I have seen the tutorials and all seems great, until I realized I have to
pass the jdbc connection from my app to the report. So in my code I set:
task.getAppContext().put("OdaJDBCDriverPassInConnection", conn);
but then how do I define the data source in the report designer? I imagine
it would have to be a scripted data source, but the given examples suggest
that a scripted data source is a completely different thing.
So - how can I use the connection that I set in the IRunAndRenderTask task?
Re: how to define as data source a passed jdbc connection [message #484555 is a reply to message #484392] Tue, 08 September 2009 08:36 Go to previous messageGo to next message
John Missing name is currently offline John Missing nameFriend
In report designer use the standard "jdbc datasource" und "jdbc dataset".
In your app first call
and then
"runAndRender()"
your connection "conn" is used instead of the connection and/or datasource you defined directly in your rptdesign-file.
There's a bug in birt 2.5 that you cannot use OdaJDBCDriverPassInConnection with crosstab reports.
Scripted data source is completley different - we use it to pass in java objects from our apps to birt.
John
Diana Pop schrieb:
> Hi
> report. I'm trying to see how difficult it would be to switch our
> company's reporting app from jasper to BIRT.
> to pass the jdbc connection from my app to the report. So in my code I set:
> imagine it would have to be a scripted data source, but the given
> examples suggest that a scripted data source is a completely different
> thing.
Re: how to define as data source a passed jdbc connection [message #484596 is a reply to message #484555] Tue, 08 September 2009 12:54 Go to previous message
Member
thank you !!
Previous Topic:ClassNotFoundException: oracle.jdbc.driver.OracleDriver
Next Topic:Performance problem
Current Time: Mon May 21 11:19:51 GMT 2018
Powered by FUDForum. Page generated in 0.02491 seconds
