Re: Yikes! ConcurrentModificationException [message #384229 is a reply to message #384227] |
Thu, 04 December 2008 15:12 |
Tom Eugelink Messages: 817 Registered: July 2009 |
Zooming in on Buyorder... The error is caused by this line:
public void setReindersRelation(nl.reinders.bm.Relation value)
if (value == iReindersRelation) return; // optimalisation and prevent looping
nl.reinders.bm.Relation lValue = iReindersRelation;
if (log4j.isDebugEnabled()) log4j.debug("setReindersRelation: " + lValue + " -> " + value);
fireVetoableChange(REINDERSRELATION_PROPERTY_ID, lValue, value);
if (lValue != null) lValue.removeBuyordersWhereIAmReindersRelation( (nl.reinders.bm.Buyorder)this );
iReindersRelation = value;
try {
if (value != null) value.addBuyordersWhereIAmReindersRelation( (nl.reinders.bm.Buyorder)this ); // <----------------------
} catch (RuntimeException e) { iReindersRelation = lValue; throw e; } // restore upon exception
firePropertyChange(REINDERSRELATION_PROPERTY_ID, lValue, value);
So, if a buyorder is created, it searches for a specific relation as a default value, sets it and because of the 1-N, that buyorder is also added to the relation's collection.
Zooming in again on Relation:
public void addBuyordersWhereIAmReindersRelation(nl.reinders.bm.Buyorder value)
if (value != null && !iBuyordersWhereIAmReindersRelation.contains(value))
java.util.List<nl.reinders.bm.Buyorder> lValue = new java.util.ArrayList<nl.reinders.bm.Buyorder>();
lValue.addAll(iBuyordersWhereIAmReindersRelation);
lValue.add(value);
fireVetoableChange(BUYORDERSWHEREIAMREINDERSRELATION_PROPERT Y_ID, java.util.Collections.unmodifiableList(iBuyordersWhereIAmRei ndersRelation), java.util.Collections.unmodifiableList(lValue));
boolean lWasAdded = iBuyordersWhereIAmReindersRelation.add(value); // <----------------------
lValue.remove(value);
firePropertyChange(BUYORDERSWHEREIAMREINDERSRELATION_PROPERT Y_ID, java.util.Collections.unmodifiableList(lValue), java.util.Collections.unmodifiableList(iBuyordersWhereIAmRei ndersRelation));
try {
value.setReindersRelation( (nl.reinders.bm.Relation)this);
} catch (RuntimeException e) { if (lWasAdded) {iBuyordersWhereIAmReindersRelation.remove(value);} throw e; } // restore upon exception
If the add is commented out, the error does not occur.
For the CME to occur, it must be processing the iBuyordersWhereIAmReindersRelation. In what way will processing the iBuyordersWhereIAmReindersRelation create a new Buyorder instance?
FUDForum. Page generated in 0.26900 seconds
