Home » Modeling » Modeling (top-level project) » Beginners trouble with modeling.
Beginners trouble with modeling. [message #378363] Mon, 25 September 2006 15:42 Go to next message
Conor Missing name is currently offline Conor Missing nameFriend
Hey,
I'm having trouble with building a model for gmf in a xsd file.
I want to start off with a very simple model that contains only one type
of element that can then be associated with other elements (a directed
association) of the same type. The element will have some attributes (or
should these be elements?) as well but it's doing the association I don't
understand.
What I want to model is a simple dialogue that is divided into segments.
Each node to be a segment in a graph structure.
So something like:
<xsd:schema
targetNamespace="http://www.example.org/dialoguegraph"
xmlns:dialoguegraph="http://www.example.org/dialoguegraph"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<xsd:complexType name="DialogueSegment">
<xsd:attribute name="intro_text" type="xsd:string"/> //set to max of one
<xsd:attribute name="transcript" type="xsd:string"/> //set to max of one
<xsd:attribute name="outro_text" type="xsd:string"/> //0..*
</xsd:complexType>
//set the relatonship between nodes?????
</xsd:schema>
Re: Beginners trouble with modeling. [message #378364 is a reply to message #378363] Mon, 25 September 2006 15:48 Go to previous message
Gaff,
I see you asked the same question on the GMF newsgroup, which is better
than posting to this more general newsgroup. When posting the same
question to multiple newsgroup, please using a single posting to all so
that an answer on one will appear on all (to reduce the workload of
answering the same question multiple times).
Gaff wrote:
> Hey,
> type of element that can then be associated with other elements (a
> directed association) of the same type. The element will have some
> attributes (or should these be elements?) as well but it's doing the
> association I don't understand.
> segments. Each node to be a segment in a graph structure.
> So something like:
> <xsd:schema targetNamespace="http://www.example.org/dialoguegraph"
> </xsd:complexType>
> </xsd:schema>
Re: Beginners trouble with modeling. [message #582201 is a reply to message #378363] Mon, 25 September 2006 15:48 Go to previous message
Gaff,
Gaff wrote:
> Hey,
> So something like:
> </xsd:complexType>
> </xsd:schema>
Previous Topic:Beginners trouble with modeling.
Next Topic:Improved Documentation for EMF & related modeling projects
Current Time: Wed Apr 25 10:34:02 GMT 2018
Powered by FUDForum. Page generated in 0.02483 seconds
