Home » Archived » EPF » Update manager encounters division by zeor
Update manager encounters division by zeor [message #39018] Sat, 01 September 2007 06:17 Go to next message
Ashkan Kh.Nazary is currently offline Ashkan Kh.NazaryFriend
Using update manager via Configuration window causes an internal error
(/ by zero). Other approaches lead to "No updates available"
Is this a bug?
>>> Data >>>
Eclipse Process Framework Composer
Version: 1.2.0
Build Label: 20070824-2334
<<<< Data <<<<
All other things appear to be OK
Re: Update manager encounters division by zeor [message #39396 is a reply to message #39018] Wed, 05 September 2007 00:19 Go to previous messageGo to next message
Peter Haumer is currently offline Peter HaumerFriend
Hi Ashkan.
Currently, we do not have an update site configured and only deploy updates
via the download page. I suspect that the error you are get from the
Configuration window is an Eclipse bug.
Peter.
"exquisitus" <ashkan.kh.nazary@gmail.com> wrote in message
news:fbb096$i24$1@build.eclipse.org...
> Using update manager via Configuration window causes an internal error (/
> Is this a bug?
> >>> Data >>>
> Version: 1.2.0
> <<<< Data <<<<
Re: Update manager encounters division by zeor [message #41110 is a reply to message #39396] Tue, 25 September 2007 17:07 Go to previous messageGo to next message
Originally posted by: TBFowler.cox.net
Peter,
Is there currently a plan/timeline for having an update site?
Thell
"Peter Haumer" <phaumer@us.ibm.com> wrote in message
news:fbksln$kpb$1@build.eclipse.org...
> Hi Ashkan.
> updates via the download page. I suspect that the error you are get from
> the Configuration window is an Eclipse bug.
> Best regards,
> Peter.
>> Is this a bug?
>> >>> Data >>>
>> Version: 1.2.0
>> <<<< Data <<<<
Re: Update manager encounters division by zeor [message #42049 is a reply to message #41110] Mon, 01 October 2007 19:06 Go to previous message
Not that I know of. I will discuss with the team as is would bring a lot of
advantages.
Peter.
"Thell" <TBFowler@cox.net> wrote in message
news:fdbf9n$tic$1@build.eclipse.org...
> Peter,
> Thell
>> Hi Ashkan.
>> Best regards,
>> Peter.
>>> Is this a bug?
>>> >>> Data >>>
>>> Version: 1.2.0
>>> <<<< Data <<<<
Re: Update manager encounters division by zeor [message #582596 is a reply to message #39018] Wed, 05 September 2007 00:19 Go to previous message
Hi Ashkan.
Peter.
> Is this a bug?
> >>> Data >>>
> Version: 1.2.0
> <<<< Data <<<<
Re: Update manager encounters division by zeor [message #583473 is a reply to message #39396] Tue, 25 September 2007 17:07 Go to previous message
Thell is currently offline ThellFriend
Peter,
Thell
> Hi Ashkan.
> Best regards,
> Peter.
>> Is this a bug?
>> >>> Data >>>
>> Version: 1.2.0
>> <<<< Data <<<<
Re: Update manager encounters division by zeor [message #583915 is a reply to message #41110] Mon, 01 October 2007 19:06 Go to previous message
advantages.
Peter.
> Peter,
> Thell
>> Hi Ashkan.
>> Best regards,
>> Peter.
>>> Is this a bug?
>>> >>> Data >>>
>>> Version: 1.2.0
>>> <<<< Data <<<<
Previous Topic:Follow-up website generation
Next Topic:EPF and proxy settings
Current Time: Tue Apr 16 03:58:53 GMT 2024
Powered by FUDForum. Page generated in 0.09056 seconds
