ANT Script for ETL [message #481799] |
Mon, 24 August 2009 11:29 |
Originally posted by: d.clowes.lboro.ac.uk
Hello all,
I've been trying to get this script (script at bottom) to work for a
couple of days and don't seem to be able to spot what is going wrong. The
error message is:
BUILD FAILED
....ant-builds\ETL_DocModel.xml:63: The following error occurred while
executing this line:
....ant-builds\ETL_DocModel.xml:79: Model 'DocumentStructure' not found
ExecTransformation:
[echo] ../etl/DocXML.etl,DocumentModel,DocumentStructure
[epsilon.etl - DocXML.etl] EXCEPTION: Model 'DocumentStructure' not found
[epsilon.etl - DocXML.etl] at
org.eclipse.epsilon.eol.models.ModelGroup.<init>(ModelGroup.java:40)
org.eclipse.epsilon.eol.models.ModelRepository.getModelByNam e(ModelRepository.java:68)
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.popu lateModelRepository(ExecutableModuleTask.java:177)
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:106)
org.eclipse.epsilon.workflow.tasks.EpsilonTask.execute(Epsil onTask.java:41)
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
<?xml version="1.0"?>
<project>
<!-- Source Details -->
<property name="SourceDataDir" value="../data/DocModel" />
<property name="SourceUri" value="DocumentModel" />
<property name="SourcePrefix" value="DocumentModel" />
<property name="SourceMetaModel"
value="../models/meta-models/xml/DocumentModelSchema.ecore" />
<!-- Define files here as order is important in creating the document
Therefore can not use loop of directory. -->
<filelist id="SourceFiles" dir="${SourceDataDir}"
files=" XMF_Prep_Main_Section_1.XML
XMF_Prep_Main_Section_2.XML
XMF_Prep_Main_Section_3.XML
XMF_Prep_Main_Section_4.XML
XMF_Prep_Appendix_Z.XML"/>
<!-- Target Details -->
<property name="TargetFile" value="../models/pop.model" />
<property name="TargetUri" value="DocumentStructure" />
<property name="TargetPrefix" value="DocumentStructure" />
<property name="TargetMetaModel"
value="../models/meta-models/tdl_v3a.ecore" />
<!-- ETL Details -->
<property name="ETLFile" value="../etl/DocXML.etl" />
<!-- ANT Taskdefs for foreach loop -->
<taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
<target name="main">
<!-- Register the meta-models -->
<epsilon.emf.register file="${SourceMetaModel}"/>
<epsilon.emf.register file="${TargetMetaModel}"/>
<!-- Load the target file. Note path to file defined in property
targetFile -->
<epsilon.loadModel name="${TargetPrefix}" type="EMF">
<parameter name="modelFile" file="${TargetFile}"/>
<parameter name="metamodelUri" value="${TargetUri}"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="true"/>
</epsilon.loadModel>
<!-- Load each model and execute the transformation -->
<foreach param="SourceFilename" target="ExecTransformation">
<path>
<filelist refid="SourceFiles" />
</path>
</foreach>
</target>
<target name="ExecTransformation">
<epsilon.loadModel name="${SourcePrefix}" type="XML">
<parameter name="modelFile" file="${SourceFilename}"/>
<parameter name="metamodelUri" value="${SourceUri}"/>
<parameter name="storeOnDisposal" value="false"/>
<echo>${ETLFile},${SourcePrefix},${TargetPrefix}</echo>
<epsilon.etl src="${ETLFile}">
<model ref="${SourcePrefix}"/>
<model ref="${TargetPrefix}"/>
</epsilon.etl>
</target>
</project>
Thanks for any help,
Darren
Re: ANT Script for ETL [message #481808 is a reply to message #481807] |
Mon, 24 August 2009 11:56 |
This is a cut down version with all the non-essential properties replaced
by their direct text. Is that what you required?
Darren
<project>
files=" XMF_Prep_Main_Section_1.XML"/>
file="../models/meta-models/xml/DocumentModelSchema.ecore"/ >
<epsilon.emf.register file="../models/meta-models/tdl_v3a.ecore"/>
targetFile -->
<epsilon.loadModel name="DocumentStructure" type="EMF">
<parameter name="modelFile" file="../models/pop.model"/>
<parameter name="metamodelUri" value="DocumentStructure"/>
<path>
</path>
</foreach>
</target>
<epsilon.loadModel name="DocumentModel" type="XML">
<parameter name="metamodelUri" value="DocumentModel"/>
<epsilon.etl src="../etl/DocXML.etl">
<model ref="DocumentModel"/>
<model ref="DocumentStructure"/>
</epsilon.etl>
</target>
</project>
FUDForum. Page generated in 0.05300 seconds
