Home » Eclipse Projects » EclipseLink » TRIM in JPA NamedQuery
TRIM in JPA NamedQuery [message #381079] Thu, 04 September 2008 07:04 Go to next message
Sven Hoffmann is currently offline Sven HoffmannFriend
I'm about to replace TopLink Essentials with EclipseLink 1.0.
At the moment I'm facing the problem that JPA NamedQueries where the
function TRIM is used result in a NullPointerException when parsing the
query.
Is this a known issue and is a workaround available? I did not find a bug
in Bugzilla nor a thread in this newsgroup.
Please find below the Entity, persistence.xml, usage of the EntityManager
and the resulting Stacktrace.
com.kn.persistence.Info.java:
package com.kn.persistence;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.NamedQuery;
@Entity
@NamedQuery(name="Info.findByText", query="SELECT i FROM Info i WHERE
TRIM(i.text) = :text")
public class Info {
@Id
private long id;
private String text;
public Info() {
super();
public long getId() {
return this.id;
public String getText() {
return this.text;
public String toString() {
return this.getId() + "=" + this.getText();
com.kn.persistence.InfoReader.java:
import java.util.List;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import javax.persistence.Persistence;
import javax.persistence.Query;
public class InfoReader {
@SuppressWarnings("unchecked")
try {
EntityManagerFactory emf =
Persistence.createEntityManagerFactory("testUnit");
EntityManager em = emf.createEntityManager();
Query query = em.createNamedQuery("Info.findByText");
query.setParameter("text", "test");
List<Info> infos = (List<Info>) query.getResultList();
for (Info info : infos) {
System.out.println(info.toString());
} catch (Exception e) {
e.printStackTrace();
META-INF/persistence.xml
<persistence xmlns="http://java.sun.com/xml/ns/persistence" version="1.0">
<persistence-unit name="testUnit" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
<class>com.kn.persistence.Info</class>
<exclude-unlisted-classes>true</exclude-unlisted-classes>
<properties>
<property name="eclipselink.jdbc.driver"
value="com.ibm.db2.jcc.DB2Driver"/>
<property name="eclipselink.jdbc.url"
value="jdbc:db2://host:port/database"/>
<property name="eclipselink.jdbc.password" value="XXX"/>
<property name="eclipselink.jdbc.user" value="XXX"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="eclipselink.cache.shared.default"
value="false"/>
</properties>
</persistence-unit>
</persistence>
Stacktrace:
[EL Finest]: 2008.09.04
08:58:04.311--ServerSession(199887850)--Thread(Thread[main,5 ,main])--End
deploying Persistence Unit testUnit; state Deployed; factoryCount 1
Local Exception Stack:
Exception [EclipseLink-8002] (Eclipse Persistence Services - 1.0 (Build
1.0 - 20080707)): org.eclipse.persistence.exceptions.JPQLException
Exception Description: General Problem parsing the query [Info.findByText:
SELECT i FROM Info i WHERE TRIM(i.text) = :text]. The parser returned the
following [null].
Internal Exception: java.lang.NullPointerException
org.eclipse.persistence.exceptions.JPQLException.generalPars ingException(JPQLException.java:116)
org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser .addError(JPQLParser.java:247)
org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser .parse(JPQLParser.java:135)
org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser .buildParseTree(JPQLParser.java:94)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQL DatabaseQuery(EJBQueryImpl.java:203)
org.eclipse.persistence.queries.JPAQuery.processJPQLQuery(JP AQuery.java:87)
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:258)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:69)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:118)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:112)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:100)
at com.kn.persistence.InfoReader.main(InfoReader.java:16)
Caused by: java.lang.NullPointerException
org.eclipse.persistence.internal.jpa.parsing.NodeFactoryImpl .newTrim(NodeFactoryImpl.java:669)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.trim(JPQLParser.java:10120)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.functionsReturningStrings(JPQLParser.java:9867)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.arithmeticPrimary(JPQLParser.java:8824)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.arithmeticFactor(JPQLParser.java:8620)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.arithmeticTerm(JPQLParser.java:8444)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.simpleArithmeticExpression(JPQLParser.java:8351)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.arithmeticExpression(JPQLParser.java:8292)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.simpleConditionalExpression(JPQLParser.java:7039)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.conditionalPrimary(JPQLParser.java:6997)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.conditionalFactor(JPQLParser.java:2989)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.conditionalTerm(JPQLParser.java:2879)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.conditionalExpression(JPQLParser.java:2805)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.whereClause(JPQLParser.java:2762)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.selectStatement(JPQLParser.java:356)
org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQL Parser.document(JPQLParser.java:261)
org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser .parse(JPQLParser.java:133)
... 9 more
Re: TRIM in JPA NamedQuery [message #381083 is a reply to message #381079] Fri, 05 September 2008 06:23 Go to previous messageGo to next message
Same exception occurs with EclipseLink 1.0.1 M3.
Re: TRIM in JPA NamedQuery [message #381270 is a reply to message #381079] Mon, 08 September 2008 07:51 Go to previous messageGo to next message
I just found that changing TRIM(i.text) to TRIM(FROM i.text) in the JPA
query solved the problem.
According to the BNF specification of TRIM the keyword FROM is not
required.
Chapter 4.14 BNF:
functions_returning_strings ::=
TRIM([[trim_specification] [trim_character] FROM] string_primary)|
Re: TRIM in JPA NamedQuery [message #381273 is a reply to message #381270] Mon, 08 September 2008 13:49 Go to previous messageGo to next message
James is currently offline JamesFriend
Thanks for digging into this
Sounds like a bug, please log this issue in the Bugzilla.
-- James
Re: TRIM in JPA NamedQuery [message #381276 is a reply to message #381273] Mon, 08 September 2008 15:30 Go to previous message
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=246598
-- Sven
Previous Topic:Exception [EclipseLink-30005] - Persistence FAILED
Next Topic:enum collection
Current Time: Thu Apr 26 19:37:39 GMT 2018
Powered by FUDForum. Page generated in 0.01449 seconds
