Home » Eclipse Projects » EclipseLink » OSGI troubles with createEntityManagerFactory
OSGI troubles with createEntityManagerFactory [message #379261] Mon, 11 August 2008 19:00 Go to next message
Originally posted by: beat.stradax.net
Hi there
I'd like to use EclipseLink in an OSGi server environment (Equinox),
but I can't get an EntityManagerFactory. I've done some successful
tests with a milestone some weeks/months ago, but this doesn't work
anymore.
When I try to get the EntityManagerFactory in the Activator's start
method of the bundle that contains the persistence.xml
(javax.persistence and org.eclipse.persistence.jpa are started one
osgi start level before), I get the following errors:
1) When I don't specify any properties:
Persistence.createEntityManagerFactory("unitname");
The OSGiPersistenceInitializationHelper#getClassLoader is called
with "bundleresource://7/unitname" and doesn't find an entry for this,
because the map contains only a key "unitname".
2) When I specify Thread.currentThread().getContextClassLoader() as a
class loader property, this class loader doesn't find the resource
"META-INF/persistence.xml" in
PersistenceProvider#createEntityManagerFactory:95.
What am I doing wrong?
BTW: it would be very helpful when the EclipseLink website would
provide an OSGi SDK zip download which contains the source plugins. I
had to checkout the projects from the SVN tag to debug the problem...
Thanks for any hint,
Beat Strasser
Re: OSGI troubles with createEntityManagerFactory [message #379262 is a reply to message #379261] Mon, 11 August 2008 19:24 Go to previous message
> The OSGiPersistenceInitializationHelper#getClassLoader is called with
Well ok. With a class loader property
"this.getClass().getClassLoader()" it works.
Beat
Previous Topic:Fisheye on EclipseLink
Next Topic:ManyToMany: Why is no exception thrown?
Current Time: Sun May 20 12:18:51 GMT 2018
Powered by FUDForum. Page generated in 0.01722 seconds
