Minor compilation issue in org.eclipse.epsilon.test [message #483770] |
Wed, 02 September 2009 21:17 |
Originally posted by: nyoescape.gmail.com
--------------040703050504040109010304
Content-Type: text/plain; charset=ISO-8859-1
Hi list,
I've recently updated to the latest version in SVN, and I'm glad to say
that everything works just fine, so I don't need to maintain any patches
on my own anymore.
I had to fix two lines in org.eclipse.epsilon.test.EpsilonTestSuite to
remove some compilation errors, though. It's nothing, really: looks like
something left over from the recent Flock renaming. I've attached the patch.
Antonio
Content-Type: text/x-patch;
name="compilation-fix.patch"
Content-Disposition: inline;
filename="compilation-fix.patch"
--- tests/org.eclipse.epsilon.test/src/org/eclipse/epsilon/test/ EpsilonTestSuite.java.old
+++ tests/org.eclipse.epsilon.test/src/org/eclipse/epsilon/test/ EpsilonTestSuite.java
@@ -23,7 +23,7 @@ import org.eclipse.epsilon.eol.test.unit.EolUnitTestSuite;
import org.eclipse.epsilon.hutn.test.HutnTestSuite;
import org.eclipse.epsilon.hutn.unparser.HutnUnparserUnitTestSuite;
import org.eclipse.epsilon.hutn.xmi.test.HutnXmiTestSuite;
-import org.eclipse.epsilon.migration.test.EpsilonMigrationLanguageT estSuite;
+import org.eclipse.epsilon.flock.test.EpsilonFlockEngineTestSuite;
import org.junit.runner.RunWith;
import org.junit.runners.Suite;
import org.junit.runners.Suite.SuiteClasses;
@@ -34,7 +34,7 @@ import org.junit.runners.Suite.SuiteClasses;
EglTestSuite.class,
HutnTestSuite.class,
HutnUnparserUnitTestSuite.class, HutnXmiTestSuite.class,
- EpsilonMigrationLanguageTestSuite.class})
+ EpsilonFlockEngineTestSuite.class})
public class EpsilonTestSuite{
public static Test suite() {
--------------040703050504040109010304--
FUDForum. Page generated in 0.02544 seconds
