Home » Modeling » M2T (model-to-text transformation) » [XPAND] clear Xtend cached objects
[XPAND] clear Xtend cached objects [message #481607] Fri, 21 August 2009 18:42 Go to next message
ekkehard gentz is currently offline ekkehard gentzFriend
--------------030704080300020508000800
if my whole workflow is running, then I need much memory -
in the different parts of my workflow I'm using Xtends 'cached', which
speeds things up
now the question is:
can I explicitely clear the Xtend caches ?
at some nodes of my workflow-tree this would be a good idea and help to
free memory
any idea ?
per ex. using a Java extension
thx for any hints
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
<html>
<head>
</head>
if my whole workflow is running, then I need much memory -<br>
speeds things up<br>
<br>
now the question is:<br>
can I explicitely clear the Xtend caches ?<br>
free memory<br>
<br>
any idea ?<br>
per ex. using a Java extension <br>
<br>
thx for any hints<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------030704080300020508000800--
ekke
independent software architect
blog: http://ekkes-corner.org
Re: [XPAND] clear Xtend cached objects [message #481730 is a reply to message #481607] Mon, 24 August 2009 06:41 Go to previous messageGo to next message
Knut Wannheden is currently offline Knut WannhedenFriend
Hi Ekke,
> speeds things up
> free memory
The cache is only valid (and thus kept) within the same invocation of Xpand or
Xtend. So the cache should automatically be made available for garbage
collection inbetween the different parts of your workflow.
Hope that helps,
--knut
Re: [XPAND] clear Xtend cached objects [message #482023 is a reply to message #481730] Tue, 25 August 2009 07:35 Go to previous message
Knut Wannheden schrieb:
> Hi Ekke,
>> which speeds things up
>> to free memory
> Xpand or Xtend. So the cache should automatically be made available
> for garbage collection inbetween the different parts of your workflow.
> Hope that helps,
> --knut
thanks, knut,
good to know that the cache is only bound to the active (Xpand or Xtend)
workflow component,
so only the models stored in slots and workflow properties are available
thru the whole workflow.
ekke
ekke
Previous Topic:Protected Regions in Acceleo for Java
Next Topic:[MOFScript] Is there a plan for releasing MOFScript for Eclipse Galileo?
Current Time: Sun May 20 17:58:30 GMT 2018
Powered by FUDForum. Page generated in 0.01776 seconds
