Home » Modeling » Epsilon » [EGL] CrossReferences(Problems retrieve CrossReferences in Epsilon)
[EGL] CrossReferences [message #479593] Tue, 11 August 2009 16:39 Go to next message
Ivo(sh) Musil is currently offline Ivo(sh) MusilFriend
Hi All
I'm using EGL to generate (hypertext) HTML presentation of Ecore model.
I would like to have at any EObject section named "Where is used" which include links to all related EObjects (not only referenced and contained - it's easy - but these pointing to this EObject too).
I have no success even I tried lot of ways how make it work:
a) if I try use eCrossReferences() method on EObject then I will get some crossreferenced EObjects to my EObject. Unfortunately I have no chance to get associated feature because EObject.eCrossReferences() returns EContentEList.FeatureIterator but Epsilon identifies answer like untyped Sequence
Example:
for (n in o.eCrossReferences()) {
n.feature(); -- undefined method
Maybe support of casting in Epsilon? Or possibility to include some Java code into EGL?
b) I tried to use EcoreUtil.UsageCrossReferences class to retrieve dependencies but I have no more ideas how to specify and access this (static inner) class in Epsilon (EOL/EGL):
var a: EcoreUtil.UsageCrossReferences;
-- unknown class
var a: org.eclipse.emf.ecore.utils.ECoreUtil.UsageCrossReferences;
-- unknown type org
var a: "org.eclipse.emf.ecore.utils.ECoreUtil.UsageCrossReferences"
-- unknown class
var a := new Native('org.eclipse.emf.ecore.utils.ECoreUtil.UsageCrossRefe rences')
-- unknown class
Maybe some classpath and/or classloader magic ...
Thanks for help and sorry for my english
Ivo(sh)
Re: [EGL] CrossReferences [message #479613 is a reply to message #479593] Tue, 11 August 2009 17:18 Go to previous messageGo to next message
Louis Rose is currently offline Louis RoseFriend
Hi Ivosh,
Ivosh Musil wrote:
> Hi All
Perhaps the EGLDoc example, which also generates HTML from Ecore models,
would be useful for you? Here's a link:
http://www.eclipse.org/gmt/epsilon/examples/index.php?exampl e=org.eclipse.epsilon.examples.egldoc
> untyped Sequence
The EObject interface defines EList<EObject> as the return type of
eCrossReferences. Are you using a different implementation of EObject?
Where does the EContentEList.FeatureIterator come from?
> Example:
I ran an experiment with the following EOL code on the Ecore metamodel:
EClass.all.first.println();
for (crossRef in EClass.all.first.eCrossReferences()) {
(crossRef.name + ' ' + crossRef.eClass.name).println();
which prints:
EClass [name=EAttribute,
instanceClassName=org.eclipse.emf.ecore.EAttribute,
instanceClass=interface org.eclipse.emf.ecore.EAttribute,
defaultValue=null, instanceTypeName=org.eclipse.emf.ecore.EAttribute,
abstract=false, interface=false, ]
EStructuralFeature EClass
name EAttribute
ordered EAttribute
unique EAttribute
lowerBound EAttribute
upperBound EAttribute
ETypedElement EClass
Property 'name' not found in object EGenericType []
(/Users/louis/Code/eclipse/workspaces/galileo/runtime-epsilo n/Scratchpad/CrossRefs.eol@3:14)
The first line of output tells us that EClass.all.first returns the
EAttribute class.
The second line of output tells us that the EStructuralFeature object
(of type EClass) cross references the EAttribute class.
The third line that the name object (of type EAttribute) cross
references the EAttribute class, and so on.
Finally, we get an error because name isn't defined on EGenericType.
This could be fixed with the following EOL code, which only prints an
object's name if the name property is defined for that object:
if (crossRef.name.isDefined) {
} else {
crossRef.println();
Apologies if this explanation is not very good. I always find ECore's
self-referencing nature a little hard to describe. Let me know if this
is unclear, and I'll devise a better example that doesn't use ECore.
> code into EGL?
A bit more information on Epsilon... EOL, and hence EGL, is dynamically
typed - types aren't checked until runtime. Casting is not necessary,
because an object's type is always known at runtime.
Louis.
Louis Rose
Research Student
Department of Computer Science,
University of York,
Heslington, York, YO10 5DD, United Kingdom.
+44 1904 434762
Twitter: @louismrose
Re: [EGL] CrossReferences [message #479738 is a reply to message #479613] Wed, 12 August 2009 09:34 Go to previous messageGo to next message
Hi Louis
thanks for your quick answer.
Louis Rose wrote on Tue, 11 August 2009 13:18
I know this excellent example and it was probably main invention for my HTML transformation Smile.
