Home » Modeling » Epsilon » Regressions in EolSet since SVN r558?
Regressions in EolSet since SVN r558? [message #482536] Wed, 26 August 2009 23:00 Go to next message
Originally posted by: nyoescape.gmail.com
--------------060607060009080308060303
Content-Type: text/plain; charset=ISO-8859-1
Hi list,
Since 0.8.7 was recently released and contained all the bugfixes I had
been dragging over my local Epsilon SVN working copy, I decided to
upgrade and see if I could just install the latest version from the
update repo from now on. Looks like I hit a few snags in EolSet due to
changes around SVN revision 558, though. I have since updated to the
latest version in SVN, and I'm experiencing the same problems.
I have attached a set of projects which reproduce the two issues I'm
currently experiencing:
- It seems that trying to access a derived attribute results in an
UnsupportedOperationException if its value goes to an EolSet, as it
tries to remove duplicates from an unmodifiable list (see
EcoreEList$UnmodifiableEList in http://tinyurl.com/kw9lts). It happens
right here in EolSet.java:
protected void removeDuplicates(){
List unique = new ArrayList();
Iterator it = storage.iterator();
while (it.hasNext()){
storage.clear(); <------ ** here **
it = unique.iterator();
storage.add(it.next());
If I wrap the second half of removeDuplicates with a try ..
catch(UnsupportedOperationException ex) which ignores this exception,
everything works again as normal:
try {
storage.clear();
} catch (UnsupportedOperationException ex) {}
To reproduce this with the attached set of projects, unpack them into
a workspace and run the included "Test Set Regression
(UnsupportedOperationException)" run configuration. It runs the
testScript.eol script against the simple.ecore ECore model. It should
generate an exception stack trace without the fix above.
- The same code (removeDuplicates) appears to be responsible for another
regression: sometimes, I'll get IllegalStateExceptions saying that the
resource set cannot be modified without a write transaction when I run
an EVL script from a GMF editor. I don't get this error from an EMF
editor, but that's to be expected, due to bug #287542.
The line which causes these exceptions is the same "storage.clear()"
line as above. I've tried ignoring that exception, but it is no use:
somehow, the EObjects in storage seem to have disappeared after the
exception has been launched. I guess the best thing would be to avoid
removing duplicates if no transaction was in effect, but this would
couple EolSet to EMC/EMF, and I don't like that at all. However, I
don't really know how to fix this in a clean way.
To reproduce this problem, launch an Eclipse instance with the
TestRegressionSet.* plugins and create a new "Simple Diagram". Add two
nodes and at least one link between them. Save, use "Edit >
Validate": a message box with the text of the exception will pop up.
Save if necessary and hit Refresh: the links will disappear. Check the
EMF model: the source and target properties of the links are now
empty.
Antonio
Content-Type: application/zip;
name="EolSetRegressions.zip"
Content-Disposition: inline;
filename="EolSetRegressions.zip"
UEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAcAAAAVGVzdFNldFJlZ3Jlc3Np b24vLmNsYXNz
cGF0aJWQQWsCMRCFz/orltydrUKhh12llC0o1BbdepWYDOu06SSdJKX++1Za UQoVvM0bvvdm
eNXk880VHyiRPNdqCFeqQDbeEne1em7vBzdqMu5XxukYg07bcb93FMhJdsUr sa1VFKOK/fJn
LP8FjecD6KUDNI5CRHixCZzObLbfp2G2aNZ3j/P2djpvFuVfjjihsHZgcZM7 yPTrRIFl0my1
2NVDuwtYzkbLZjCE68v/CRbBeEEQfM8kaJ9c7ojjmSSfU8jpELYh3rNVedLd F1BLBwiUuP5i
zAAAAG8BAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAABoAAABUZXN0U2V0 UmVncmVzc2lv
bi8ucHJvamVjdL2SzWoCMRSF1/oUMnuTducijmBLdy3F0QeIyTVmmPyQZKSP 35uZKCoIhYK7
c+49N1/+2OrHdLMThKidXVav5KWagRVOaquW1W77MV9Uq3rKfHAtiPQOUQTt E4br6YRZbqDe
QkwNpA2oADEvw+hQx75wxoBNNaNnhcWyVMyaXpt9rzvZeBBoinvDMW5lLhSa C4qA6LSPQFqZ
iHABBT/xIQ/hAscBHlSfqXG09MYzek/4C9JLIJ/c6gMeev00YiOOYPi/eaVQ rhhRqccnG6Kj
fny7Yz+jh9yDkbzX765X2n7d588ScZdXv/lNv1BLBwjFbns16gAAAIoCAABQ SwMEFAAIAAgA
EQQbOwAAAAAAAAAAAAAAAEwAAABUZXN0U2V0UmVncmVzc2lvbi9UZXN0IFNl dCBSZWdyZXNz
aW9uIChVbnN1cHBvcnRlZE9wZXJhdGlvbkV4Y2VwdGlvbikubGF1bmNobVHL bsIwELzzFZaR
emsMSKiFYhCFcAIhFbj14iZLsOrYkXfD4+9rkqaipTfvzu7MeHY0OeeGHcGj dlbybtThDGzi
Um0zyXfbxeMzn4xbI6NKmxxmzu51VnpFYZrRpQDJnc8iKFAbZyNwJoLE6AIh SimqlwJTFDuz
vGeYg4FMEfCrgEaaEnn9URKwT7hInrsUDDZgbMlf2FGZMoi2H9rdzkt7WwKb lhnr9Vl3MOz2
hv0nNos3W9brdAbViMYVkKqYFtrAq0JI5V4ZhAq2KgcZz5yvSw8qXdulU6kk X9Y9pICu7Vxj
4VCZm2VldKBDWRV5I7PzWh6IivehEKfT6SePkJOAfC+CtZ6Ik0ayCjFeLWqS xqcUW0DaAL1B
5gGvxxGo88JA4GtW4Vwoe+M0v/1p7YqLkJ74lW1oYHja7E/a6EqfAG8S/scA XTuJ1wVdD/1N
fX/VcesLUEsHCELEeAVWAQAAVQIAAFBLAwQUAAgACAARBBs7AAAAAAAAAAAA AAAAIgAAAFRl
c3RTZXRSZWdyZXNzaW9uL2J1aWxkLnByb3BlcnRpZXN1jrEKAjEQRPv9ioBX 6uYHVLBQuOKs
LG00Wc5IcrtsEtC/N1op6nRvHgwDM7N0LHcN46WsoZF9x1Z0ve8AzmHCMLlY PWWzMjg/gvlM
Yk/RfvfD9rBZ9PvdDyWxjm33luJfJ8pCWgJluJ40o+MkIRKyetLnEchc1RFi g6zOAtcitby4
nbbwAFBLBwgQQai8hgAAAOIAAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAA ACMAAABUZXN0
U2V0UmVncmVzc2lvbi9wbHVnaW4ucHJvcGVydGllc+NSVrBJzi+oLMpMzyix 4wLy9JG5QAEV
zxQVLq6CnNL0zDy/xNxUBVuF4MzcgpxUBd/8lNQcroKi/LLMlNQiqFx5eble akUiSIFeflE6
FwBQSwcITy1s108AAABhAAAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAc AAAAVGVzdFNl
dFJlZ3Jlc3Npb24vcGx1Z2luLnhtbFWPMW/DIBCFd34FPWUFp+rSAewtUoZI kZLOlYUvFAVz
COwo/feB1E0bFniPj/c41V1Hzy+YsqOg4VWugWMwNLhgNXwcN+IdupapDo13 MeMf+lbQcsPU
ixCMK0PxOzn7NbVFNP8U46vtsGJCVDb62bpQTc4VXicMNYxHcmHSQMnKpUfi eCpnSigtBkz9
hMNn7M25twhtfV4TFmORP2tOTsOJCJ5c4/ucNWQ3Ro/ycN/2S9wTWNp2NKB/ sMUYqwHNvVY1
j2/XgZrfiW5QSwcIUjUKRMoAAABJAQAAUEsDBBQACAAIABEEGzsAAAAAAAAA AAAAAAAeAAAA
VGVzdFNldFJlZ3Jlc3Npb24vc2ltcGxlLmVjb3JlrVVNT+MwEL33V1jm3Lrt XlDUFLFskZCA
RXxIXN1kEqz6I7IdWv79ToLdtF1WlA29VMm8efP83iSZnW2UJK9gnTA6pZPR mBLQmcmFLlP6
9Hg5PKVn88EMMmMhWdzxbMVLIBslkm3TFJsGBH9IpV2CtZS+eF8ljK3X65FR 5cjYkj3fXNEI
cfuQ9Y8WMR2PJwi7fsheQPGh0M5zncEueatjrxcyKSoHLQGooiGZskUDo0Rz hWAnVCUDi3ZP
91cpLYzBqruzUIjN++Uc6zO4kNw5UQg8G0GViX+rkCGcvi1G1huTg2y7mr5z rY3nHv1wxJna
ZogoVTHKBS8tVwGHyBw8F9KRFbwFGa9c1ohecktZoGO7fHHEg7d15mvL5SVw /IcPFN5DARYa
z4JKjSpRcl1VYH+aWucpHU5oEEMIPLbdJ4zdIpCSzGiUpxVon1KcB1tJ/zde Cr06avw1Av85
Hv3YyeWrQbUn+ywn3YEOQ5J8iUHHmBrO/jmde2/FsvZdTg1t9COAfnHPmxvk qG1HExc4Gp/b
npkJfPxVQ3N0bPC7qowTvrvHPLcl+J5KTO1L01fJe8rfsUjtiM8WSXagw0UK SuIm7Qr7GxwM
jOADP7/vBRFFHbwJOof3HG1qbBtLv3TjCb8webuaH6aJ13tfqfngD1BLBwja ARuX8AEAAN4G
AABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAABwAAABUZXN0U2V0UmVncmVz c2lvbi9zaW1w
bGUuZW1mZY9NasMwEIX3gtxhUDZuCb2AEeQAaTZZli4mzliI6MdIcgiU3D0a ywqUrB4z7+mb
p71HR2nCgbo5GiXHEORuijSaex0+RDGvqAmScZOlXoi9duPXxaCO6LqSUfKM sQQHiynBd7iQ
hb+NAIAbWjiW+efzF3zR1Lftwfgrb23R1G/EY8VyqrN4JqskV3thGbNSMecI pxyN18CZBVoq
N+g2Y9SUwfghuBJ681OY40AQ5qzD4rfr3KarrpJV5Q4qTsmqr0ZMWxsxnAtu GxLq4/6f2fqs
wOXXT1BLBwhUO4ds1gAAAIABAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAA ACEAAABUZXN0
U2V0UmVncmVzc2lvbi9zaW1wbGUuZ2VubW9kZWzNlV1r2zAUhu/zK4x2PSsL DEaIU0rajEIb
QtPCbl35WBGVJXMk5+Pf71i287G4jPWiay4SK3rfcx69EvLkalfoaAPolDUJ +xYPWQRG2EwZ
mbDnp/nXH+xqOphIMIXNQI9/gnmoH6JdocYH34h8g4g+VM24Mc0lbO19OeZ8 u93GtpCxRcl/
PdyxVgLCIpyJQGhVOghCKHI+Gg5H/LaWnZbuQP5u7UhZFAw3CkF4i/uE8Sdw fgX+ESSCq1fA
HYqmS9AudSWVubtJ2IWyrbZIC6JfqaLUwCL6segBawcxHHiIJe7mYjguRVjy qdQIuIdNvZbv
de7ClntUcu3nCnTmEpan2gGbkmWSk1fJZkFTF9o2BSf8bKrWUkTLVLymElxU IuRqdyTNlCut
S180LNFuVAY4T9tUPFYkCEVbe8JOO33hAaVpMNOpc1Q/zITBn2LehN9YGtMc Ul9hoLIloKem
C2uoqVgrnSGYDkIgKWFW/3vG1RZIWBiNbx8hB7IJiPp6c0PfjvH/iaCVeT0g TPgxuX+KckG1
