Re: Problem with generated wizards [message #480487 is a reply to message #480341] |
Mon, 17 August 2009 11:35 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Stephane,
Could you possibly come up with a minimal version that reproduces this
problem so that I can investigate? Off the top of my head, since it
works through the preferences, but not through plugin.xml, I suspect
that you may not include the folder in which the .ewl module is
contained in the build. Other than that, preferences and contributed
extensions are handled uniformly (see getEwlURIsForEObjects(...) in
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/plugins/org.eclipse.epsilon.ewl.emf/src/org/eclip se/epsilon/ewl/emf/AbstractContributeWizardsAction.java)
Dimitris
Stephane wrote:
> Hi list,
> I have a project with wizards and operations files plus plugin.xml
> declaration of wizards for my metamodel, but it doesn't work as it
> should : there is only one eclass for which wizards work.
> Here is the tar.gz of the workspace:
> http://stephaneerard.fr/workspaces-epsilon-tools.tar.gz
> The project in question is eclipse-project-0.1.
> The working wizard is src/eclipse_project/Project/Project.ewl
> I think the problem comes from the plugin.xml declarations as I tested
> the ewl files using epsilon prefs and it worked.
> I have tried two different nsURI declarations, like:
> "http://eclipse-project/0.1"
> and "http://eclipse-project/0.1/Project/Building/Command"
> for the eclipse_project::Project::Building::Command eclass as example.
> There are no error or warning markers nowhere regarding this problem
> (existing errors correspond to generated and copied files from
> epsilonTools to eclipse-project, didn't clean the workspace, just delete
> epsilonTools/src/src and actions dir somewhere else within to get them
> away) :(
> Thank you !
Re: Problem with generated wizards [message #574177 is a reply to message #480341] |
Hi Stephane,
Dimitris
Stephane wrote:
> Hi list,
> away) :(
> Thank you !
FUDForum. Page generated in 0.01732 seconds
