Re: BIRT 2.5 in galileo broken??? [message #468315 is a reply to message #468273] |
Wed, 05 August 2009 01:46 |
Dean,
I have not seen this issue with the 2.5 build. Can you retry
downloading and starting with a -clean option?
Jason
Dean Hiller wrote:
> I decided to download the latest eclipse bundle with BIRT reporting from
> eclipse downloads and BIRT seems to be horribly broken. I do the same
> stuff I did in BIRT 2.3.2 for adding a JDBC datasource for oracle, and
> it fails with some cryptic error "BIRT Message file
> 'oracle.net.mesg.Message' is missing" and then I do it with postgres and
> push test connection and it never returns....luckily test connection was
> non-blocking so I could cancel out of the dialog. All in all, are other
> people actually seeing this thing work at all?
FUDForum. Page generated in 0.02984 seconds