+pM8w2zOSz/ntfeoXip/wVnX5oaO8xtBGetVvj8U72vYZbmigz5bWyXAvS+z wKLo+ino+vks
PLby0p7wvHsX7+ks9O/iR66ppuDOVig+w44HGp+iBP9WvmHcXWj0KuIX76Lp 4DdQSwcIKo3s
SPgBAADHBgAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAfAAAAVGVzdFNl dFJlZ3Jlc3Np
b24vc2ltcGxlLmdtZmdlbs0aaW/bRvZ7fgWhAoEcbEUn3QKNI7lxfa0BOau1 lHS/FWPyiZoN
OcMOh7KFov+9bw4ew0NSHMXbILDJefc5b4Ye//yYxN4aREY5mwxej44HHrCA h5RFk8HHxdX3
Pw1+Pn0xjpJlBOzkGthlSCUX+ACC4IP3mNCTkv4N0r/w8B9yZdkJwiaDlZTp ie8/PDyMeBKN
uIj8/97eOGiZi/bwg8Z6c3z8GlGn82AFCfmeskwSFkCd0qjlEEMQ0zQDzQHB istbH9W95SHE
Ay/g6UbQaCUX8Cgng8EpchuHlESCJJqx561plpP45gLdcXxs7fE8QLtnRMjz mGTZB5LAZKBZ
Xtr1Ao9KSOaoL5M00DAe02DTpLrpxCp4BIRxRgMS9zM4b6OUGgSczQRf0xDE TFAuqNxMBlP+
UCCsSUxDIuneaJeM3McQTgZS5NAGX0DAdTJkLkZM1/CpxPp4cwUQ3pPgs8U6 1WiF8+9ytqAJ
aDstveetBCwng9HIx/9pnEeU+RjXMsYY35HI0YcJjBiXWoyfKPf4xesI80Ov fOeXa/6FETnw
rQoQQwJMLjYplKIxKU8kLkwGNvdvQRLNSaENSjyVF/+COAXRlRkGUgpaU3hI SNov5IpGuYBP
Bq0SstTL/8G0pEsKYU1S3R2hIA9vwtGVAFhykUzJpiYak0ISrKH5igsZ5DJb 8NOMJmkMY78L
ZqiyYsVmSnjFRUnWCbRB5QkytH6+NO5tRNVwqcfHrPimUgu9JU+nsIb4A65W iVHVqOoSbjQa
VaoIm0W6R5kqsu1V6nlFQql4XZEAK6DJoQapyLaXtyLbUt2ehy5NVwpYWtbF 4robq6aFACLh
nCdoX9iUX4fZQt1Rqt+sWJU+RTb01Or+1dpTr4WP3HLtKNgOSTeMWV6tskUn uzJMebcQfuEh
tt6X3z2evfNfvdK/vVfe+8hsshDaFV//TvN7DKQh9CqmHu5nwMLM6+gIdzxn WJ53EOAOGsXg
/aE5OT/elqL1S1u+Xfarl1TQNYK9vihb6Tkdmf6VjX7FpExxtJiSe4i9pdFc 2aAXzOs77zDK
GTdVDhoeVWa/bf6QK5qNMpDnXCDbC9SeqYkmGzJ46PJoBDwBKTajEnUYgbwl qWpew6PRxUzy
6Wz405GW+A9vC/DoyJhZqDClDH6loVwNXzcgv3CBe3WfSrdEYMlZnC55P25T 5quBhRmVT4sG
wzAvZTasw/88QNatOQ29poxmYnenmDfxmk78grwtLOnmrQKlZsvhy99zLt8p qHk6qqmlI0rC
cNjN4+jdy44S+LO9eJDyvec8BsK8ZPMxgynHLeOcYxZRhsAMXbUkcQYHkMYl 9h8IS3l5W1pH
jQqQuehRrtc5X6WfTiyMYofA4Rbd26r3ObSDeI8wP70HPrU/Y7V3pmd/lHo6 er9xtffarqs3
bhybQJ6WW+UY+y1pjhw7Z0l3eKjGYDVCqBHhCtsHavglLG/tyILjqMt5RePw kDzHftsP41i5
te6CahL+0ZmEe2dh9dSeh/eciNXTrql4n7lYPXXOxqi2GfBuAnWhUDsoavO3 T6DPNIN2zoUd
kyF6GA05yzIaMQg7pkNPlZgEYfzSV24uxX5HwS8oc8euKuO2m2ZzXDO4LWlc TVMiMhCTge+/
11k70++Z/17nvIqxdm42Oq5F2Ba65e8Gd69q9xk6w7Gpq4x8U0f2jOk7h0y7 GFP2uevA+c9d
B04c4D4/4cCpyHaVVt+ZTdG6Z7aSRAAXFH3dTXTnQv/PR73LMPrmR70iOk85 6vXczhymKDHW
G8w5NcwyHETUtdtj5564TUPlAmVhrSa/dgtV7L7JFqoL7MBbaJtnxnMRwBOZ Ktt9w8FhKvGs
BU+1XjM1HLZt9mNjjH1JSay2ihI9EjxP63GUVMaYB/++/x8mT+ZcMfA4Jph/ 7d0UI4jV72ZD
O6Vw5L1ExI3b3a08vTM6AOyggaCp1B8ETFPSp602JnLXDVdvEbbh+O+dXox7 Q81FxuidPqgq
6Pn8oKtkLz+0MZG7Wmz4QUe/3/6x76TEOMWkA5w3ApiRqGZLy45rYHOJvZ6I cObQ1PYq3OYW
kMk5yDuIsDmpC46R1WxkTh1x7RpUd7q5zm6vuFsvtdZFjUK2ta09dNqlFU40 QET1gaiu2lkn
7DNloQPzn1vnoDtRjdI9WWy0rgOfXe1UUNzEWNTWedYBMQqXkGfXVuQxTp1n LLwWNGyrfKfB
HsK9JoLR/M6h98vqc+tNf0f0rUz9YuYiy65wmfslzfIS8HtOBYQzTZGdti/3 xn4TZzdl57TR
yWhsZzj9DPr7rjZzzMiaRurDXvENSUXsrrC76jF6vd69qq9OPRSpPho5JP3c eveEQ7EvWm3t
Ews2WjPAmYnChZizqfrOmplN+kPhqGsFHkV0+QQVO/TYwxW1Qd/KWOgC4rn8 zQ4ZXWZ1gpp2
LTTSgYzrVXyfgDSMo+w3O5V12UZZwBMsNm9X7ArE6d80htvN7AQ1QzjXSH/D EO7ITwRHfJ8Y
FohbYzj2nVZWnG4/piFOZbbZpYLjgVBu5isoR3BJ7vedpAzxgty7YxRpjRcH YNrssjs5nueZ
5Ek/P/21vlrTlyNqyBDVmDxe0hh9tevwibyvNGJ9vlZY/ZtTeSWgDtZj3yBv JYblqLhgaeOX
l+ILDUDXSEGCqoupOxYcpV2scsQ2Vpb3Qkhtd8hmdtg/cSj+ssgy6Dn62Sys X4NZAv3VNqM4
FHyiZA5iTQP3gDJu3Jb1xxkHpBCWlOHerkVU8cyzHYcse0Onn6pzaFE7dbX1 iroBQMVvgeWF
PnbJ2XILA9DhW9SecoL9xzSzMz3SFnLrYk5fjP3eP0I7ffEXUEsHCARU3l5O CAAAyCYAAFBL
AwQUAAgACAARBBs7AAAAAAAAAAAAAAAAIQAAAFRlc3RTZXRSZWdyZXNzaW9u L3NpbXBsZS5n
bWZncmFwaJ1UwW7bMAy9+ysE3RelHbaDYafpMmwIkA5De+lVkRlbmCwZktKk fz9adlLJzRag
vol6j3wkn1zcHVtFXsA6aXRJb2ZzSkALU0ldl/T+abVe07tFVtTtrra8a/IV 1y/ckWMr8zPr
FlkZwQ9zaZfjXUkb77ucscPhMDNtPTO2Zs8P6wTmUtjhc0Ddzuc3CN08iQZa /klq57kWEDNP
YhI6CCU7ByEHAvo8X9nPHiYFV99hJ7X0KJcSzVsoqZNtp4AuMG+xk/Xeggsl yHiPDL5XPgAQ
UoETVnbe2BPsBPxlKvgREoxYRHPh91wN0TMc5TuZ+9cOSed5Ppq9rqB6BIFt 1mrs80p+rLA1
tgIbgS9mf+C2lvpbwEZs5ONcwbuET4g3XUm/0ElUwc5fCG+N96a9cGFl3QQC i/SyQXAUEY1U
lQV9rYcN34JKa7wNJlyO00kgHo5+gLzJKFi8l2hZApyLF0vIKYY6wA/4/5Qb /FNSxpajlWZz
tows0x/j2mx56h6fzqivYBHhqus2Uv/5uOt+G/WqpIaV0Rqd1z+Ld76LKvxL YcHGdsNB44DS
NxTGn6Uziuwc0hbirCEl9/Wn5KmmQvULeV808cyFytl0y1c2NxpkWFbBJn/D RfYXUEsHCLNB
mJ3ZAQAARwUAAFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAAHwAAAFRlc3RT ZXRSZWdyZXNz
aW9uL3NpbXBsZS5nbWZtYXCtVU2P2jAQvfMrUPZcDFSVqshkt6JUQoIeuj3s 1U0miVV/RLZ3
s/33HTvBJLRhUdWciD3vzbz3RoHev0oxfwFjuVabZLVYJnNQuS64qjbJp8ft fp/cZzNayVKy
Jj2ypsGb+avkaQStETSb44NUyqZ4t0lq55qUkLZtF1pWC20q8nTcj8rsuKx9 H6rWy+UKSw+P
eQ2SvePKOqZyGCIh1wZGWMgFbywEApClJ1mTnS8b4joNk8CqA34kshNpL7BO a/EW+AP5jlWf
oeSKOzQnyZCDKl2AzQIbzbVyjCsJyn0B5p4NhHP/1AbKTWK5bAQsgsg7Qo6I FSQwJKTn0K2C
YltzUWQ9mBZaIusRHNsJ8OSRdYL3KzKeCBEv2A8Qfbp2gMWUUverQbv7DeiH PgzqkywCaMFZ
ZZgM1wOaiyGQC6ua+s5PEWrPoyBJ2fWw0wRDFUQxOZRCRlrisY9vSpi/S7cG 22JmPsFkyr6+
GFs/NEyAc0Ae/IFdLOOPwSy9HX7MK4xnL2LEZJwxJXGHqODq52mbpmP/q10H hMYW/7aJoXvk
GJl6q6U3Grr6w9C4XTjDJFtn5kip1c8mB+/SpdDzyEFluvsGJRiIH5yrTpKO N7bx1vz/Jo6Z
ClzXhJIY/smLsTNbpl6YfcOb7v1sardDPt2r41wCbl26wBzBfci3LsNJd1RL yfivKJv9BlBL
BwglHkhuCQIAAMMGAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACAAAABU ZXN0U2V0UmVn
cmVzc2lvbi9zaW1wbGUuZ21mdG9vbM2Ty07DMBBF9/0Ky3vqtohNlKZCRUKR ykOUBVvXnaYG
v2S7pP17JiaURHSBukBkESmeM/eObzT5bK8VeQcfpDVTOh6OKAEj7Fqaakqv l/OypLNikFd6
E61V2TO+nqCSIfoD2WuZHVsn2Dog+KCgCRnWpnQbo8sYq+t6aHU1tL5iL3dl Dwt9rL5M1GQ0
GiO6WIotaH4hTYjcCOh2thP1ukEo6QIkCaw3MlesGfkGNtLIiIPSAjVyxxXE CEmOkCijgikN
UjsFj5+lxCHZeISWQ+sgs3hwCHcDufV25+gRauUeVq8gYvg+F1Yp7oJcNdXo d18eP1xO+cw9
8Gb+xo92yNbs3q6he7yGILx0Mf2a1AvEQE0SVxzBPGiuVCms6fSesscA+U7F UvMKKOsIKO4r
OFsgZ+nmbda9j/ODn1tjMHm8+h+Fv5Dm7TfhJ+7/h5+zdj1w79mpxS8GH1BL Bwi7B6V0WQEA
ADcEAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACAAAABUZXN0U2V0UmVn cmVzc2lvbi90
ZXN0U2NyaXB0LmVvbCtLLFJIyywqLnHOSSwuVrCyVXAFs/QSc3L0wBIamtZc CBV6BUWZeSU5
eRrqYDGFZJCglYI6qqLU4JKi0uSS0qLEHLfURCCdiqRRIy+/RCEltSizLDVF U6EYrlIhDaoU
0zjHnJyg1LTUotS8ZBST4KYAXatQBFeB1QC8TkIxCKeTuABQSwcIPJhKXYIA AAAuAQAAUEsD
BBQACAAIABEEGzsAAAAAAAAAAAAAAAAoAAAAVGVzdFNldFJlZ3Jlc3Npb24v dmFsaWRhdGlv
blNhbXBsZS5tb2RlbHWQTwuCMBiH736Kl/ee6x8dxBkWhlaeIvAmldNGbosZ 6cdvRUWkXnZ4
eXieH3PnjSjhznTFlaQ4socITJ5UxmVB0d8towjnnuXmSjmxylgJjeDOlx8/ eWOQlWPuFM+3
29UhpK5rW4nCVrogSRx9ECOhaB58SXhGMQ2TcnJab+IgmynOxCBcNdO9j54F 4ErTq37QdLe+
tFGQB8HMVATNcqbNeFb10pButsdp0LaQrmIP+y4u/ordNPTtNkWXfL/Vsx5Q SwcITMBwf8EA
AACKAQAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAeAAAAVGVzdFNldFJl Z3Jlc3Npb24v
c2ltcGxlLnRyYWNlrVNdT8IwFH3nVzR9GTy4DaLGNAxiUBIiqFFIfCN1u8yG rsW1fP1778rX
IEpMdA9bbnvuuR/nrNleZZIsIDdCq4jW/ZASULFOhEojOhp2L25ou1Vp2pzH wIbFe6ATkGSV
CbZPa2BaheCDZMowvIvoh7UzFgTL5dLXWerrPA3eBr0yzHEeASGWYmbAgdNs EjTC8DpwRWkL
E5sKS7vQOBpCFsLMuezdYQthWKfb08855OshrGxEqxIsGUNHcmPGDGKdA2P3 LiQRyYpRushn
/Qwsd8e+A20QQu1zfXjm8ZSn4CszeulhsjfR2iNcJQeM4hkUN4/I69Xc3aaB WCvLhcpA2UH3
0MerzeexnedcdoHjF457Kmdhe1vMpsFdArZ4fsaT2j50NjEK/LchnQ+2U54W 2WEKwYxXc+pt
9evzd5BHIpZlvCrJeCQkbgpo4FwQHGzgYinU9AdXXH7vitKOdSx75kGo5GlS RculoBgbrmfQ
R9LBHlbW8hdmQtJbU7Cco/xfyxXkuGjcUDM4/VlblS9QSwcIXOC0Ao4BAADn AwAAUEsDBBQA
CAAIABEEGzsAAAAAAAAAAAAAAAAvAAAAVGVzdFNldFJlZ3Jlc3Npb24vLnNl dHRpbmdzL3Np
bXBsZS5nbWZnZW4ucHJlZnNlyr0KwjAYRuE9VxFwL7EOxUIGEa/A7iGkb2Ig f3xJev1aO4nr
ec5peXV+646PExdiFtN8Gfn98Vz4KMSVwQRfKoZCsCAkgzpsoOpzkmfmkEC6 QZEp0upQwbxL
maBctB9Umw5+1W2/fzjqEvOK8D/0+lW1s2zUj0I9NR+hrHedUA94A1BLBwg1 EaJ2gwAAALsA
AABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACYAAABUZXN0U2V0UmVncmVz c2lvbi9NRVRB
LUlORi9NQU5JRkVTVC5NRk2Qu27DMAxFd3+Flm610ATooiBDW3gpmsKIi+6K zLhE9XAp2Yjz
9ZX8iLMIJA5576UO0uIZfMi/gTw6K9iGP2Wvna015IcZ3th2IZ/SgGAPre4a tKlZQDWYk9Oo
poGvuFxBOEJD4JPEzqNtNIQotg/U3dbu3Vf/Ny29L2X4EYyvk7Z2lLzJ9VgD 3bt/OCU1XmUY
taZ0CzvCX4cEdXEB1aWBwvZIzhqwQbD3bVXkG/6cFZfWUchLqX5lE0/waFoN j9lc8PSuXRTS
2aycT0aCOWo4KI2tB64cAafOBjRJ5B6BOcc68l2PHk+oMQxiTwBjgiX2iwrY jweV6V8HwbS8
