Home » Eclipse Projects » EclipseLink » Change tracking of many-to-many relationship broken?
Change tracking of many-to-many relationship broken? [message #378580] Mon, 04 August 2008 16:11 Go to next message
Frank Schwarz is currently offline Frank SchwarzFriend
Consider this code snippet: (Person <-> Address is a many-to-many
relationship)
@SuppressWarnings("unchecked")
private static void update(EntityManagerFactory entityManagerFactory) {
EntityManager entityManager = entityManagerFactory
.createEntityManager();
try {
entityManager.getTransaction().begin();
Query query = entityManager.createQuery("SELECT p FROM Person p");
Collection<Person> collection = (Collection<Person>) query
.getResultList();
Address address = new Address();
address.setStreet("Oak Lane 12");
address.setCity("Dallas");
for (Person person : collection) {
person.getAddresses().add(address);
address.getPersons().add(person);
entityManager.getTransaction().commit();
} finally {
if (entityManager.getTransaction().isActive()) {
entityManager.getTransaction().rollback();
entityManager.close();
The database has already two person-entities beforehand. The execution of
this piece of code does not alter the database - it should, however,
insert an Address entity with corresponding entries in the join table
PERSON_ADDRESS. However, a subsequent query for person-entities reveals an
additional Address-object associated with each person, that only consists
of uninitialized properties.
Is this a known bug?
Kind regards,
Frank
Re: Change tracking of many-to-many relationship broken? [message #378582 is a reply to message #378580] Tue, 05 August 2008 05:28 Go to previous messageGo to next message
Tom Eugelink is currently offline Tom EugelinkFriend
> relationship)
Maybe you should also include the relevant portions of the entities, the error could be in the mapping?
Tom
Re: Change tracking of many-to-many relationship broken? [message #378584 is a reply to message #378582] Tue, 05 August 2008 06:20 Go to previous messageGo to next message
The mapping is straightforward and has proven to work with other O/R
mappers:
@Entity
public class Address {
public Address() {
@Id
@GeneratedValue(strategy = GenerationType.SEQUENCE)
private long id;
private String street;
private String city;
@ManyToMany(cascade = CascadeType.ALL)
private Set<Person> persons = new HashSet<Person>();
public class Person {
public Person() {
@Id
private long id;
private String firstName;
private String lastName;
@ManyToMany(mappedBy = "persons", cascade = CascadeType.ALL)
private Set<Address> addresses = new HashSet<Address>();
Re: Change tracking of many-to-many relationship broken? [message #378586 is a reply to message #378584] Tue, 05 August 2008 07:44 Go to previous messageGo to next message
To me this looks ok indeed, so I'll leave it to the EclipseLink developers to comment on.
Re: Change tracking of many-to-many relationship broken? [message #378588 is a reply to message #378580] Tue, 05 August 2008 09:36 Go to previous messageGo to next message
It seems to be a lazy initialization problem (or a configuration problem
on my side):
EntityManager entityManager = entityManagerFactory.createEntityManager();
try {
Collection<Person> collection = (Collection<Person>) query.getResultList();
// provoke initialization
person.getAddresses().size();
} finally {
With the addition of "person.getAddresses().size();" in the for-loop
everything is fine.
Any comments?
-- Frank
Re: Change tracking of many-to-many relationship broken? [message #378589 is a reply to message #378588] Tue, 05 August 2008 12:35 Go to previous messageGo to next message
> everything is fine.
Only that I have experienced similar situations, which I usually solve by creating a new collection immediately on the query.
Collection<Person> collection = new ArrayList<Person>( query.getResultList() );
I'm not sure if this behavior is faulty as per the JPA definition, because this would be one of the first unittests, I'd gather. But it is unexpected behavior and often causes unnecessary debug work. The JPA1.0 has issues in the "unexpected behavior" area. :-)
Re: Change tracking of many-to-many relationship broken? [message #378597 is a reply to message #378588] Tue, 05 August 2008 13:51 Go to previous messageGo to next message
James is currently offline JamesFriend
This is very odd, it seems to be an issue with attribute change tracking,
and a read-only many-to-many mapping. I think this is causing the address
to not be persisted. If you call persist on the Address, does it commit
correctly?
If so, it would seem to be a bug, please log a bug for the issue, include
the example code and a log trace on finest.
https://bugs.eclipse.org/bugs/
The workaround for now is either your size call, calling persist on the
Address, or using the @ChangeTracking annotation to use deferred change
tracking for Person class.
-- James
Re: Change tracking of many-to-many relationship broken? [message #378600 is a reply to message #378597] Tue, 05 August 2008 15:25 Go to previous message
Bug report filed as https://bugs.eclipse.org/bugs/show_bug.cgi?id=243176
-- Frank
Previous Topic:unidirectional one-to-many mapping with join column
Next Topic:how to
Current Time: Wed Feb 21 09:54:23 GMT 2018
Powered by FUDForum. Page generated in 0.01720 seconds