Please take a look at JavaDoc
It's a little messy - method eCrossReferences() returns officially EList<EObject> but you can cast it to its subtype EContentEList.FeatureIterator and use additional method feature() which return feature where on referencing EObject is reference to referenced Object:
Example:
Model
class A {
id String nameOfA;
class B {
id String nameOfB;
ref A pointer;
Pseudocode:
var a: A;
a.nameOfA := 'My name is A';
var b: B;
b.nameOfB := 'My name is B';
b.pointer := a;
a.eCrossReferences() returns EContentEList.FeatureIterator like { b }
but then (in Java) is possible to call method iterator().next().feature() which returns EReference named 'pointer'
Hoped output:
This object _a_ is used (referenced) in object _b_ in reference _pointer_
I understood earlier that Epsilon is dynamically typed. But this (IMHO) dirty casting trick in EMF API is probably in pure dynamic language unsolvable.
I will focus more on second main way now:
Ivo.corpus.cz wrote on Tue, 11 August 2009 12:39
Thanks for discussing
Ivo(sh)
Re: [EGL] CrossReferences [message #479767 is a reply to message #479738] Wed, 12 August 2009 13:06 Go to previous messageGo to next message
Ivosh,
Ivosh Musil wrote:
> Hi Louis
No problem! Thanks for the response, I think I understand the issue
better now :-)
> http://publib.boulder.ibm.com/infocenter/wasinfo/v6r0/topic/ org.eclipse.emf.doc/references/javadoc/org/eclipse/emf/ecore /EObject.html#eCrossReferences()
> Object:
Got it! Thanks very much. So, EOL wraps Java types. Instances of
java.lang.Iterator are wrapped to EolSequence. As
EContentEList.FeatureIterator implements Iterator, it is wrapped to an
EolSequence. Consequently, the feature() method cannot be accessed.
> Example:
> Model
> class A {
> id String nameOfA;
> class B {
> id String nameOfB;
> ref A pointer;
> Pseudocode:
> var a: A;
> var b: B;
> b.pointer := a;
> Hoped output:
>> dynamically typed - types aren't checked until runtime. Casting is not
>> necessary, because an object's type is always known at runtime.
> unsolvable.
I agree. It might be possible to fix this in EOL, but to solving this
problem would likely involve patching the type wrapper. I'll reply to
your original post to discuss your second approach, before we decide
whether a patch is needed.
Louis.
Re: [EGL] CrossReferences [message #479768 is a reply to message #479593] Wed, 12 August 2009 13:09 Go to previous messageGo to next message
Ivosh,
As promised, comments on plan (b)...
> -- unknown class
> -- unknown type org
> -- unknown class
> var a := new
> -- unknown class
Given the problems you highlight with approach (a), this seems like a
good alternative.
I think that you've already discovered how to load this class - use an
Epsilon tool. Do post again if you have any further troubles getting
this to work.
Louis.
Re: [EGL] CrossReferences [message #479779 is a reply to message #479768] Wed, 12 August 2009 13:38 Go to previous messageGo to next message
Thanks Louis for your support ...
- "casting" solution on (a) will be IMHO too complicated and unclean -
better stop thinking about it
- with "Java workaround via Epsilon Tool" on (b) helped me Dimitrios in
another thread - seems that this will be right solution.
THX
Ivo(sh)
Re: [EGL] CrossReferences [message #479813 is a reply to message #479779] Wed, 12 August 2009 15:25 Go to previous message
No problem. Good luck with the project. I think this plan (b) will be
successful.
Louis.
> THX
> Ivo(sh)
Re: [EGL] CrossReferences [message #573762 is a reply to message #479613] Wed, 12 August 2009 09:34 Go to previous message
Hi Louis
I know this excellent example and it was probably main invention for my HTML transformation :).
Please take a look at http://publib.boulder.ibm.com/infocenter/wasinfo/v6r0/topic/ org.eclipse.emf.doc/references/javadoc/org/eclipse/emf/ecore /EObject.html#eCrossReferences()
Example:
Model
class A {
id String nameOfA;
class B {
id String nameOfB;
ref A pointer;
Pseudocode:
var a: A;
var b: B;
b.pointer := a;
Hoped output:
Ivo(sh)
Re: [EGL] CrossReferences [message #573848 is a reply to message #573762] Wed, 12 August 2009 13:06 Go to previous message
Ivosh,
Ivosh Musil wrote:
> Hi Louis
better now :-)
> Object:
> Example:
> Model
> class A {
> id String nameOfA;
> class B {
> id String nameOfB;
> ref A pointer;
> Pseudocode:
> var a: A;
> var b: B;
> b.pointer := a;
> Hoped output:
> unsolvable.
Louis.
Re: [EGL] CrossReferences [message #573904 is a reply to message #479768] Wed, 12 August 2009 13:38 Go to previous message
THX
Ivo(sh)
Re: [EGL] CrossReferences [message #573952 is a reply to message #479779] Wed, 12 August 2009 15:25 Go to previous message
successful.
Louis.
> THX
> Ivo(sh)
Previous Topic:Trouble accessing java objects
Next Topic:Enumeration arguments in operations
Current Time: Thu May 24 23:43:52 GMT 2018
Powered by FUDForum. Page generated in 0.02603 seconds
