Home » Newcomers » Newcomers » JOGL in eclipse
JOGL in eclipse [message #457856] Sun, 02 August 2009 03:08 Go to next message
pdelbarba  is currently offline pdelbarba Friend
I am trying to use eclipse to develop jogl applications and have added the both of the jogl jars as variables to the build path. I'm getting an error "java.lang.UnsatisfiedLinkError: no jogl in java.library.path" whenever I try to run the project even though all of the references to the jars are being accepted in compilation. What is wrong?
Re: JOGL in eclipse [message #467837 is a reply to message #457856] Mon, 03 August 2009 06:07 Go to previous message
Madhu Samuel is currently offline Madhu SamuelFriend
> Thanks
The "java.lang.UnsatisfiedLinkError" is thrown when the program is not
able to find the jogl dll files.
Right click on the java class, goto Run As > Run Configurations
Select your configuration, Open the 'Arguements' tab.
In the VM Arguements, provide "-Djava.library.path=c:\jogl\lib"
where, "c:\jogl\lib" is the folder in which jogl.dll, gluegen-rt.dll,
jogl_awt.dll etc are available.
Previous Topic:scp (secure copy) Export->Other plugin
Next Topic:Eclipse 3.5 segmentation fault on startup
Current Time: Sun May 27 05:33:49 GMT 2018
Powered by FUDForum. Page generated in 0.02522 seconds
