Home » Modeling » Epsilon » [EuGENia | EOL] Adding new label problem
[EuGENia | EOL] Adding new label problem [message #482899] Fri, 28 August 2009 13:44 Go to next message
Mihir is currently offline MihirFriend
Member
I'm trying to add a new label to the compartment of XXX node. But it is
not working out.
var label = new GmfGraph!Label("temp");
CompartmentFigure.children.add(label);
If I do this then it allows me to all blank label where I want but, when
I try to add name and text to label it is not working.
var label = new GmfGraph!Label;
label.name = "RuleNacsCompartmentFigureLabel";
label.text = "NACs Compartment";
Please help me with this.
Many thanks,
Mihir
Re: [EuGENia | EOL] Adding new label problem [message #482907 is a reply to message #482899] Fri, 28 August 2009 13:47 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Mihir,
EOL doesn't support constructors with parameters for model elements such
as GmfGraph!Label("temp").
Also, in EOL strings are placed within '' (support for "" will be added
in the next version) so you should try:
label.name = 'RuleNacsCompartmentFigureLabel';
label.text = 'NACs Compartment';
Dimitris
Mihir wrote:
> Hello,
> not working out.
> Many thanks,
> Mihir
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
{solved} [EuGENia | EOL] Adding new label problem [message #482941 is a reply to message #482907] Fri, 28 August 2009 15:35 Go to previous message
Member
Hi Dimitris,
Thanks for your help.
Actually I was just experimenting with the constructor if it works and
so I forgot to remove it while pasting that bit of code here in the post. :)
After changing "" to '', it works fine.. :)
Thanks a million,
Mihir
Dimitris Kolovos wrote:
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> is not working out.
>> when I try to add name and text to label it is not working.
>> Many thanks,
>> Mihir
Re: [EuGENia | EOL] Adding new label problem [message #579841 is a reply to message #482899] Fri, 28 August 2009 13:47 Go to previous message
Hi Mihir,
Dimitris
Mihir wrote:
> Hello,
> not working out.
> Many thanks,
> Mihir
{solved} [EuGENia | EOL] Adding new label problem [message #579858 is a reply to message #482907] Fri, 28 August 2009 15:35 Go to previous message
Member
Hi Dimitris,
Thanks a million,
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> is not working out.
>> Many thanks,
>> Mihir
Previous Topic:[EuGENia | EOL] Adding new label problem
Next Topic:[EuGENia | FixGMFGen.eol]
Current Time: Tue Apr 16 12:23:23 GMT 2024
Powered by FUDForum. Page generated in 0.43623 seconds