Dtk/UEsHCKBxPi0BAQAAuAEAAFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAA JgAAAFRlc3RT
ZXRSZWdyZXNzaW9uL3NyYy9zaW1wbGUvTGluay5qYXZhzVVbT9swFH5uf8VZ QQpUS/K+pRV7
2EOlaUyD98lNToOHa0e2A0OI/77jG6SlpQJt017quPa5fZeknE7HMIWqVt2d 5u2VnfttubF3
fx0vmmNay3HH6mvWIhi+7gR+HI9pVdqC0m2BteCdwQLXK3pWGovP58ufWFu6 VsZK7/Iclthy
mfcGdd6oGvLcV/0EGjuNBqVllisJagX2CmGtGhSgfCLIKlzPq+X8C5fXVbmc VyXts+IxNcpm
O7E/63yJS0q3UkKoWy5bWCGzPRUEpmmevnNzYPPB3++FDwCoBJ/fnwkqF0cu XOmjFu2F6nWN
4BoKj76Xh6qkiEOxl0zTr48Nj1uxVRkbqMouzXBmMMFeXPjlW+DCJXSJT079 tYAXk1IFHGeT
lvgIXfg+Z1lYM7C+9iwLazbx8S1K1IyQCHz3S8Fr4NKiXjGa11UC/GUJaQOR X7gfjxzBI4r/
jgSqNJ66GyZ6TDwm6hJYiTyifYUaZY2FT7CwwA0secM1paYBmJumAW4NKCLJ cIvuRrYJ7Vca
2yFx3ttWOXpdubQJ8GahwD4NjqJQfBNRe8ikyzUcYUD2oHfqSGYWaoFMv/cp KIB0pZEJcQfm
SvWioaokZ+0hYdCgqTXvvNbd3aKI/ZWxid2Kdidn2qO8B+TdHYbkXkVHJsn3 xMF2+nTykr5+
xJDn17exDxeicSNls4mKp5Nw/KSzkRPayCWBR1+dnNJL41FUF2h3KepVxnwG xYs62A99xzRb
x0ZcFxJv38TBYNTdgNwo3sAmU6HQBjQH/ZZeMH/JbwtZq3XyW9r8Sb8NXpD/ qd92d7jlt3Dp
VX6LIfv9luDe7TceTw/4LVV5s9/2fMz+rd8OczAY9WW/DZh68tsDlKX/9o1/ A1BLBwh6Dagx
lQIAADQJAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACcAAABUZXN0U2V0 UmVncmVzc2lv
bi9zcmMvc2ltcGxlL01vZGVsLmphdmHVVE1v1DAQPSe/Ylgqbbsi9h2y0XLo oVL5EHBHTjLJ
mjp25DjAqup/ZzzJsm3F0pWAAyd/zbx5nvdsuVqlsIK8cv3O63YbCl7KB+u4 dXZVn9Eo015V
N6pFGHTXG3yVpjQ6H8D5VmBldD+gwK4Rles6Z8UYtBGX13oIx0Oxch7F5bvy C1YxTM6knmUZ
lNhqm40D+qx2FWQZE3wNHnuPA9qggnYWXANhi9C5Gg04BoJljl2Rl8WbuJnL ssglbSzFT2y0
9WNkPuu5xifCa5wx7pu2LTSowkgVQXm6+9jHi2D9kuNHwwkAudHF7cZoezO3 R3Dt5y2GtzQZ
IDLiGVO5yyUlPJl6TZtTKs8epeZyLp/Lfn+DzYB7gcRHHt5PqkU4xj2/4Lip X8paN/VxvWhJ
j1qr1quObu/Wy1L55YKDW7ToFd168sFYGl2BtgF9oyoExgX8HqitA8xqwm2a RDkTAviA1EE7
sFBflRlxr9peqLkze6GgciSvth2pTHo36NFSHUNeEgwYFYorDqSgSZwIuusR HnYzYt9Nacd8
lczax/Fq9hMqG9W/T/Sg3+8Ygh7skpgZVP4FQxIAsfOojNnBsHWjqYkFWXbi rIBgK6979nOM
FWLmK2dSvzZtPNl47u2R1p7GeCr2tHU+MxwZKDk46B7qehH8iIvp9GCZJHom 4Y8gjwAF7B/F
+QU9+dNNMr+Bf2KSiP13THJ4qf+LSU5jfLJJGO5PTBIB2CQzEpnkDqScvpn0 B1BLBwg0SRgm
MwIAALgGAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACYAAABUZXN0U2V0 UmVncmVzc2lv
bi9zcmMvc2ltcGxlL05vZGUuamF2Yc1VTW/bMAw9J7+CSwskLRb7vrlBd+gh QNEOy+6DbDOu
VlkyZLldUfS/j6Js52NJmg499GJJFvlE8j1K8fn5EM4hyUz1ZGVx52a8jDfW /tfpPD+lMR5W
IrsXBUIty0rh1+GQRmMdGFtEmClZ1RhhuYwyU5ZGR42TKrq6lrXbb4qZsRhd 3aa/MfNmcRvU
p+kUUiyknjY12mluMphOOcBvYLGyWKN2wkmjwSzB3SGUJkcFhoFgnGA5S9LZ Df1M4nSWxLQe
Rz006nwbmPcqPuInwS2NUuZR6gKWKFxDB4KwlHpT+Tww/8L2jWIHgETJ2fOl kvq+rU7kjz4p
0N2IEsGH4yccx0sSk/VrfnNNZfTne99u8Qb/28YVpvPvFlv+SdwmkMRVV4PL GjuGowUP3wPt
nAyBT87YLNRbaG0CDxejgvjU9BeUSFFdjDUlPB6xcYEaraCyBR01qZIZSO3Q LkWG4GEB/zii
pYZWDPA8HHg1DMj/BxIDumaeH4RqsCO955lr2/EMwjkr08ZhxO771DRoKffj vFURCu2Lto7f
E7cGDLLWYweZQmE/MwCZkz4sCqWeoL4zjcrpTJKl5WgF5FhnVlasWW8bRW10 cRvCbmX6nUvL
BdiT/674AjRzeVIHEU4WtKeLs9XOIZZ/sUtrzFyH6YrJgadyEEChFfrkjHq4 p22BbhdnR/fJ
24jcX71KWFG2QfgIND7+Rxn7FHcX4sHIHDZLHQ7ZKMmrSl51eq9mi0uSi6Y+ UXSXhpD8FeVX
kBnqIu3C7eSxniqEzQpf0/wluM0dCRdSmUtLLUZKFL6Fc5AEYOhmqyVLe5sj j+Dz/yksfZml
MG15epc227jjtrP+SP12MNDoyPbqQCb/9uNmtdc6sKfoYuR4b7RbivzmJh5m BmsvyeRtSly9
GR9QiQvT2CzcF2H6nkrceC0/shIPBnqsEjuQA0oMJd6txJr3jlPi6ihS4gvE Mb/8w79QSwcI
wE67T9oCAACKCgAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAvAAAAVGVz dFNldFJlZ3Jl
c3Npb24vc3JjL3NpbXBsZS9TaW1wbGVGYWN0b3J5LmphdmG9lOFKwzAQxz+3 T3HCYDpo+wDW
ociEgQ5xe4E0vXZxXVKSTB3iu3tJM6Gb+zCUfWkul7v873dpko1GMYwg56rd alEv7dhPs97c
uQbTckBjFreMr1iNYMS6bfA6jmlU2oLSdYq8Ea3BFNcV2UpjOnlg3Cq9pbgs SF0kCRRYC5ls
DOqkVBySxMsulgh5MQ4peVaMoVIaLLnXqsQmdUFTC61Wb6JEAwy4RmZpGe1S lT4aGV+CVDJh
hbGatgLeMGNAVXsb+UJQlgdl3Brc4aVzPzx3zH6xRomaNMuuG5uiERyEtKgr xhG6hIAA+GFJ
wcCuDfAZR64PUaA1QtYNWiVpB2OZpA1CnVWXkPrQYz2LjmJE/VIjV2u0V9t0 Nl/cze4ncLOj
dd+0FzV1HiGFvbyiI/yp/QXtRkt3ABLfQRWvSH2myrtWD3Ncj59co/OMrOGf ILSXOknpANxH
hH/F2yfTzCjrLDD7QgcsLiCgOPNkkkchV2ch2Rc6IHEBgcSZv5O4u/Dz5Gxa 99RgCcWWFoT5
l1sSSE4QOnKxwisBNdqew4N9QZb1blb8DVBLBwi0WOPOpgEAAHsFAABQSwME FAAIAAgAEQQb
OwAAAAAAAAAAAAAAAC8AAABUZXN0U2V0UmVncmVzc2lvbi9zcmMvc2ltcGxl L1NpbXBsZVBh
Y2thZ2UuamF2Yc1ZW2/iOBR+hl/h7Y7UmWohe3kcpirq0AptCyMu0r6hEA40 25Ag20hbVf3v
60scx7mShqTzAiQ29nc+n+/knBzr6qqLrtDACQ4v2N090WtxaRnX/Nan8eYT +7a6B9t5tneA
iLs/ePC122XfAaYowLs+OJ57INCH/Zb9DjD0R0NKsbs+UjazeOKtZxNSNumH 3Lxs2gy2gMF3
ODwrtPCXXg+tYef6vSMB3NsEDur1hLWLJ0CD9XW49sBaX6NtgBFlt/fBBrw+ nzSmyAl8ars+
QbbjACEBJnoeUBsF63/BoQTRAGE4YCDgU7H10RP7IDTw3GuwnSfkcGN/G1js OjGyBZseMaBg
i0pmgn/cJwdsfyP/trEZIPpygGjCwAphCCbA36R4uCGgjrU/F193tkMD/CIG BRXo2fU33y5C
H7gQAzvwAdsUNtI9jmvPdZDrU8Bb2wEkVwrJRfAfZVsTpE4SvXY7/IQ64Tko 7/LtPfTF3byD
6+Sa0jFRdTiszpy5ob9DMBk+jtA3dCHtvGAOkrs/OXD8y9m4GSDzFVuaQ9kG wQk4mmNkvvox
G92N/8nDQtg0D2jgs1Ml1Gay4t5JNcrzwjL9ZTyZL4aTW35moWvyz74xa8zv uL5LP39JYo8J
E7mbSK+Xrzee6z8bSz5yB+dLoQHsr8XVwGK/3i6lCGtZGZOWuVn2cMq8X3dA xX8+f8mmjQkO
PU6/jx4YUb8nWVBBJc4AN5JFvQlblPCYJ2y9VEFuz2IXi2JhGEWeS+j5Thnd BHjDVk5hX60m
7Gte0YQHdpI/kQkP48nf3IQ/kiaweL0GzLVDKD46zBzbU3YRJalL0/nO4Xsn Ar8bDRfL2Wh1
O11OFgz/nzW0xL0qkhK/aE5JaqsKQuJ/KdIRd8KsAyySEYvOMRe0VdbT7MFx oEwz8pFWRTJj
3wn2LKzHILepFIl7PLmdPo4n9xWpnh7pLvho7NPl4n4qsad0crrOI2W0InOB PKnyvxj6d8uc
R95I5vyiOZmrrSrInP+lSOY8UGedX4HvzYMjdiDL85o9Og51tZpPl7PbqlJf 2Jhx8VGQF8PZ
/WhR72kYOVYrKhG4s56FGv4MGEhWByYqP0G9QJgUi3iep9LKWnZggaEIQiKR 6KeUIwaz5SGr
caSTzq8nms/v5edfmbyoJzKJkgXSMEFlIE0cecxFuFWM4RNK83T9biJidxWu 0jDHIk2OIvXP
wLHGUcSxmFWb43CVUznOlDE/p2RG24KIdZaQZomPlUlYprtVvCtKX7MYEH7P 0l3JhMh7G/ek
GCBj1xxGFMSk1xQl/vpNpeJsJZeoQlyxFBU0lX0LBnUq3jiLWRo0ti+gU82r RKmhQ0GpXub8
tKrCQNCqq4QPodXYvoBWNa8mrXqZWgGOB8lkLt9CgNMJXpooPlYW4GSi/z6H ymCA8y8TfcGF
yvlb9KPLxL45vGigSfcpKn1M9+EzV2qRs1IoCw9BoapB2qYwtm8BhXJWTQrV InkUbmUrhf22
KXIwq3NADqh36lHNE/aczkPSu7bNeScfdoO4ycYN0+gizN9h6/psS8+lbH0v r3/GseoOmliU
9674j5weWmKoqImWmBrroumRvDaagGIpLBWaGrod9qBMf+12JGdZ711Cgur2 KwrPo8CEzHcs
sZbF6e9gojw9SYvkRQVx1bmI2j19s/SswFTlvobylrp8ZRinw0SivZG2M14E Vrf29BZIm9aq
TkiGtbFyrJ4KSjsNZ9WAbjacLgGVyhUrIOw5GFTpwu0d/p/TkGjw/HUBZfQl UibF6qrqdpV2
Llpx8FQDI22kWelUN7S0zdGiobFuR9pQs/aop+bShsJZ1ax7CqerWaWFxWoO WwsGWbpKqe4M
+X2HVrwg0X5ImWUUENWty29RtGhd1KlIWxfP7d+63TdkWYZvdP8HUEsHCDyY jBuZBQAARicA
AFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAALwAAAFRlc3RTZXRSZWdyZXNz aW9uL3NyYy9z
aW1wbGUvaW1wbC9MaW5rSW1wbC5qYXZh1Vldb9pKEH2GXzHRrRoTgf3ekChR iiJ0c6EKpK+R
sQfwrfFyd03aqMp/7355vTZ2MREhvQ/B2Ls7e2bOmZnF8c7O2nAG/YCsn2m0 WKaX8tYr3ItH
H4bhB3712ms/+OYvEFi0Wsfois/zdptfCE2B0IWLQRytGbq4mrsBWa1I4iYk jebP7khcosBP
I5K8Zs3N0o/4wpp1GBCK7uAm9hnbMWmYpEgTPx6MZ/9ikNZjUdOFj+7ARjKU XjdYpDYYFoKk
I3cXJd/OS89GJMTys4m8fFFh51Y8TdlJrwczXERJb8OQ9kISQK8n6btOQK5Z YZJKuEDmkC4R
Vtx8DERigtM+ri77s0uBo+/NLvsevz91jW1Mwi3L/bW8TLmtOYlj8j1KFjBH P91QZOBTzDfG
8JNcsYnlEoB+HF3+vIr5brZ2ZBhEfP5aYDohGxogCGDqq8T00vf40sZGpj7l n9KI+loy0vc0
pL63ztR9tcAEqc9BK41vZnEUQCCkBJltwB8pjwkDi9TcXTUPfrZbgp+WDlLg B0sM4cmPN5iR
cKrx5w47nS2XT4HiHCkmAbrSWh3drVq6xMgVQyxspJ7m3spbQkO+lbzx2q01 JSl3j8MWagQm
V3Ld7eWYirx2zKbh0I5lG+3vWCpX2o69Ekph08I+mXR4HLgwWmyzRup0ztut l8PvejV+Qkqj
EG0AqhoCTkQdCOSNxkKR52wCheLC04jXRT9m7t1w9PfbwNSpJRmwE0Bgiubg KLnByQUkmziG
jx+1AF0csi+U/Hh2Ompyq1TEgcShrh8X4JQGO5mK+TpmJgkQHbxHRuInVMaN kY6cW0SUDyoE
chjtvnCP/20irjgOUk5oqdFnJ8HvsNVBnHQZsS7Yj937wWR893XQLTPDCXl8 nIwf7m/4mAHS
1dHpKLgvbfWnyTVOvzGPM59FwW2JzGNiKB0RFKCJASRBcgaymG0vWLEFU7Dl XFtKuXKMcIyp
8/bvNaBkssU7JNYDZa+ZOCaDaWNhGJC5koWXcKEyqwPqroDlHDBmKEdcPwwd e0yascQlJr0p
rU8kCoHVkJgXDPNIZCiz07OaZlD+V6S3DItMWz3PqSkjHV6MEl5tGa8dK/KE mqoiMaPx58Hj
4/hhejsejm67MlNceaLoKrkZBAUPGoDIg2BwXHOyXg9C71TKGithinjl9BNb Rm4YsbWfBkvH
qEQKaVd93Ls67kwAC3QepjfquKVWZo48mTLVAcNuZepJo1amT7EVrSw7t/B1 qZlU3cqUkZy5
HFE++E6tbHp9fyvINEC6OjrVrcw4faRWViDzmBjqWpkGlFXBLGZNWpmRUq4c Ixxj6o9pZRXC
MCD/762sksRCK5uaDE3t9GzWyooFZ0cX0fabt7Lh6Gb8z+5WNt0HRB6Ehq1s F4hSK9MBtxLm
