Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Code Coverage
Code Coverage [message #42180] Wed, 23 November 2005 14:35 Go to next message
Mark Levison is currently offline Mark Levison
Does TPTP support code coverage? I've spent 20 minutes browsing the docs
and I can't seem to find an answer to the question. If it does would you
point me to some documentation that describes its support and how to use
it?
If not what coverage tools can you recommend? My requirements
1) Supports branch coverage and
2) understands that some lines have several basic blocks (compound if
statements)
3) Integrated with eclipse
4) Free - I'm not ready to justify licensing fees to my management.
Re: Code Coverage [message #42326 is a reply to message #42180] Thu, 24 November 2005 05:09 Go to previous messageGo to next message
Eclipse User
Originally posted by: markus.milleder.generali.at
TPTP 4.0.1 (what I have played with a bit) only seems to offer method
coverage.
I have used
* djUnit
* coverlipse
for getting coverage from unit tests.
Both are listed at eclipse-plugins.info .
Re: Code Coverage [message #42716 is a reply to message #42180] Thu, 24 November 2005 12:33 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Mark,
Yes, TPTP does support code coverage as a profiling type. However,
TPTP's code coverage is at the method level of granularity. For more
information, see:
Help >> Help Contents >> Monitoring and analyzing application performance >>
Profiling an application >> Using profiling views to analyze data >>
Analyzing method execution >> Viewing code coverage
and
Help >> Contents >> Monitoring and analyzing application performance >>
Profiling an application >> Profiling views >> Using the Code Coverage
Statistics view
Paul
"Mark Levison" <mark.levison@cognos.com> wrote in message
news:cc7d2eb345cb16a51c8943bdc1393ebf$1@www.eclipse.org...
> it?
> statements)
Re: Code Coverage [message #43561 is a reply to message #42716] Tue, 29 November 2005 10:29 Go to previous message
Thanks for the replies in the end I tried
1) Coverlipse
2) djUnit
3) Emma
and for now I've choosen Emma for its speed (even though the eclipse
integration is still very new. Its only serious failing so far its funny
handling of exceptions. If an exception is thrown part way through a
block, it doesn't consider that block covered. This is a bit of hassle
with our unit tests where we check all of our exceptional conditions.
Thanks for the suggestions
Mark
Previous Topic:EXCEPTION_ACCESS_VIOLATION
Next Topic:Can't get UML2 diagrams to work
Current Time: Thu May 23 21:58:40 EDT 2013
Powered by FUDForum. Page generated in 0.04806 seconds
