Home » Eclipse Projects » EclipseLink » DDL generation without database access
DDL generation without database access [message #378607] Wed, 06 August 2008 12:59 Go to next message
Frank Schwarz is currently offline Frank SchwarzFriend
Is it possible to let EclipseLink write the SQL schema definition files
without accessing the database?
My approach so far still connects to the database:
String directory = args[0];
Map<String, String> properties = new HashMap<String, String>();
properties.put(PersistenceUnitProperties.DDL_GENERATION,
PersistenceUnitProperties.CREATE_ONLY);
properties.put(PersistenceUnitProperties.CREATE_JDBC_DDL_FIL E,
"create-tables.sql");
properties.put(PersistenceUnitProperties.DROP_JDBC_DDL_FILE,
"drop-tables.sql");
properties.put(PersistenceUnitProperties.DDL_GENERATION_MODE ,
PersistenceUnitProperties.DDL_SQL_SCRIPT_GENERATION);
properties.put(PersistenceUnitProperties.APP_LOCATION, directory);
properties.put(PersistenceUnitProperties.JDBC_READ_CONNECTIO NS_MIN, "0");
properties.put(PersistenceUnitProperties.JDBC_WRITE_CONNECTI ONS_MIN, "0");
System.setProperty(PersistenceUnitProperties.JAVASE_DB_INTER ACTION,
"false");
EntityManagerFactory entityManagerFactory =
Persistence.createEntityManagerFactory("default", properties);
entityManagerFactory.createEntityManager().close();
entityManagerFactory.close();
Is there a best practice for this usecase?
Kind regards
Frank
Re: DDL generation without database access [message #378612 is a reply to message #378607] Wed, 06 August 2008 13:28 Go to previous messageGo to next message
James is currently offline JamesFriend
EclipseLink will always connect to validate the login information and
connection. I don't know of any easy way to avoid any connection at all.
If you don't have any access to a database, you could just connect to a
dummy in-memory database, or use a SessionCustomizer to configure your own
dummy Connector in the EclipseLink DatabaseLogin.
-- James
Re: DDL generation without database access [message #379022 is a reply to message #378612] Wed, 06 August 2008 14:51 Go to previous message
I dared to create an enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243321
-- Frank
Previous Topic:many table, one entity, annotation driven?
Next Topic:Typesafe JPQL query in EclipseLink
Current Time: Wed May 23 03:45:47 GMT 2018
Powered by FUDForum. Page generated in 0.02173 seconds