z29lWQJYoPMwHeHHY10lsgnaalj89z8dJGEXoiTNXggNP/++PrHvEY8zOGa6 Fnvg83jXN/lP
pl9VHd2OeHbLykfp3KR6cR6RfEGtY4ry3LGqRD5iJpcd01lU65j9k1O84ijk cj7fkkW29J2l
rCP1/mquVpIgf2/9VHNXMlXLmI7I+5OmqUB+FnNKLMwIidFPgKrTbv5AvHef Pq/xQOVF2++A
jpT1umo7TW5Lg41zvWKX7PBZuYs9uE2jCJcVKhMiE5pj8SePPDjZZk8Ty1va V/Hy+ABcsVLp
Nabt+DUnhZUKXq25l+yVriv9tHy0lxwx2g8JK8f7LcIrWtKBQltlygqrcihH faxwZgWF/1Df
UvDhqn3x+LJ3hS8eEmqqOptUBPAFPC/710T7F1BLBwh4zWtWSgUAAAIeAABQ SwMEFAAIAAgA
EQQbOwAAAAAAAAAAAAAAADAAAABUZXN0U2V0UmVncmVzc2lvbi9zcmMvc2lt cGxlL2ltcGwv
TW9kZWxJbXBsLmphdmG9V9tu2zgQfba/YtItGjmIpfdadVOkxsLYNFms2+5j QVNjhw1FCqTk
bFDk35ekaN18SRrYeZGiMedyzhkOmejsrA9nEFOZPSi2vM3H7jNqfVvT22ny 1ryjfkboHVki
aJZmHEP7HPX75iVVDj/JioRFznh4KTlHmjMp6l+lWoZIOcs0hpguQirTVIpQ yJwtHsJr+2KU
WJ/LW8KednSJJldM57uXIpUKw8klJ1qP9i+aihyVIHxyM/9pSn8qpkUe+rXT Fgvb15fVlusv
pcgNwhRF7ut/2rUqrw3Y63DFxN2oY/siE+Rd47Uxdm0z9/q7VNaEjnxXnAyH MMclE8NCoxom
ksJw6DrkkwDnYxE4xUAuIL9FSG1OkA4lnMaYjuP52BUSR/NxHBnDaVgFR5Fs hI4z9/pqgi1M
E8l7JpawQJIXCjUQhXVmTN47j4I7F4CYs/GvC264aPZnSYTV6I8l5pYADbYy 95cr6TGOjOfz
Y1i2yxjur06MOPIFxVG23j8XSxSoiCm53EXFnDMK1LYlVKEB/8sNJRoabVWj 9QvhV79nBep5
kiiht5jAivAC1yqcegAV3mDQRXwKtG5CULhAhYIicNNdoQu+S/7eTvXsLxca sZm3NNbo3adU
iUnnPqJ+L1MyN2gNCNfbsfUcg7D+phl/C6yTw4NtSHN0sD7vC8BazzFYAC2w L6ynlbqVrWoy
w47poJ4uMlTBYNTvPR4+7cXNCpViCbbwuiEMOLMTg7oPX4tCs7kFtMaQmWhm 3hGuwy83nydX
x6nTb8Nm2zV2jC2NLSBwnQgfPoAoOC/NPW8DgfewY6iXAQP7DN1GPzftysyz jdPB+/Hj2rxm
Vg6Ds2LE74GjQy+bsLF/1tBdX3age9te6C5gYJ/PgH41vf5rA7rfEcfuzpKF jbsH4FSYRRr/
wVSuMOjcDUCawaMmIjkHZgaKP52mn8+3REr1Uvstd89yegtBtdwTSonGPU3x 3q5Z0xIErXtA
/HE8qDt2EM6JZtTXXNfoShjtT+VEeEYq3yFPpmpI6UZN2GG0dmmwt/Z+FdG9 lPgn5kFHxbmU
HIkwJ4WWfIW1wV7Hvj5keDhBa/V+W6Baje2EW2ANUBWYCsSRmJ4VWWaS6X+J EubypoM3hTDH
Nr3D5M1gmxIryRJzLmzq4CUyk+a7PfEPwHpNtxlMSJSnvWknSfKJ8yCo/4WJ P1Y3MzfTB1VB
o4Yez9evFm6jiLV9bxFuuu4u4nF9vIeO0wafTZdX2WOlst+E7mp7RCkPpcZW Qksodb2vReR6
AOFUb+yTww2j8lZzUh738O4dnDhLyPQkzfKHF8yo8rLQjOgs7Yhbzgo920Lz I0RRdY/t/w9Q
SwcIBtcjzfMDAAC8EAAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAvAAAA VGVzdFNldFJl
Z3Jlc3Npb24vc3JjL3NpbXBsZS9pbXBsL05vZGVJbXBsLmphdmHVWFtz2jgU foZfcZLtFNMh
5j1xSbKpN8NsCp1Ato8ZYx9ArbG8lpw008l/X0mWsGUgFwpt9wWjy7l939HR pfvuXRPegRfS
9CEjsznvqWbXasuuN/3ojfh2m2kQfg1mCIws0hhd+XvSbIoPzTh8Ce4CN+ck di9oHGPICU3K
UZrNXAxjkjJ0cTF1Q7pY0MRNKCfTB3cgPyQMtpW5mAdECD4tp3zzrwjjm01g SDN0/Ys4YOy5
Wf2EY5YEsT+cfBHhbjRfzJZguX7V6b6C7wVChf6+hfb6+UWIxfzPhM/7yR1m DK+R0fiOJDMd
/fM6lrFZApr3K5J8fYkS7Ujdek3bgEZYtzBSn09FugmJrk7Vg6MjmOCMJEc5 w+wooiEcHam0
PU9AySww4QpdoFPgc4SFUB8DVZ5Ay8NFz5v0pE2vO+l5XdFuuUvdmEQrmr1U fcZC11QkNr0X
kcAUA55nyCDIsDSM0bGSyGMlAuDFpPf9LBZ4VdeMClnS+ccM+SBYIEi35B/l z6PXFWIvVtBP
RH5Ln6QS09hG0TDnM2oUmUZNkdfVsXnd1JSHsxkmmAUi+qJI5JOYhBDKJQRG P+A3LsBlUEnm
ErdiHnxvNiTRDY12hNMgjzncBXGOhs6WDsJA57Rr4LUg4Dwjk5yjq1RtSprG RtLlyBlDrBgp
+spAVZNmEWZFo9tspBnlIjKMgMkMDGFKxAKCkXBGYDo4/+jf+h/8v85vrsbw HpI8lqvZCjgM
wrkQ/9/Fq0NMZCa/tyN9bYgmf3WYdjq3IMOp8CAJEWJRSnYSb2nxVTGrWubJ StgDolW8Nliz
xnSw9pLbS7Clxa2DpVpFNdgtvbKsWwZN2RDIiKLQYHmKmdM+aTYed2/1bCj2 yIxEaEWsTgCA
I7WUVUP7kqEo/AlYO5TYEcV2GcTMHQw/+PtxU5dVvdbKalDxSS7AvRq/o0RU N23arHq8l83C
Ed1H42hQFAPtUkPXBj1Z9pApOFg9Dl3jvzkR2ee0RXI2GsXYgyNEYOXY5PA5 YR2odrsjf9yp
0SLZuL2VBaljfOool9p7yiWNU3W92EXtu47clAx4X2wFxUij7AYV9zMnucKE I39dtd92oABm
HQz9wcXwY39wWR+96g/+vr0dn19f+mMJi8BlmVFlZft5aFWqokHL1JwaWmX3 7tEa3owvhxvR
Gg1vri/8OlpladxLnRrlaSqOnOxzkCXCCnMO80RsMOFXjA7bdh0rgF25IQFq YM6jyKldX4CK
7Snzk6gjWOfmgNv/0FmjZsFmTFfme8LDOTjL6ZqaMGD4ZBYey1kGOMex7hte zbVeuzZ+2mtb
y6rtTgJGQhlVGYVy8uRJZwzJO3CmzNqnnamki9rV3Col5fwK/EZ0z1vfcylz jQt6h79z1mzI
Cu347hNjA/Gb7W3kfkXkV9GvScVL5E6NzwmlMQaJOJXKmoplh7zvjx9S3JJa uTtbMC+PNk9T
tDYlLP63oNjicz1lEpoKLEs4ljD8LtVfHdZwtMqkJllsmf/Im8kP82YOhPpE 2F4qPqlA+xoy
LRbFVo1BptmsDQVRdB7HjlM+OHqny5cGtdtv44ydGVZKrDhTGfoRZx7NJcdV hFXIqor8lBJQ
pM1NwuqJs7M8sR4I9pEkOyV5LUkFPCUGP4scU3Oxz1YW9q7qb+2lqjhxw2nx vHOgm8dwYM1z
xeVN3H8ddbnaonAvLz7GwNu3cGA6XcL8Rcoftirpy0tCVbPptDWv2Z/Z6Jfw rO/RnBZ/Klch
4dKnjH4THrfB8rWcK19m9E38z3w6xUxuUvIhtbgmVUecuqzCoZjuBmkq/HcO QbF6DIdrBpd8
292tdkv3Kg/1YNVFieMjdLvmpaf5H1BLBwj0pESgbAUAAI4aAABQSwMEFAAI AAgAEQQbOwAA
AAAAAAAAAAAAADgAAABUZXN0U2V0UmVncmVzc2lvbi9zcmMvc2ltcGxlL2lt cGwvU2ltcGxl
RmFjdG9yeUltcGwuamF2YbVV207jMBB9Tr5iqJBIu2ryTgGBoCtVCwUt/IDr TFIvrhM5Dhet
+Pf1LW3dFLEP9AHijOdyzszJNBuNYhjBGa3qd8nKpbqwr1nwbkzHs/xYP7O4 JvSZlAgNW9Uc
U/N/Esf6UUkFlSxTpJzVDaa4KvS5kphOrzlpmskXTveLP0jVV14PrvxXJQ2s dPqTUFXJ99l/
YKx5WzKRTs3Lgz1vIjzVkbZkvl9H4zEsUHuN2wblOK8ojMe2d1cCrPsKhSKK VQKqAtQSYVXl
yOFsceFRnWWLi3SdDEXeS3VZokBJFOau8+2CMwrUNBMebZEtgoBvSidpYJv1 BspOBPyNI8Ml
0mWuJeoajQWZY0FarqDwbiGV1Pp/Rj76lEsUkokMm8jTaUxquoOOCaaSoQEZ KQc2ikIPDTY0
nEMSGIadVNLfGmqj06Sz+ePT1fx6mpaoui4lg6KqBsMJmBKsgKSX+OgcRMu5 QxNFElUrRa/+
xFx+xO6PEkWXkEzfKNZWAtidfJYtmW1Q8apMNo4Tn8vXE/jan3livD7i/iiJ FqHQnRUUO/n5
iR5ihHtwWZpNW6PsYfym2pf3Lygly3ENw28QoLYJids6gPbhAb0yOxhnMzKw B1YwlLObZOin
Q0mDnlSnobv7m+ntKfhhuAp35oO29PaGzHXITsRcR3wecDub/9oJuGXi2Qf4 L/PUilAtZfVq
NTHjHEvCr2TZms90Lblk8KSH7nbFyQB+wIbznKw0Cm0anABrQFQKCLwQznLn b9sx6AR4gNH5
edn+hb20/bdnu73cyjy3RNdW1w/fJutxGIF5lGZmwfgsRnO0EIW5dgg7WwDQ 3B8Un5FIoBaL
zxwtPm6uHb7OFuAz9wfFF2gctPwCg4frwSTB3dCs6bXf94DMsZZIO5R7tsrN lsO+X6gtInsp
hJ80dsvdof+ALOsty/gfUEsHCMuceQq9AgAAhAkAAFBLAwQUAAgACAARBBs7 AAAAAAAAAAAA
AAAAOAAAAFRlc3RTZXRSZWdyZXNzaW9uL3NyYy9zaW1wbGUvaW1wbC9TaW1w bGVQYWNrYWdl
SW1wbC5qYXZhzVptb9s2EP7s/IqbO2B24dhtPzZpNs9RM2GJ3FlOMWAYDFqi bS2yaEhyWrfI
f98dSb1QtpxsiYN8aUTqeHzu+Nzpjm7v9esjeA2nnlht4mC+SM/ksGeMaepH 2/8R//aOVsy7
YXMOSbBchbxL/54cHeEfEacg4nmXe2GwSniXL2f4LGLetfppGgfTdcpP7hEc hCxJ7hP6pBDc
JzbiMx7zyOP3wSMTcq22YY828jKIbk4qc1fC52F10sHJ6pwr/3xkXirize6X uUVHPX0ePxwf
w5TPg+h4nfD42BceHB/Ls+lHINcseZSyNBARiBmkCw5LAgSn0zOt7bQ3Pevm ynjkb6n6Zc4j
HrOU++pk19Mw8MCjMwADGDkF+NcUlSRQ9lQBpbICvh81yJbGHmMatdgaJrgG oWus4uAWh6BI
oszVzx8gWod0bAfeM8I9n3nLEKlXu+Ug5iiaAENOREnKkOz72NCBGOElKYaF D1+CdCGVfP+F
9rgn2LojuTLewNbMHUw3ckudGaTSLEtcj2y4ZeGad5UfVmeOSPl7KY8bxNxL 4QvD9QI8aUxZ
EwQJ3AZMTiVEdk8qmalQgiVPF8LP8L8KoiAF+qfVvuvAl0XgLYCFiYAVj2ci XiZyMQkELAy+
GbGjN+ygF9BH6TqOEjlf8lcmorTMQEQc1SNmf4OhgVJJ9zE0SDh/6BEUC3Yl kVfccSfo9kLq
lXLKfrptxXurTTHcSNbovpbW2QEjmXW57bjjvjOw2idHjbvDxYI6fJgKEXLi emKjRXgmH5AL
YcJ3hERBdXxkkV+cO1cna0YGIEFwOtBpRS2hORZtQKB8nMB6hXxRtEKi+XxF 2VCdecbtsdSg
aIlPaKBPzC72zshaObHMjXeon0cIhKUwC3gotTDP4wlqUlsNwkBm22Qh1vg+ EsT5W3HDJaiA
AircdMHGdIDU7JCtm0xY0mWjFZZ3QYximrIgKgfDo+m8g4kqxrXdAxGlZEtG zZyrylc1Ulsc
UV8tTRHzI6SIL3mMEdvKeNPWMQ4tQ7y9FWnd7GC6c55mb81FXW1km0jY6PVg qByJ3NEJjaiU
kbHIkY3tDyz63oT/oQKQpNqt/SizUG3nXwRMcdt7/bydx2vUvIeIf9mVHpTF pVhM4zXPvKDC
ME/kGBPs2GcpQ579gxTFXNyomtutIUem0i6iSEn6hdpd6vYwKVN5xeKbEjYZ qn7gEXKMJo9F
P6XIffAWLJoT4bY3mcWcf+NSI4BSer3ys+9YnH00FQck54wvZWPPKazW6W6q dbaYQum3Ueiv
FJUHycwq6nRlgoSR5bCONY2kVKEdFkRe6edAJlSIJyacViHXLkGToe0idz2U YuFHZNY6prUy
DN4c6stWD52ajaeA/vbA0POjJ1+beIs6+bAQ8r4ygzFx2JJXfZdLtQtcL+jU JW478sQyiOb1
5/5Q7Ic+9m3sw3U6F0+C/d1zUZZizIRb9FnP6D6CMXHFOva2SFs4r0D2gkgr kY9ZTBs/GvmB
KWv0LATemKjAN961CbZ+tnU51Tpwr1M0OQNd5dR3OarTp/pFtfu6uNLdTFHJ A5ididQxX7PY
Vw3Kgt1yTNrAZjNqyLHPob6H+gpPtcmYPbEiQsVBnKSPagxqzuhWBD7UFICl +l27JCvgT2QB
WvhpRwUqb7PkFYlPLglimGnyoZh5h6S2V8PW1fDcupR1lZ7Oad0qreqAlJtM HPzjPlz80nZ+
d1UZatwpGRBIZ1ll/h1rFWs6QFK4f//K2r39tqztDIZXtnPxUPnh9fhiqORx gXEhZeAlo3br
LNZ0gKQmE3d4PRrUIN6WHvdHF9b42QKv6DR2B5+gFKFL/L33SermIU1KMapj USoqbgpeXizu
6Z4q/bT2lBmTpgvLcVlq44o2KMFSgio3nvOYZpJPMZ8FX2Uv+mlkfbT/LF5h H9Sqtt465NPN
inTHqJDuf/RLl2MvJ9Z0gy3T406hvu+DvPGi14m8lVT5Y0cPWkosWUo5AYYK xIq8ikelXpY2
Qc+gAh0uZl6Q3PDUoClHzQ78YLuT/q/ueNQfjNXIdsbW6GN/YHUARxeWY436 Y+t8knWNk8Fl
31WJSG5VRFW1NerI+65uXr935O0ybk4JIGlmwzcdOH5bwUdAEJPj2pajcX0e XvbH9qWCNfit
71xY/V+z4fDq09C1x5YSHVnu8PKzhSc6/NO2XDV57bjWeJwvuXbsP661/Lk1 sj9b53J+OMKR
