custom SessionCustomizer cannot cast to org...config.SessionCustomizer [message #380517] |
Tue, 26 August 2008 22:49 |
Bill Blalock Messages: 118 Registered: July 2009 Location: Alabama |
I've written a custom SessionCustomizer to set user id, password etc.
I've tested it and it works.
I have been experimenting with a headless RCP based on the example
provided in the wiki.
Eclipselink API/workbench cast my custom SessionCustomizer ok.
Eclipselink JPA also could find my custom SessionCustomizer when it was in
a Java Project that was exported as a jar file and included in the runtime
classpath of the headless RCP.
I changed from using a Java Project for my domain objects and subclasses /
implemetation of Eclipselink classes to using a plug-in. I made the
change to avoid having to export the Java Project to a jar and copy the
jar into the Headless RCP each time a change was made.
Now the runtime fails to cast my custom SessionCustomizer. Defined in
persistence.xml
<property name="eclipselink.session.customizer"
value="eclipselink.SessionSysmonCustomizer"/>
adding to persistence.xml as <class> didn't help.
Problem goes away by copying SessionSysmonCustomizer into the headless RCP
and changing the property "eclipselink.session.customizer" to match the
new package in the headless RCP.
The domain model I am tinkering with is in the same plugin as my custom
Session customizer. Persistence.xml fines the enties as long as a
<class>entity</class> is in the persistence.xml file.
Where am I going wrong?
Bill Blalock
!ENTRY org.eclipse.osgi 4 0 2008-08-26 17:21:09.531
!MESSAGE Application error
!STACK 1
Local Exception Stack:
Exception [EclipseLink-28014] (Eclipse Persistence Services - 1.0 (Build
1.0 - 20080707)):
org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on
Exception Description: Exception was thrown while processing property
[eclipselink.session.customizer] with value
[eclipselink.SessionSysmonCustomizer].
Internal Exception: java.lang.ClassCastException:
eclipselink.SessionSysmonCustomizer cannot be cast to
org.eclipse.persistence.config.SessionCustomizer
org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on.failedWhileProcessingProperty(EntityManagerSetupException .java:178)
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. processSessionCustomizer(EntityManagerSetupImpl.java:1222)
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. updateServerSession(EntityManagerSetupImpl.java:1198)
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:237)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:69)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:118)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:112)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:100)
at eclipselinkrcp2.Application.start(Application.java:37)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.ClassCastException:
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. processSessionCustomizer(EntityManagerSetupImpl.java:1219)
... 20 more
FUDForum. Page generated in 0.01839 seconds