db7XPt0/FfapYi+3j9LLy7fP5IqRlPE5ZwoNnoQoxcfFbKU6IG+hsysIXcfJ ap+4gjJlV741
4f0XR1a9JI04fwQbKn3VNh/K47yWRaMCvabKkcdYVuLIQUOg0pDdY3TWeqDR Qq956UabcWGU
CvicxwUNnj6BVpxWTaDlsXEIzUSuqURKGfBLcG2txUVs7LW4HGvNVK554RYb ZQN+v+Up5SXp
SE/U1RksioT6CT5R8/PlrOsHbI7f+1zJxXLWL+Rk85iJUlIvy03e1kkSzQ3J d1XJcl1sV37q
KuGUpc/p9KyEVP03gSetp0WKlSsWfqWmruoGWUOqDwkoL2OZ2CzBap40GiiC 9VSxDscAZt0k
p7SGbCR/r5Cq//pb7tOA5kwI5GJzyuKmErpryw3+h9/o2J7NaRVO1LuNUJHP apxWLiAe6rOQ
TWUVqr7yhdv+l9eIws/ntXcP9Bqhkl6rcVv5+/JQt+W5Pn9S83lGzJ5yj0qH 3kGvt/Ur29G/
UEsHCH/Cnvj7BwAAoCUAAFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAAOwAA AFRlc3RTZXRS
ZWdyZXNzaW9uL3NyYy9zaW1wbGUvdXRpbC9TaW1wbGVBZGFwdGVyRmFjdG9y eS5qYXZh7VdR
T9swEH5Of4UnTSIgNf0BlAqEmIS0wTR44NVNLq23JI5sd1018d93Z1/aGNpS BnubhBontu++
+767sxmdnAzEiRjnul0ZNZu7iX8dRe/06eN18RGfo0Er8x9yBsKquq0gWzhV nQ4G+KKNE9rM
Msgr1VrIoC6zXNe1brJGO1WusotCtg7M6WGrb+ihaPlh6wlP5+KTzJ02q2v8 tHs75NpAdnU7
/Q652yzjwE7wy4jZ+TAciinMVDNcWDDDQudiOPRM3c9BjKcTdivY73g0nYhS G+FwutYFVBkt
vnaiNfqnKsAK2QjJm5D8Aia5Aeng4eGByMd3UYOb68KbAZnPRV5Ja4Uunxj1 4KApnkE7t7BW
6c4/vgbp/OQMGjDosAiiLqaVytlFWBwzKeCXQydWPCdY/B4kRFTCdOQIFoqA UHC2ZH52F4/J
zjCSGGpCWBPk0KFi6MM66RB2FF1wzC+o4RrbpSfYM68a3Nnk0LHZKVGGqN4X baB2G6npMXGX
qFKkfdDi7Ew0i6oKs0k8FQebwfXN3f3FzeXVKS59HODfJuBv4BamsWI5x0wC SkZluxAFDmXb
IjI5rWCdq27VrknRvi5e5uKezHpQNTQkiG6EYdchtZ1ZQJfVqm+cUIBicKzc ke2SBgvWw+zr
FbbFRfCCIAHLe7DwTNvz259gDNbzWuap1hUQYssaf9LmHs2lt4zcPza6c0Co eF9mVp6RE30s
b39PRwoC5R4Wb0vT7jM7zeCS6js9zmbgrtgV5uAT550rNlPKytK3fmZRmdul ctiV3Fw6gZth
5ovLac/a3pZm/1E3CJVx53GNudImIbTwUZxhWA0st6/kauyLmnSydv09lxa+ kMHU/0ZyrhkL
YfsFvC89JlI9qy+av8F9Kf3sM07zf2H7s2p+pPSzzzbNv9J2AaVcVO4SXXRJ t88DL3nu5HFH
v173Zy5QbivSYCJzbr0pp1ppZC2CvX57wmz2rrOok0QnxkuIDugZa4V8wB0r 3fWHYQUiGUEv
p7NCh8Gm3HlDqNktfAoqgX4AyPCmsYY7wNHv84ryhO8PIdvHUE/8aDzC0ePR gWcDZ8euM4KO
OmF16CRLuj80eOGxqsL2PGvwiuZT1556g8rh+YBuykVF6vAC6ZdQi6ezAru8 CsfFUqHpXFLp
Sxy5OdvCiFdLuTr06KB9Pc5Y2N71ypOy9/iPNY57Q19ZIuNJs32Lbr6PkGw0 +K9arBpx8grR
op77DzXz/Zk0o8F/zWLNiJNXaBadZX+tGaHqqKWo3k+Nt/FyEAVPD9vtLDyK 0WjbvyiDP1BL
Bwi6AVKxzQMAACEQAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAADMAAABU ZXN0U2V0UmVn
cmVzc2lvbi9zcmMvc2ltcGxlL3V0aWwvU2ltcGxlU3dpdGNoLmphdmHtWMtu 2zoQXctfMRe3
QOQglruOH22RemHc1C0aL7KlpbHFRqYEkWpgFPn3zpCULMd2jOImQRcBApiP IefwzBlylP75
eQfOYRjnxaaUq9SMbbe/0+ehd9PkHf32O4WI78QKQct1kWFUGZkNOh3q5KWB H+KnsEPRtdRm
O56XqwjjTBYaI1wvqZ2XGE2uMqH14ITR18UPjFt7ecfnNNL36P/p9WCBK6l6 lcayl+Qx9Hr2
JPMUYbgY39xLE6fD/mIMy7wEQ6PrPMHsTINUKZbSCBUjpBJLUcbpJuK1U/JV FexT2xWxyDL4
9TGT6g7+TXK3Z+jxdaEZyd3AA+9hcnLwM79DuwPRnOA4Fhpvb2+ZZOrBGk2a JxYXijiFmEmB
fLlFecE7aSNKI9UKyElq50RsKpHt2jvfbC9UAkWZx4gJr6oKO3/wtGxeKYoa CFC56qmKDlqi
rjIDUlPLVKXCxMK4TyVhlI4Rb+N9a3v8qIkIqmQvHh81NtK5sT/fnJ7s5AoV QTKYOKVVi0zG
/nzO2MdxPoZfnYCjH/gYx8QcJo4u8BK1k8e0ERxFGewiCRhKQEwaIpZcUBwM odoB7/z6Dumy
gXZVIm2iKRjEvHa0P2LrOUE6wtpUhV1mKpBLCNsYYTQCjrKbDXands8W4XR2 M/80u5oMyPSh
Q3+t81FK6MOyfkLPXmy5Qq8t7YQHLeENQBrYSMwSlpowfvh/8eWcWRxLWWqz J/Za6bDYEKKD
x+JLIHqS/jk8vhvYY3NNMOEeSGO3nY/Q3olh96K9aPDG+nHWm8xsE29ZtBTa 1gUcCwVnRmNG
7OfKCEkeKHEoR9qJ4XPlUOzc4hUa25BLulinn/djyNkTYKbR7cRP5NCtHQPe VAWW801Bt8UI
djadbKdCu43HwK2gtS6SerIuzIagf7BzQYJLQQxfEZlh++CXfro+Q3sTchi+ Pwj9TYJ/IkGp
jGPAy+G4BN1LAGHb2ouNMTy6jr98/Ty5vnTTwRfLquN2BKHtdrf7W7EE8/qU I+D9rJF7DZya
bA7UJvW70Cw5oiG30hPrI8dDD0dgzwh2jXpGvikECb81IXdOQWabkBe8IuDr 6ey/GvA1l3y2
7iPA3DkFmG1CXvBSgP2aS6ivo+N7PMrc7z7xdus3UiuWBW3GteK2kASxV7uc DXE9thoa9ql1
djox5ymVi5bbNSqunnLVpD9TMbBWboTd7xeh95LaBHAtFaXd4fLpcOYXohTr +jC8jqpouuEO
FWHtW+L5iLEF7/Zr4clvnO5e5dA9UWls89ndBPl+keEZfnYJcE6+KeA0Ly8v AHs72jv1FcPP
N9xb+E/z8vLht2+NfaFeMfwe31+ggAtYVBxZduAORWWUscwQ8s292Px1GjlA 3h/J5NTnZ6sW
qGvOJ6XxAP1++58Gnd9QSwcIU3+l1R0EAAAWFAAAUEsDBBQACAAIABEEGzsA AAAAAAAAAAAA
AAAkAAAAVGVzdFNldFJlZ3Jlc3Npb24uZGlhZ3JhbS8uY2xhc3NwYXRolZBB awIxEIXP+iuW
3J2tQqGHXaWULSjUFt16lZgM67TpJJ0kpf77VlpRChW8zRu+92Z41eTzzRUf KJE812oIV6pA
Nt4Sd7V6bu8HN2oy7lfG6RiDTttxv3cUyEl2xSuxrVUUo4r98mcs/wWN5wPo pQM0jkJEeLEJ
nM5stt+nYbZo1neP8/Z2Om8W5V+OOKGwdmBxkzvI9OtEgWXSbLXY1UO7C1jO RstmMITry/8J
FsF4QRB8zyRon1zuiOOZJJ9TyOkQtiHes1V50t0XUEsHCJS4/mLMAAAAbwEA AFBLAwQUAAgA
CAARBBs7AAAAAAAAAAAAAAAAIgAAAFRlc3RTZXRSZWdyZXNzaW9uLmRpYWdy YW0vLm9wdGlv
bnOFy7sOwjAMRuE9T2GpM/QJmNqlK1TspnWNpSSu8ic8PxexIuZzvo7mwotl Jd+reQZtXqje
hWZBvUg9ixYBXum4GmvhRHtserAcQkeDp+SZDGiC8JP0q9yanjaOkDe7GhpH msa/pn981mn8
4idQSwcIHMdMC2wAAACwAAAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAi AAAAVGVzdFNl
dFJlZ3Jlc3Npb24uZGlhZ3JhbS8ucHJvamVjdL2S3UoDMRCFr+1TlL1vone9 SLeg4p0i3fYB
xmRMUzY/JNni4zvZTYstFATBu3NmzuTLn1h/2X5+xJiMd6vmgd03c3TSK+P0 qtltXxbLZt3O
RIj+gDI/Y5LRhEzhdnYnHFhst5hyh3mDOmIqyzBlQEewgo99yklvLbrcCn5S VKxLpqL5T/Mx
mF51ASWZ6p5oDJwqhUr1UTOUvQkJ2UFlJn0kAUcY8xjPcBqAqIdCTZPlF17w a8JvkEEhewVn
Punwj/9G7OQeLfyZVwv1igmVB3q6MTrp27c79Qt6zN0YKXt97wdt3Nt1/iQJ d371i1/1DVBL
BwjEdX108AAAAJICAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAACoAAABU ZXN0U2V0UmVn
cmVzc2lvbi5kaWFncmFtL2J1aWxkLnByb3BlcnRpZXN9T7sOwjAM3PMV+QBw voChA0gMMDGy
tKlVGSWxZScSn0/Khgrcdg+d7iYqQCWmNqP5g4fd3flPUORiYatfjrdhf76e vliS2tJ7nzn9
9ERZUCuhbSMZzcYF7W8IWCr1Ze4xqkHkLJQQWGfU9YczbhoRoBPTGBy3Kq2+ +UQluBdQSwcI
8fLDE34AAAD5AAAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAAAtAAAAVGVz dFNldFJlZ3Jl
c3Npb24uZGlhZ3JhbS9tZXNzYWdlcy5wcm9wZXJ0aWVznVfPTyM7DL73r4j2 3VFZvRPSHCoK
KyQoaCm7x1E643byyCRVksJ2V/u/Pzs/pmmZKYULJYnt2M7nz57RP2x+P72/ YC1XGy7llq03
jj3D1jKuavbC5Qbs6FG0awmXBrgTWv0Uv7mp58JJKGbwysIpmwq+MrztFS7j 4Z2uQV4LCQ98
BcGCF4RPG5mCrYxYk1TxCBIqx5Z4xFzDHXsVUrJKK8eFYnXQZi2pnw3coFsU fd9LL8a83MmG
PuBpMH/E0fs1qKtaOG2ujNGm8H+Zxl2hVl2k4CV6DaRVUE8r9mD0QkLb/+IU xNUvB8p2ihQb
U7wFZhu9kTVr+AuwP+O/DJJgCiA+XvD6yQlZUhA+Q9/B6o2pwNtEOalXIet+ 41P6d2Atultc
c/SwZk4zqXkdUhrSjk4OWg6vHfcxJyuD5ubcPsdMZTmmKtlZtaeZvNQt1lt9 yxcgj5hMxnS1
aUE5dORF1GBKYTFssRQc36p4WtdBveJVA2zpAx7SbNC2hCt8Yty9RLjRD26u oM5SZWCJATes
EWC4qZotWyK6qiCHpyHbQ3fcqEobg/C+UcglASd/zv8Oic90TMqN2nvHIm4z YZnSjq3xXtRj
WBjveRA1b/HFMTF5hciwlVI9ZOBJ2a2qGqOV+A01gfwRcR0MzSnJBKCGW7YA UF1isH5cOrRb
62DQPlmLTnpU4foEr0hrhnWV0pSrZmjuU5tYLBbDA/d0GjvE2dGNEi66RPGW 79TkCeKpBO92
NZfSH0F6aCRvLHSGZjD/TGGPyb0lU290OzKgVe5vpNqcU2OmsHdlFiJxJ8oj spshsR06sufE
iXaCI9NPaOY9I7ag3IkFtwF3lJ7AQlUo6mMXfNfahazkcaY8RdMGhRgEoviQ sf1gP22mp1ta
QNJ0ooqRRqtEWAtgNaxF5UI29uvotPu6xT5qesK4+FhudbdMBdGXm8Ry1gt3 BH7aHTcK5zRR
v7ko7vdGQReecllWZ7Fr7Soib1oRd/a4rdgZKILApt1WfFS9+M8/NbZNfEtk WB68TpQfBfra
bBmIbYpBuUDanqu1ESuheGSgL1gpX3bUXQfh3hklEqf3M4AiTkdsujEUOp2z iT07e1c9PYjX
qPygRI+9oAUpkgtszs0K4kyIj8Ml1nu99UMdNT2OGg2YONQNX5n56687GOkG FJKHl51zlpTJ
mXRVmhoarS1Eji8D5jzxxvO9+tmr1FEutgfgLj89WhejHwRipL7JHrjT7uje I8KefzN6sy6d
vz7ujWZo6TwR6lxrGc9pv+ewRtLJedaLjSLuiSV9m4kpLOj/7oNlhuBbccxp 8LLrvplCOPFk
u6c6WVhneOUeuLF++IBfa1+XP+jra75d+2A3COUlc7jybI8ISWKHBn7i3LJ6 dIRRHPFewFhP
on4jfNFhN4TAN5UX8CRKVv3pW4eelX5Vt8LhCCGLuGQyrC/87DGKz3KtTcuT YuSfbA5MjCRo
i+F3z25u8eBADyfWCuv4boAZbOMHfWXQQELM5AXHDpqZe63YC3xopQIo7dcc Tdn+6Fao5z5E
0X7P4SGivFiHFX+Jx5V3vjwfj8clxvBsC/+3T5IwWX4dj89LgdzZYsBBIa3Y CZp641a600yr
YU3yuvyXNJ0nqSL8HBcNhF3EUf1/UEsHCPaZ2MDOBAAAaRAAAFBLAwQUAAgA CAARBBs7AAAA
AAAAAAAAAAAAKwAAAFRlc3RTZXRSZWdyZXNzaW9uLmRpYWdyYW0vcGx1Z2lu LnByb3BlcnRp
ZXONU8Fu2zAMvesrBAzYoRgMd+jVhyAthgJdETQrdgxYi/aIWZRAKd3Sr58k O2lmpG0uBi2+
Rz0+Un7Y9sT3YLFZk/UD6lU5UV7cMxmUMQVHKb2aUl/0LbdKoaHo5LjENUEv YPVNyhD3qnUc
8W+sDIZWyEdy/BGUc7lb1idgThTjn5/0AmJO3PqavE7XNUtBiBj2hcwIqpQi pjhRFm2WdAdP
OKQ7kxAY6AV1KJTNRNlTdUcDKqUYnqmHpGaZJXMsUi6qN0jtCArKOAvZ8HfI 2jqDwytl601q
odpLL9Y8lrNZV3Pksd8rlM6JnTH0yEjtfMpj9Shxp9e/EKOK8FSB9wgC3GKz OIQlM/Gbh+2A
EvRn/U3IjJnSYLN0gmNV7FAw8ULaKew89Fj9wBDXGB+wFwwhyTtI7pFRYJjP 9Azmaa1nEJPP
jGUDQlJ9iM+heiHOa9uspuAckhTLFmyyZXsD0+9o4TSJ8sCCshgh7jyWoVff 815sLuu6bh7Z
YEeMZga5T5DN17q+bHKUiy2dtcAm6PTRFnmrYWqwtaZNw++d7MalmkwfH9mB +B8ur9RbuJmU
O+Lfm6ssJUfqH1BLBwg9jBALuAEAAGoEAABQSwMEFAAIAAgAEQQbOwAAAAAA AAAAAAAAACQA
AABUZXN0U2V0UmVncmVzc2lvbi5kaWFncmFtL3BsdWdpbi54bWztXemP2zYW /zz5K1QDAdpF
ZCe77WJReBJM50gMJIExkwP7KaAl2tZGVyV6kulfv4+XRFKUTMp2ttt2gCQj inznj+/xEjN/
8TVLg3tc1UmRn0+eTZ9OApxHRZzkm/PJ+3c34b8mL54/mr/AUZqUNW6r/gOq 0jffheGjR2EI
v5XpbpPkzx89CoJgjr8SnNOaQVkkOTmfFNVmKohMCUbZNCoqPF0nKX73UOJ6 EiTx+aTCZRGu
CRRMnlMylNKLTbbe4DyAP7hCBEM1Uu0wZS5qNEQC2hJeA3NQQ0pwPqmTrEzx pzhBmwplkxlr
OZ81NVxkxtkafqcyN9U+laiqcSVFr4tdFeFwjSJSVA8+CnA64gl+uBqG1O3r KEV1rUsHLKbV
LidJxiVlgkqR6unLNze34uHGFG/GuY+xyS6Z4jgBcsJ9IEXIC3y05y1a9Sgl rvtU6D4FEcn0
jpVd8aJr1mhxpZglRxlY7TEn9xYelHdJRHFA/65nxeo/z/4506jdAIKmm2St tGgUrwc8EeM1
2qVEqNTxkKMWSsMMkWgLfe+OUFttHoZovDHqqvyLnFTJagfELx1FuYgIKPsL qi7btgpIuFW7
IIFnJ5xQiaCOAMouCUWBD1BEE9X8dVQlJWGd/LF4PVVKJ4OoArHEr5dCmA6Y JM1chxOYD+dk
Efd3wn4erU0F8ZE9L8dfPia/oSoWNo0qjKjO4RdW6mjYM6jAG/CHVvWGvuxK Z749iTeIKDgh
4nQUuP6KaMNaqboPq5dCRy6YItRgyNBbQcwQip8FcwUrz1uNr6B0PlPfcZQz P3FrjXRaWZS7
8g3Od8JpSZ6QUIgcItYFfXoEOABHpOmx0LrFqDDLO1yTO0xu8QbSAZWssdAC eF91QpoAAPiR
4Op88rcpt6teQ/Dt5iEj7ywoHBqFqMRcR40Y/KRohVPAXNKKxOPRa/piYlbf ixNFNSoBp9Uh
k4EfVqhaIrI9n6AYIhwN951qOEcrgOlNAeZ41nnrbOML3bsMPtwabUTo+rOL s7P9QFMDUVRk
GQgE2IMkf59Qr3Cu001arFDKxXqF8jjF1bIq7pMYN/mc1RC4rH2A+bKftvM4 RgmhpZRrKow5
QN+I+RwQS3AMRGzUccGySooqIQ8i6r0uvoAvxQhRVPmQ4C+L2HNY8lzDyfw6 xYA2QkepHmrT
pEt5QEd6WaFym0QopRyWUGZwMI0OAiPxy/kkxikmWNOKoUqR6sjyKubwFbZG 986izmfcOW0P
GgDG6cAJHRDGYRD3ciDRBevHhGyXtNIhqGUE/nzQZcb9P4ODdD/83QXD4ur6 EBhA8z8fCFZF
8TlD1effAQ68oNAXEN4vbtkbNyBoWOAN/3wQiHadKDBcvygfvBqUqHZPkf4A 06cKBw/haG/A
1Vt0n2xEdtAGbvx1HeZNBZ/B25se4n3j7gbecl3C3lwDLa/EwMRh2z+Gpv/m RU2SSAf1HtzP
Z32C7J27URMqXAUDrl2wZMucAWgNs4IMDG7xnjENEu7w8UG9K8HgfCFwgLKQ gjNQdO9r7gQr
hU5Jl3uhY+QkuEfpDgs5uyuo8GizIjRKYmb8K7p4iiCyNHAQZv1gVmFzjX19 Ql1fMSl7GbrT
2hHlHbEVzTyjM5/1jQuqQB6c9iBD6vf7W//AQ8TydvHm4vbfnz4srj/q4ohl qaCxzDtUbTCp
+9rQlRLDAmNWRziyhbhlhdcY0mckdwZogZdf6VJCAj76bcCjDQ+ZmJdN0aJt Pm6/gI0EJbUl
2qiKlOzRa4Nggz1WdjihtLuqcz55LPlPPZs72/Alb73UlNe2GzZ4rGKoLDGq EBAdq1sfhXaV
8lR2uWg4n8Q00GtzHFlWsNxt00vi9Ma5bFmfxDpyjj7WNPb2p7fLUvA9iVGq HYxS64s8flkl
8VjLDBA5vXluVeb7beQfwu9hmM9GWTAQIgkwJmi1wrEseVA3y0R4L8pQbL95 RfguQd0kbfli
yKm6Idm6ukzKHYPWW4zl5O+O/v5ara6NYhrxhEsV38ZFhpJcH0IMVL9P6h34 27U6OKhC6ljD
YqgT+fYdWtWtUwl9cnBo0G4VqYTcHWgzDFDQZ7Ide+qvpdC0LVVrqiYfXnyH bZsiciOGtlFS
pTYtPp5UTZBzFUk/weEhjwDpHnmstTT+BtZbOFIfnwiHdzInNwLXsmQcHiXB wzApqOhWFJJN
RT4vqn7gBZqZ12K/0W2BVVqKt6qn7fBBToQMbnw70+DptaYrWUrbK91DYe+q LrjYuYdq606G
9b0dc7dFJb4sUvBMHt+A/0/pFsbsf+KRVs1a6Fl/I4cEvh5pRsDuwh7mFWNv 7pv6ZYSyx/MM
/fH1Dhth8tHlH8gjG1DIVbWu/XvS9iHG78xaOo4QqXefbLYUbp9OqKPfAVUC tpZU7sie1dS8
4Bt0U7oz0NlH6KWA19NmO2SokSG8WNgvKqHAxaqGcXJE3sryBcH6MKk3dXRe jBrH2MDHVvTo
6MbYnaBFYWlOMxwmSSot12VapcnIdVl+updPLWEqLo9rgTJ7OmEDiavuMIrS zzDZFrEQYIPZ
JtP3P0zkSrs4eKU7kctkW66lxrGcyLIK9LaI8YQN/6Cz4Ioaqe5R0ro07MNL Kh/UOEPwLnoF
4Knldsrh9LkuBvG/P3367HDS1/GmS/pHjfR8poLyWD1HWeM3+g4uR/Uck5pj 71Ey0gl3NrpQ
YYfPpDKhZRbi0H1s+LJ0H08ROdp0+XIoqz2l6wL0cNk4XHXZ0iT/7CvbjyeQ zWY3NrP2Fe6n
byRcVGS0w9DNf18RvUJ2bUH6EwNbTwx/PjFt+KRHbiVMmRHg0FBFvzKBMJWB fCDT5qKm+8Qo
N+MVe4/Yy1GBq5e+62GEvvaHhTKDKzXulO/IMobNkI7ZgBV9evb06dNxJCk8 dYq05FN/jsP8
0Eqtsn5iaTOf9Zr3UHhYDhfQbwYMdNCiUbBYRN7HUtQme5yvWkhtdgKj8I+v DLPwwlGGWWr0
HE2jN/LpGfOZ3vaIAyDLsQ5+MEeWj7LP2OMed9uiItGO1N/otIeWm3pPdcha P5jZixTl6YYl
/QdEbAIc+5yImYTo/JhPNXF7Vk+OlnlJSFiRT9rBBLHYGOT1+9vF+WRdFJqj mwqUm75hsG/b
VUkHZkOx7UqJM7Xo81D9z0k+8A2abp0Fnb/gmMrb/cRFoJGx6r6F3LPFaWnZ QmRZir9TUt8r
VmBCD6IayoSK6pyqAV83Q840MytpSxZ/E4e1mdPJX/3Vj+0uNm4d6y05qhjp LEuk+F046zUM
kD/96Oys/urHdhblNNpZtPEBzrLM6JycdYrQ/AvYFUactggdruQ7j1ANvIGA +Lp2Dzgof/M7
XKYV+8SPCmJYlgAp02dyudThC3zqQ9DnyravHEjn9It7rTXX/dcVeT7TTNHs RM2FVQORt0cZ
SDn8X+G1Y3qbjSTRM73xoNB2a40Ciumomzd2Wr3mDZpx1hUuY/oBhjG3Fgbu dpmzvV1G3ChR
CgXq9vQJ6NaMeZvl/pAdRYFX04RGTvGtBt0n8OgyyokJxkTF5XD/0VkuNSoa vLs7HbxPyPmP
IbvalIaxukTRUM/QGrQbXDChNK2iVtz72fD7KlHaCrVaq810s1ki5En9Lacg 38TTkpmXj/v3
w47o4MYMXq7t0ee4zqW3MjQbc3RxT14O0/qTlopw4bvzhdnVHBB7RAYNeKF5 C4UmBKhLZ2/X
X8sUgKfPVZM8SncwQzNSXsSZXLeKIgIGyQdPkooPUoSANDaenZ2NIsU3cG+7 BA8WsrEKTQ5i
IKXnVNMifHPHtLvhFHFxykl9wj9TG6ctl69ZrXDTWFNq5Lm2VuPmN+lOo1MI b/p0CJOkZq89
x54NbOlHCuTtJwZ9dgmKXrMUaz2gSVFlKDVPaPCGvadvzS38twbHxmM62eEj vb1E9aO9urW8
70aCH4rIe/zLw5V2A5KKLVIlmw2ulhQbJp7pmd0zDeC5+JZSKYXOQJekI1ys 5VB571UjCrrP
pBwAhJ4xu0GiAbSxBW9cHKZpMmskV0u7kh98foMrBCNYVPodRenQsBilv7Mo +dYizYyJYzh3
VlRajOkDwrwsgBdMYi63SRpXOLeARGf3l1mVxwHrzflA+w444Cow0TkcHRsT 8taTTnP7UKs3
8Agy3RULlr7lOLjbhcwQEfREieBYgcLiv+PGiqAvXNhVOAK0OUsNN6xkwPr0 VrIWO+2wwMyH
x0jE9qGeNR3zqmaKPH1SvrLyPUpqNkj/laDHd7oTJmbDS7ZOdrSEd3Th+pPE QIdG2nzBozv3
zTj0DuiXPQxSTmu2ZrwbZdo/8sjBtnSse70744Nn3wWQtJ1mG/M9+mar72Q4 TPlaemNAqUz6
DwGkQkYDY7tseN2HS8eA5Lxoagl6HigaJmaGT3kBbL+G8xqn4hOsPgOcoBPO ZwNs57MWMlZE
O9xam2VgCHlrbRkDMMMoc71cldUQNFqZ5VeJlkUi+YptHHXvGRYXCzlc4vSe iXrJWWuE1Btz
uULteMz54lzWTp7WbauKwZpBlt2da7lDI3C8OnilbRi2TghHrKN+xg/KmE24 ZuGuodhCs7UY
uEy4jrYATIu/hV8voghQXIlsvE42O34NjkoC/7qjn7afT25+Gn0hSdZePCsU CXmRhwW/C0N2
cap6SWmQFhETmG3m07c/m5xhnMLYv0Br9qGUuuOsE1NOCQxxIUWRrlBlZSTe 7ecV0Ivrndix
i3t/3rdnCAIo33KJsdVXQi/81dKFAJ4KwIG9zALFcpLUvUQ2YAvRbJD3cWsO KYOetEPLvyRk
C3G4SmjYPJ/w+QI9YrqA8DYHuKG07onTA5fGzZ7TG5LJ1oVlE7qBX0IY3oJk fZ2VNHetgT3M
VzrLD4LU3lzSeyS3Z2IuBOgT3zKfoGvlNrvzKbRSvQfj/v1XT0eUaNgU+WQk ec2C332AzZ3o
WdzkKRbbzXvYlff0jbJTLnG/5whPF/BmjqFVAllHjc9Kbh3zfwi4JFqLeGMD 8pbzUR3aFDk6
tMuURuiCOQOl6cOToC5xlKwfAsh9MpWyuAezQ/E/dvwXUEsHCISK8E2/DgAA BmQAAFBLAwQU
AAgACAARBBs7AAAAAAAAAAAAAAAALgAAAFRlc3RTZXRSZWdyZXNzaW9uLmRp YWdyYW0vTUVU
QS1JTkYvTUFOSUZFU1QuTUaVVMtS40AMvPsrfOGGp1iOpjgAmxtspcjW3geP PKtlHmYeJuHr
Vx7HScp2KKdySdTdUkuj6IUbrMGH4g84j9aU+Q92kz1GIxQUL3vwgN0OyC+u ocyvGhUlmu7H
AGx2+s0qrHrCbxJvILyCdOC7FEwgl47ru9yjkQoCZb0PLh70pzbo8xG5whrB DfiT4t6vefhb
5myIPVQBWx6sKymrbhQMVVjDXWCbFPvZh1YCibhOvo81jejEV42zLQpwpw09 24osfPGQXPUN
Z6ttY10o1rx65xImZYGKpNr+OpuzNBPdV/bZK3xEdFD05cvcOsmgUth4YJV1 wFw0ATVQjikE
3kZXgZ8DYdvsH2EM/6t5Nc4XkZGfabBF+BzrKWx4i7J7gm+gs/ZA1/SdPJ6L s63GOawbcxwj
kpD9jBJrJvGUojU3wi/hUkf0WA24gJNGTrnDy37r70iipEgxIy9j00wNrc1S 0UW+j0t5IX1m
c85ILnF/2J707pNNW6ia8SYc/7wVdy16fEOFYVfeO4D0Dyfm5IQtJqaK59jj XW7pyIh0ZJYo
JNSLaKczSV3SSGaF2aqXFM/8a7cJdKPKPJ3l/1BLBwhAuH99uwEAACAGAABQ SwMEFAAIAAgA
EQQbOwAAAAAAAAAAAAAAAD8AAABUZXN0U2V0UmVncmVzc2lvbi5kaWFncmFt L2ljb25zL2lu
Y29taW5nTGlua3NOYXZpZ2F0b3JHcm91cC5naWZz93SzsEwUYBBguMrA8J/h /9oi/SZ3yR83
Oualqf+4UPHjwYwfFxrS7IxeHJvy48WGFxc6fnw48f///8PdZr++7frxYMGP GxN6Yt1+vJhx
aXXDn2/3H5/fuaXe6MGBirVF2h9uTFiao1Lp7zAvXnZtjkp/kOSeeqP394/t aTU63GrGQAOg
+JOFEUTrgAiQnxjYih0aCjx0pPpPKD96kWHF0LQixOCLyTre7gcTJxSsbLiY sigywamJhXUh
W7dEgYW7guMN1SZVj4PPw7dxcsQ7iQu0CTB2dnUzSAr2M7JNmjyJm5FBmpmZ cdbcudOcZFkZ
2ZcuW7rASZ6Rde26tSudWTZv2eq5fYebI4O1c35eSWpeiW5IZUGqlUJmbmJ6 qn56ZhoXl/to
cNMguAFQSwcIs3stkywBAADFAgAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAA AAA8AAAAVGVz
dFNldFJlZ3Jlc3Npb24uZGlhZ3JhbS9pY29ucy9saW5rU291cmNlTmF2aWdh dG9yR3JvdXAu
Z2lmc/d0s7BMFGAQYLjKwPCf4f/aIv0md8kfNzrmpan/uFDx48GMHxca0uyM Xhyb8uPFhhcX
On58OPH////D3Wa/vu368WDBjxsTemLdfryYcWl1w59v9x+f37ml3ujBgYq1 RdofbkxYmqNS
6e8wL152bY5Kf5Dknnqj9/eP7Wk1OtxqxkADoPiThRFE64AIkJ8Y2IodGgo8 dKT6Tyg/epFh
xdC0IsTgi8k63u4HEycUrGy4mLIoMsGpiYV1IVu3RIGFu4LjDdUmVY+Dz8O3 cXLEO4kLtAkw
dnZ1M0gK9jOyTZo8iZuRQZqZmXHW3LnTnGRZGdmXLlu6wEmekXXturUrnVk2 b9nquX2HmyOD
tXN+XklqXoluSGVBqpVCZm5ieqp+emYaF5f7aHDTILgBUEsHCLN7LZMsAQAA xQIAAFBLAwQU
AAgACAARBBs7AAAAAAAAAAAAAAAAPAAAAFRlc3RTZXRSZWdyZXNzaW9uLmRp YWdyYW0vaWNv
bnMvbGlua1RhcmdldE5hdmlnYXRvckdyb3VwLmdpZnP3dLOwTBRgEGC4ysDw n+H/2iL9JnfJ
Hzc65qWp/7hQ8ePBjB8XGtLsjF4cm/LjxYYXFzp+fDjx////w91mv77t+vFg wY8bE3pi3X68
mHFpdcOfb/cfn9+5pd7owYGKtUXaH25MWJqjUunvMC9edm2OSn+Q5J56o/f3 j+1pNTrcasZA
A6D4k4URROuACJCfGNiKHRoKPHSk+k8oP3qRYcXQtCLE4IvJOt7uBxMnFKxs uJiyKDLBqYmF
dSFbt0SBhbuC4w3VJlWPg8/Dt3FyxDuJC7QJMHZ2dTNICvYzsk2aPImbkUGa mZlx1ty505xk
WRnZly5busBJnpF17bq1K51ZNm/Z6rl9h5sjg7Vzfl5Jal6JbkhlQaqVQmZu YnqqfnpmGheX
+2hw0yC4AVBLBwizey2TLAEAAMUCAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAA AAAAADcAAABU
ZXN0U2V0UmVncmVzc2lvbi5kaWFncmFtL2ljb25zL2xpbmtzTmF2aWdhdG9y R3JvdXAuZ2lm
c/d0s7BMFGAQYLjKwPCf4f/aIv0md8kfNzrmpan/uFDx48GMHxca0uyMXhyb 8uPFhhcXOn58
OPH////D3Wa/vu368WDBjxsTemLdfryYcWl1w59v9x+f37ml3ujBgYq1Rdof bkxYmqNS6e8w
L152bY5Kf5Dknnqj9/eP7Wk1OtxqxkADoPiThRFE64AIkJ8Y2IodGgo8dKT6 Tyg/epFhxdC0
IsTgi8k63u4HEycUrGy4mLIoMsGpiYV1IVu3RIGFu4LjDdUmVY+Dz8O3cXLE O4kLtAkwdnZ1
M0gK9jOyTZo8iZuRQZqZmXHW3LnTnGRZGdmXLlu6wEmekXXturUrnVk2b9nq uX2HmyODtXN+
XklqXoluSGVBqpVCZm5ieqp+emYaF5f7aHDTILgBUEsHCLN7LZMsAQAAxQIA AFBLAwQUAAgA
CAARBBs7AAAAAAAAAAAAAAAAOwAAAFRlc3RTZXRSZWdyZXNzaW9uLmRpYWdy YW0vaWNvbnMv
b2JqMTYvU2ltcGxlRGlhZ3JhbUZpbGUuZ2lmc/d0s7BMFGAQYFjKyfD09Y/4 +Pj9+/f/vz//
wIEDDQ0NDP8ZGBj+A9n//4NYvbWeQPacOXOAUsVqPlsm2ALRhn67NT0Oy7ud FnU4z211nd7k
1lzuW1fqV10ccGVT5q29NQ9O9P/89ef7z99ff/z+9PX3h6+/33769erDz/sv f9x5/v0/9YDi
TxZGBgZ7Bh0GBkagj/gZGNgKDswXcNIRavVQOXI4J0/Bc8kT51obrjnpX8wZ Kx2v+5UJLW05
tzD7sU9nmMsiN2fe9S66i90ORmX0uIkFilfxs2SpqIg3tbTVdnR5Nlf38vYH cvdk8TJwB0qo
trAu4lWVCJRUUytavVIyUGrDxk1S0VsDHRmsAVBLBwgPA1P+DwEAAFMBAABQ SwMEFAAIAAgA
EQQbOwAAAAAAAAAAAAAAAD8AAABUZXN0U2V0UmVncmVzc2lvbi5kaWFncmFt L2ljb25zL291
dGdvaW5nTGlua3NOYXZpZ2F0b3JHcm91cC5naWZz93SzsEwUYBBguMrA8J/h /9oi/SZ3yR83
cNMguAFQSwcIs3stkywBAADFAgAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAA AAAsAAAAVGVz
dFNldFJlZ3Jlc3Npb24uZGlhZ3JhbS9pY29ucy9zaG9ydGN1dC5naWZz93Sz sEwUYBBgmMgA
Av///29oaACSij9ZGBkYmBl0QKIgeQYmvTn9K1c/4ncUWhilLbh2AbNdrNyK xOQJsrd/LFS8
lZSvM/3O01sWlRX7znNwtR9xZGSwBgBQSwcIvtT7EVoAAABdAAAAUEsDBBQA CAAIABEEGzsA
AAAAAAAAAAAAAAA6AAAAVGVzdFNldFJlZ3Jlc3Npb24uZGlhZ3JhbS9pY29u cy93aXpiYW4v
TmV3U2ltcGxlV2l6YXJkLmdpZs2T+z8TCgPG53I6E6eSk1BJbk2HY5a3cqTE yZnbwd7KvVwy
t3KLjls+S47r2Mxts7kvQ2iuM0OzYXbhYJq7hmHujKMcJ731X7zP5/vz83me H76/WVvdMPG2
BVgAlqUAX/Ply5fNnU+bOx/bmAIuf57LnxOtSDZ2Ppm6ZZi5I83cM+h0OoFA QCAQz3TtLL3R
d30xv3qjrXwxVr7ZUL8c+8B8h2CsQ3CB01Mc7CnuXmihczjBORzvFlnsFlnk +Ufpo5hyr2+U
+cZVwBNeB74kPXlVHZr8Jiy55lla3XPk21hUwwtM04vsxlcFlKQCSnoRLaOo I7uCjvnGu7xK
Bq66B1fNJNT2lbztL/0Gi9jIqWkbrKcNUZiCtp4xBm+6f1jInxKPTi0LZlbG P6zOijan59eX
1nZFKzs3PZC3PDPNPDJuP8y6/TDzjhfqV5+vL7J/88uxepxt459rF5jnFIKD heDuhRU6RxCc
I/CukcWu38aXeMWWP4op84ot842v8Et4/SSpOjip6ll6XRTybQyqAZHX8gpL ScJSUvDU9OKO
9GJaZmlnVllXVllnNpGOIdKzK95lE99hiO/ySN24mp5Scn/JW1YpmVXRxKls 4VW3DdbRhuo7
hhq6Rpq7R2ms8S72ZDdvmjUs5I7ODwhEQxNLg2Mi/tTy+5mVGdHm1Py6cGlr VrSxvr2PrWES
6npLvhaSWZWtvLqOIUqPoIsz2fPXbP+IkDM6x58WD00sDo4tCGZXRKuSefH2 6ta+eGOPNSIc
GFvgTy+/n10ZF65+WNqaEW1Mza+tbe+vbv0t3tjd2v20Kfm4tL4rWt0Rb+5t SD7u1T/am2rc
nesb63nd0lRUUFGQjM+Pz8NEZaN9X/5Z3NBYRWnuYFC/0sdq7aDWluMxnUzW B+Esr++vwf7h
YZ5gYnzhy/9l9L8Z8M0FAPAIIAM8DyWXdr8CKl3xCAArS8MUtGwIN4YvVWec 0guaBhnlI1JU
DCPOW2O89FM0LOH67MYF69wrRq2E6u3HAJSebz2RvQvXLwFGrK5P8JfYpRa+ p4sC9wIcYdaW
PxtMGANgRMeodEL7DmkM71xmlZcOLphoCuDX2B/mzDm/dWYGzcSecobA2ZLV GS4ltN69Pcwg
/hCyySQ9U5oPElDCiY9Rv+lUtMjCtD0pAK34uKsIBCr55GWrKtu8QH4djJL+ oxwmGFoRwC42
wLvCB34wjfusoPbT/HBUTjWsrjAq2K3OE+X2+zllIa/dLiLhwGTPBUe8f/mn rsK/1xcb/I+Y
aqifwuDdRVGHN13N6seppvKrmiE3cYvQZt+UsyfXQg/caSLITKz630uzUXID lBnfWqoyO6HZ
HMqNJvM0j3thpeC5IYZnooVRkarGJeHat6Duz5RgQC6IMqN8wftCq79K/I4i 0TatNlNCzwJx
KjX1Mdp8HzhLxPBOUU8APkrMjvwozDphPARA3Tq68RBtabF8BrOuqvIAZgMK B+SY6O4iZJyu
0RG5J+8dVGhjHmMXAR6w5cW4s2kxdKk32ya6gdrFaZW5CrUr5vhQhpw8vF0M sQP/sBdhB4l6
rqqmFyuhcioJum2TEY4nJgGF9x7KXSbICDHc02x9JgJ8xLBzC8Q4+NXokfAS HNqowhwygStT
/4ee29ipKYcO40iLAJzZXoQRzdEtMI543iu4ZBx+uHynHUzSKmSc4MLzSByf n4susyPOQoYH
j2Ow5amNyx1tArxjs1DuymLXwohPvfZSIdcPzWvmLtK8k/W2isdnOSutx1S1 3J/4S7ih+KNj
58GY690YpNGIcj7pdBPo/FZHgmBKz4I29GCn68+sNzt99p+1uSCNDKQiG1uI bGS2WXg4cps6
7cSFPYP68ix3G8xuKBYDsWWXg8IhTL1gGqfzZ1KMMd5GvmPRvdc45/0gzKFo +73Lm+nLY3cz
gnZkvLnSi5F+a8a2R5PH3e0Nh9oYBvjSh7YxAeNnSgIdjXjmndfZOof/UgSh TfGac4fq9ZG9
wcUT+eYxrGbK5IOmATKn3S3BZM5UMHCQe+KJiwLIfxl37f1rhxNtQ7KKLzQN TEc8P1rPxx7F
AJrWBiiip7SiIfA77gPKeAO65oY/07iYv0Bczmqcyrso+3mLb/hipOycmrHC RrnhxS2GXvCV
LwJg5m33gyXnL3Tn1Zj/IKVS5XJaEvbNUkx8/vv99OjuNqmhoNTBbKXBej/W ir5Vx1BU6dCQ
NurvltFNOkuyeTD+y545g7isy3TpY2iEA5TrpeUuIMsULioyTyaf8tIkFh8d Mz5VoWCpelR/
J/FUCvTXS79oyqGiexTz23qsQEavOs4BgTqK9UJXo+di24spspIcbw2t09bA ChUUWhYCyU6z
MtdSulplnrTH8GCcu0R+0tgLjHBS6Qf6Xt2LToLv7aAGApIVZfWgWioS4HmP iTuzKhmfXYfT
M6c/5McCu1uFRmgsj6h71TXJQhPykmoDNUx1NgvDNWY3mM4l6x7k2IZI8rDr xIsTYrATZiSX
ZKx+9j7b1hsMyMfJ3r2apArVuiktN8G5/0lhXh7m9uRRFVGkbSrzGv8Jozrg dexaC9v+KVwp
J3Wd/690Chp+TCglFV2Z61jd26AzKCWFyLtOxQ089WnCWh+d8hck5qPh1yDK fx4PMHdK4yZ2
bdp1e5lfP1tj77O06x9iO3MnIVwpclOShOKByOWjJt/LWqpwvUBmn6scYnV2 veUOeh1qqpyi
T1QZ9GZcqM2/wy+M5aOgZEHL76TG3NbXpd+9qHYYXKEC4u+pQu9bQRtikgi6 SASn1vnH76QV
gJPZWf8uLLonKiKJsTlINBRbLBy7GXdGWxnjYnHffly51opcR1Dsd7JU69cm g4N8PF2Y5auk
RAWNOrb4O/Ax23GG2j451awWvElV08kt94/RWbvFZve6KHgByFV2D9VlVDvD rhlaD8n7Yowm
tcFLzVjjp9r7Sa2buE0iaDET6p6Sri3VI4ZdcmLchX68lZr4VivKY3E8yFQL TFVOiMsLspj/
R8AZTP/l+/S0kJhDN3rLTi2VKrb957rBdPkPEcE5+p8qg1iektC2pnalUWIf pabBgLp7Dmk8
MHVbeua5FbXTM1peZTiVl1/3l9/JhPuQ9n7qHxHvZpDWIOrdvdNjNFqRm6hj rDVcXUMDYPo/
UEsHCOVlw3Y1CQAAogkAAFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAAUQAA AFRlc3RTZXRS
ZWdyZXNzaW9uLmRpYWdyYW0vc3JjL3NpbXBsZS9kaWFncmFtL2VkaXQvY29t bWFuZHMvTGlu
a0NyZWF0ZUNvbW1hbmQuamF2Ya1XbW/bNhD+LP+Ka1F0cuEqLbBvRoB1qTsE a50iTrGPAy2d
ba6SqJFUEmPIf98dSb3GaeKgH1rbx7uH98p7cvJmAm+A/p1MKpF+F1sEI4sq xySTYqtFkWAm
bZKqohBlZuaTCZ0qbUHpbYJpLiuDdKqxVUkWt5jWVqpycZtixV/mDxrpurSy wOT8QyYqK9Y5
PkH3q1ZbjcZ8UaW0Sh+0wGJD39lscbH+B1N7UGtLWg0s+6/KQSzJmf+8RFPn z0M4DxCPGrPD
dl+FWM8XORZY2iuSHGna1YEKF2Ce54TGf2s01lAayo3c1hovveTZOBqFxeDT T8G6xFxwh5md
rFrABjE08mdZfp+PZF9UhvlYuCThWLZyH59ESo22Hx8ORqRSuUwlmmDyuzB4 brFYIWXeypSr
8ZVVCGVy8saN3W9bLFFTGJkfwHpN55Dmwhhgr32MoXiAtxaprnC/rvDfZBIx ZjQEjRg1qrS8
pp+wkaXIIYwDGFXrlMI92tAKvUV7hKHLNaSqtEKS3o8tfQruBR8/WG4IHTEb RTabRFE09HlK
eYoiU1eo42CVkPizWGMeT2dQ1nk+a/Cmc9K1O2kSjwenbcqC3IOSvMlIFLVB kjTDrE7J/yCJ
g1uNL6R+94RMrJXKUZSQitK/qxj7MOQG4sazU+c6vH4NjU9e4jUjjbbWJWxE bpz3d0PzF525
U2HrcCRLY0WZotoAD8cjeOHyQ3jh6Dg8slg5PyjkgxFZXeMcTk4gp36BlFuE mgOkoYugClti
3gZjoFSW6kJtiRns0Ya7CCD4V4g9rNG7v0ONsK7JafuLgUoZI2k9gVWQ7jD9 zg1trKba2s7d
rtoPeDyIMcgeey/cA3bW3mYYLkqoIfxM8Onfv757937kwAx6+XM/rlyQ8fTx 3tPK0thQkgYL
EDIVevAvaXdeFo+3MRT+081ft9apIhs1BbvT6oaesHsUoe3pF/1OD8lzVlDi zQHD2KUjenle
XotcZkAx1vw0uh5wLYGhPXwoL6fcMa+WF8u3y8+rt+9fuWLQf5xHviM8rTTB g7c/wfPl6urD
8myRpG3eY/dKDPPunhQ6M/RVZFncQTrl7mdi2vr0KnVAKdRtVMEoU+1e7l0y awvgU86acXxo
8065J8J3guSbli3M2O3Qq4N+SEjn4s+BaGj25Da7VlS5fjyjYszgZ7ZZn1wB 9r6fwpMy5QeQ
RD0c3wljosSPxFBw6tp4rOebmBFp6mW5/agK6ia3k3o56Lk6DdtmgMIVPMul 4wWlJboQHxfO
0HZ6+A5q6a+CSA9a1CbuAzFE7+gBe9NTenirJ6uLb5dni1mTl8F0PBfz6sPl H4urFnMwTA1P
7yrWCE77ee9KT4VquMnYHwfIb9k9rN5qHJ8lB969ezoYFO6P+N1xs2a65lUc StwwpRCrd6B7
d7+VRJuY+mJ2UTHw4Ak+YqHw2u8vJndPeFxizwlamnUkZFPPA5AtQ3sK5fJ8 dbTNe5g9JjvA
+4gbwVtSVOSbSHdMOIgt0Na+pnlAYOJjqGoGiP7YHTa8hHSIkWQtOeLj9o7E QZNLcrOHG1q7
Hp4YtltsaivT5McknEBtG9WYlI44MxwizESPPkk/GYHchiaBDb3DHAh3CO/Y xGvTO1Ksoa5g
vW+MnPpOkoM63e3ZJ83vHGy0Knq58PY8KQ3D2/FfEdq0jUkSYT3D67LFWp13 7u8ndoXdGzd2
R+NbSRjKeU8lfPPT3ktXM5g83I12j9O6HAeVtgODMKjzrDry1yOA7nbXS3eT /wFQSwcI3Dkw
bywFAACQEQAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAABTAAAAVGVzdFNl dFJlZ3Jlc3Np
b24uZGlhZ3JhbS9zcmMvc2ltcGxlL2RpYWdyYW0vZWRpdC9jb21tYW5kcy9M aW5rUmVvcmll
bnRDb21tYW5kLmphdmHdVt1v2zYQf7b/imtRFHKQyi2wNyPAukwYjKV2YXvo Y0FLZ4crRWok
1aQY8r/vSErWhx07bpc97MGQfLzP3+94uvHFEC6AfuNhwdIvbItgeF4IjDPO tprlMWbcxqnK
cyYzMxkO6VRpC0pvY0wFLwzSqcadSpzcY1parmRyn2LhXiaPGulSWp5jPH2f scKytcAn6H7U
aqvRmA9Kcqv0QQvMN/TuzJL5+k9M7UGtLWnVbl3+SnZqia/Dc4GmFKc9uJj2 W7GHBwGYCMxR
2srfmZ40/lWisSZeoNKc3CxQMIerueXFIhw2xFT03XD5ZdKTfVAZir5wRsK+ rMN9oQRPOZp4
6Q9/YQanFvMlUimWp668j07lG+UwvvD99PMWJWpmMQudVa7pHFLBjAGXWF1I hQfgvUWCCvah
gr+Hw4HzOui6HTi/g0Lzr/QXNlwyAVxa0JXnX7km0n3vPdm+6hRQIkscSWcb Srw7aRigOABC
dIRdqFpgRHAMBqYsUEeVKN6ivWFrFNHoElqytpfW0WhCDvZAgqu26U4cee0A R1dlLrJ2ADoP
ugGBru4M7w7pPjwBprVSApmElMkwVTAKEPANRBsmDMLVFVCMqmlWynUQ6XBp LJMpqo2HOhhR
3bbUEryhy/ah8nQAjys4Qke8SOaLaTJbfV7O/1hcJ133lGxtu1SlTjFA8+PB Vu8XvyWrR4Ot
mCYkmmC9ao/jrZWlbDBrQ96vYof8i6jqiRbMbozA69fVHeifjI4w4C2tTx48 mY6xaORap11S
CNwc47WSlnGqo8u3H3LH4nkFSGtrihkFGzjsfNJgeWoC+qlLpsZqMrbGpTCI ffdy431//unt
23fRLvglhAtSQ3xZAXH6ghwjrIbtOQkzPuM+Ye2G/58SFgqviauhPoOwzlIB maom2ydub4Ms
6m84kIfnpUuvWZUIxI0agb3V6o6+nXtrV0N/e35WQHsrR/4Bw8jDMHg5lV+Z 4BlQjaUbr4Yi
7r6wIAgdqLacl6MJjMevZvPZm9nN8s27V882XfV/Nlr1I3O1QW4qBG6ZWFri uQHvu1uhX9oJ
ZpvmN7uL150m7ZvQCRVT9vPfO6Lmov5w/rvxc0b+lc3+pXrW/J1BM0R8VlW4 KKwN+6vF0537
MRl2pc4XtI7gx+xu2TzXa4vmA17rTfQ7cu18PP61XI94beX6MPwHUEsHCIhp FUt5AwAAkA4A
AFBLAwQUAAgACAARBBs7AAAAAAAAAAAAAAAAUQAAAFRlc3RTZXRSZWdyZXNz aW9uLmRpYWdy
YW0vc3JjL3NpbXBsZS9kaWFncmFtL2VkaXQvY29tbWFuZHMvTm9kZUNyZWF0 ZUNvbW1hbmQu
amF2Ya1W30/bMBB+Tv6K2wtKUGXeVyENdUWqNgoCtO3VTa7BW2JntrOCJv73 nR23+dEiChpS
lfR8993dd+evnJ3GcAr0OYtrnv3iBYIRVV0iywUvNK8Y5sKyTFUVl7mZxjGd Km1B6YJhVora
IJ1q3Lmw+SNmjRVKzh8zrN3L9MUg3UgrKmSLi5zXlq9KPML3RqtCozFXSgqr 9MEIrNb07sLm
16ufmNmDXgV5bWFd/UoOemGz9nmLpinfh7AIEK8Gu4LtUx16XcxLrFDae7K8 MbSbAw0uwLyv
CI2/GzTWEA1yLYpG421reTeORm4x1HQsllSWuyVi3wRuuv0LW3qlciynI+OS jGPbnX9c8ow2
5olgzk795n8qUKKmqvL2DjSrUmSQldwYcDBtyYE/wEeLRC3sUwt/4zhymNEQ NHKoUYDdA0wO
MQLEV0p4UWSaGnVCX1mB9itfYZmkE5BNWU680zSOnntpLxc/ruYf6aQueYaw EfYBDG4LvVeu
6iR9oUKtLN0SzCHcFyj2In1N2+NMScsFgcA5JAf7SB1EeE9Sykt/rpHZNjJx DURiDUkHJqSx
XGao1uDm3eaMhsnag50tZV2pLeQzfTTaRsvOa8TVSyNaKVUipzguWx3D0HfA s7qh1XoNa0fm
QEAgVwHzO42mtSVjNYOqfU5c350sEjFrlYJ90GpD+7cnsb5Gt18gcRPIILIG W89wsby7v1jO
5izz83L+jjEK9fcI1CZw7L+mB3bA0eu9HOku3iQp43medGlbwFztVKN3Ntm1 1zbkXY9aH0ab
vNzhDNPtpjOgm5HP9ZeBaRR25BD/KJFDv58RzxP4n0PsSz9g7/2t96yH085t LOPucgwN564r
GPslHtIh0goIWXxWFV0pL0U9Dnql+mxjcDfAWSm8ZEpLSpq8UTYGsenhHLSJ N5z+a0GL2iR9
IAfRO2rjt7/OHRNbw3m/n45SImAr3ePcfTEbYn0495oNJyd7eVhfZzqxG/pg cBhfHS90tMPP
8T9QSwcIcUi2J/ICAADGCQAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAABm AAAAVGVzdFNl
dFJlZ3Jlc3Npb24uZGlhZ3JhbS9zcmMvc2ltcGxlL2RpYWdyYW0vZWRpdC9j b21tYW5kcy9T
aW1wbGVDcmVhdGVTaG9ydGN1dERlY29yYXRpb25zQ29tbWFuZC5qYXZhzVXb TuMwEH12vmK2
QqsEgat9riptRYtULRRE0fK4MsmQeknirO1w0Yp/37Hd0qQXyuM+pLVjz5kz Zy7pH0dwDPT0
o1qkjyJHMLKsC+SZFLkWJcdMWp6qshRVZgZRRKdKW/gtngRvrCz4mSoKTK1U FR1vnU4tamGV
3nF0IY1dAyqdc0wLWRskdxrfffLJC6aNw5+8pFi7xWCvkW4qK0vk01Emaivu C/zE3Wutco3G
XKpKtqm2LbB8oLUzm4yqSlmxl0frpvs9Fylhvu69arWojPD68dv1WhQTEl5W +ViVQu72lJP5
KginFiG0laPM+P8bNE1hDyKsEt5IrvFPg8YafqZRWPwp8fkmvDqI4kJ6z1yH zejeUKyp7QS5
pHgQdqU4d1zWRbOrVmuhifmlytBLeE1bMugf+0r/nmPlChKzUPPNfSFTSAth DMw9WAh5viB4
qrqxy6T3bJZUAV8sUnARYx9FBH+jiDmnrOuVObes1vKJtuBaAMrXMZpUy5rq xHXYB2aB7ueI
xsSQ7a8owPbuBJywQNphZd3yxFl7ek+0axFMKDLGTFOjjjcgeoESrDiZ3gnk aO+UfjQ0XfBc
FmjitY8kGUC/fzS7mp3OLuan344IuCMGDDe9DyL29j8ptNUgvkDXhDf4B/Hs QppN7Vq40Jqo
zgfjhi4WaFXlEhJvQCYHNdHKEhxm0BkIkKkwWfFO2kV4F2/OQijDvw92PVRB Vg8qAbvQ6tnA
9oD2YT6Qebya/yAtZbOTXS6XZzHVATXuQpgZNRftgkyHxa3oems7hPiQSUKO vKaMV8GX2/nM
OlkdhK/MDWhOZeyDp6J359xPjGAsH8CnBL4MoWqKAr5+9VjOpvWtiHurQuwl MAxXKc6tBmCs
ZQRmadN6NYT2d4XjdDa/Hc3OJiEsxlMvQdtz4Mm2sbhBO1eNTrHNbrspd9pS eGO0QhYmTnjd
2HhJoFe60TsdU/N3hjC/vBpPLn5Nxzsd7FDM4Yosi7d9h4DeovBotI2uusVN 2X2++tF5FYdG
eYv+AVBLBwhpLTOiBAMAAPQIAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAA AGMAAABUZXN0
U2V0UmVncmVzc2lvbi5kaWFncmFtL3NyYy9zaW1wbGUvZGlhZ3JhbS9lZGl0 L2NvbW1hbmRz
L1NpbXBsZVJlb3JpZW50Q29ubmVjdGlvblZpZXdDb21tYW5kLmphdmGdVN9v 2jAQfnb+Cq/q
AyBqtNehSkMdk6Z1dCpV+2ySI3h17Mh2aKWp//vunABJmxW2B0LufD++u+9z JqOEjzj+Jkkp
00eZA/eqKDWITMncyUJApoJIbVFIk/lpkuCpdYH/klspqqC0uFY+HPzW5QJS rUoPmOVAuMoE
VYD4NstkGeRKw/R47E9ncwfe/7BGBet6M6BYi+Ck8TINyhpxd3iXeo6olcm/ 2EIq05ueY/qu
H42HFSKGZlRxVf/fgq90OFqBwOyW1K0zW3lEmYYOvKb40bLGBhmHm2d5/956 o+8VPCElk1Fk
93MOBpwMkNU8VyutUp5q6T1fRrJvwToFJlxZYyBCpAoNSA7PAXCshLH3ZuG/ k4RRR9Ztyagn
K53aoskPKuCAI0WL+H0vtcZ7AtIBQmR/lwGHtjXmy+DQ4lquQA8RPmO+KsEN XoXF8zE3ldbD
acJeTsBKV4LnEGbrNYKE7KvS4Ad1D8LLt/S45AMyhu1NCMqiV8RBhyLSRH2Z WvNBzPtwWYOJ
5ZiDUDlD3R6se/R4i6FuR7Ex8SXZR8UBxVtkJ87VYg9rzA+wm9maLh1mTyq8 tSrjvluyXyp1
o7BRXrS8uMt/aepsiNPzziXnmZ0/Q1oFeFBhU/uipF5/jnjZtcftxSiztjVI JA7wthJXxFkb
7id+tiB3ulE6w5RT1H025ZPJ+eJmcbG4Xl58PMcOtK5Yl7RExvANL21B0UFL UD349sCi8d+4
osYDFOV9rXOqRkCWtnIpRLmx6PN73y7kTjp8DoadmMa5qxjPGq11GBQGnm6+ d1yNtl+SP1BL
BwgWK8kuXQIAAOoGAABQSwMEFAAIAAgAEQQbOwAAAAAAAAAAAAAAAE0AAABU ZXN0U2V0UmVn
cmVzc2lvbi5kaWFncmFtL3NyYy9zaW1wbGUvZGlhZ3JhbS9lZGl0L2hlbHBl cnMvTGlua0Vk
aXRIZWxwZXIuamF2YU3MMQoCMRCF4X5OMXWK5AA2IixY2HmCMXnEYbMhZCII snd3iY3Fq36+
Fxyx42OBmsRVMth0awU+qeQum0fS4Z8oDd1ORMFNcc6o6DKQfvb1KBo5FjHj m9Z1OdR1IsZ7
oCbj+/y9iOEvfminL1BLBwiSUZ8HbAAAAIQAAABQSwMEFAAIAAgAEQQbOwAA AAAAAAAAAAAA
AE4AAABUZXN0U2V0UmVncmVzc2lvbi5kaWFncmFtL3NyYy9zaW1wbGUvZGlh Z3JhbS9lZGl0
L2hlbHBlcnMvTW9kZWxFZGl0SGVscGVyLmphdmFNzDEKQjEQhOF+T7F1iuQA NiIINlaeYM0O
MbjvGbIRBPHuPmJjMdXPNykQB96WqEm+SwF7XZohapXSZYnQOuIN1tB9R5TC FPuCFV0G9Gef
V6uZs4k7nx8KO27sNBXjNbCq82UeH8TxF9/0oS9QSwcIHJE0nmwAAACFAAAA UEsDBBQACAAI
ABEEGzsAAAAAAAAAAAAAAABNAAAAVGVzdFNldFJlZ3Jlc3Npb24uZGlhZ3Jh bS9zcmMvc2lt
cGxlL2RpYWdyYW0vZWRpdC9oZWxwZXJzL05vZGVFZGl0SGVscGVyLmphdmHT 1+JS0FIAYn2u
gsTk7MT0VIXizNyCnFS9lMzE9KLEXL3UlMwSvYzUnILUomJrLi59LbAOh/TU vNSixJLUFIje
0qSczGSF5JzE4mIFv/yUVFegLg+wJoXUipLUvJRihWCwuU6JxciS1Vy1XABQ SwcIhP7WBGwA
AACEAAAAUEsDBBQACAAIABEEGzsAAAAAAAAAAAAAAABTAAAAVGVzdFNldFJl Z3Jlc3Npb24u
ZGlhZ3JhbS9zcmMvc2ltcGxlL2RpYWdyYW0vZWRpdC9oZWxwZXJzL1NpbXBs ZUJhc2VFZGl0
SGVscGVyLmphdmGtVduO2jAQfU6+YrTah4C6QX1GK5VCpCJBQMBDV1WFvMkQ rCZOajttUcW/
184VQnbL7YGQjD3nnLnY0+ua0AX165kJ8X6QAEHQKAnR9ikJOIls9Km0txgm yEXfNNVizCXE
PLDRC2ki0A6ijc1TJmmEthdHUczUH8/fCfPtYax8BJU4zA39a0DG5zqjepe7 BHN3J8QImVwp
wwIDKiTfXYgwPoC40FWnLs+cPXhV1MSTjjJ9yUzXY41rkIH/i3qXyuL4M0Uh hT3kSCQW8S1y
621YCwyJpDETW5rcCDhSTx7v7qOuAFvgBjkyD2+EyypQNGQFZfa62WH6FCBD rpLh58cqfQ2p
B15IhIBldrY+E4F1DQH/SGS+gNMegb+maWhY4xjX0MBGgSykSrkHG8pICEvJ KQvAGY1X6/ls
Mh6+rIez6XTgjuAZHnQTQRIrrx0UB+uhD73eoztzn9zJ8unj45WEw5m7cr6u 1s7EmTruar16
mTua0YuZVPEB5mUEncyLKHks0VPfcNL1375DgLJptVpqA6pwHZVLw
Re: Regressions in EolSet since SVN r558? [message #482539 is a reply to message #482536] Wed, 26 August 2009 23:39 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Antonio,
Apologies for this regression. Ivosh also ran across this and reported
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287756. I'll fix (and add
some tests for it so that we avoid future regressions) tomorrow morning,
and release a new version.
Dimitris
Antonio García Domínguez wrote:
> Hi list,
> try {
> storage.clear();
> empty.
> Cheers,
> Antonio
Re: Regressions in EolSet since SVN r558? [message #579724 is a reply to message #482536] Wed, 26 August 2009 23:39 Go to previous message
Hi Antonio,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287756 I'll fix (and add
Dimitris
> Hi list,
> try {
> storage.clear();
> empty.
> Cheers,
> Antonio
Previous Topic:Regressions in EolSet since SVN r558?
Next Topic:EMF ChangeRecorder in eol
Current Time: Mon May 28 05:26:01 GMT 2018
Powered by FUDForum. Page generated in 0.01794 seconds
