Home » Eclipse Projects » EclipseLink » eclipse 1.0M6 to 1.0: IllegalAccessError
eclipse 1.0M6 to 1.0: IllegalAccessError [message #376377] Sun, 20 July 2008 03:06 Go to next message
Tom Eugelink is currently offline Tom Eugelink
I've follow the Toplink JPA implementation from the essentials all the way to now EclipseLink. Currently my system is using EclipseLink 1.0M6 and works fine. Yesterday I did a memory profile of my application and found that a 400 MB memory dump was loaded for almost 50% with EclipseLink classes. This does not seem to be right, so I'm investigating. As a first step I decided to upgrade to 1.0 to make sure it is not a beta-release problem. I downloaded the 1.0 release and replace the jar and started the application:
Caused by: java.lang.IllegalAccessError: tried to access method org.eclipse.persistence.internal.jpa.EntityManagerFactoryPro vider.mergeMaps(Ljava/util/Map;Ljava/util/Map;)Ljava/util/Ma p; from class org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.callPredeploy(JPAInitializer.java:85)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initPersistenceUnits(JPAInitializer.java:149)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initialize(JPAInitializer.java:135)
at org.eclipse.persistence.internal.jpa.deployment.JavaSECMPIni tializer.initializeFromAgent(JavaSECMPInitializer.java:145)
... 12 more
The exception comes immediately on startup. Any suggestions?
Tom
Re: eclipse 1.0M6 to 1.0: IllegalAccessError [message #376880 is a reply to message #376377] Mon, 21 July 2008 10:28 Go to previous messageGo to next message
James is currently offline James
We do not get this error is any of our test environments.
It seems to be some kind of classpath or class loader issue. Are you sure
you don't have an old version of the code on the classpath? What
environment are you testing in exactly? (server, jvm, spring, etc.)
Re: eclipse 1.0M6 to 1.0: IllegalAccessError [message #376881 is a reply to message #376880] Tue, 22 July 2008 02:55 Go to previous messageGo to next message
> sure you don't have an old version of the code on the classpath? What
I'm using it stand-alone. Eclipse 3.3, JDK 1.6.0u10_debug. I removed the old jar from the classpath in Eclipse, added the new, and altered the vm agent argument to use the new jar... That should do it, right?
Re: eclipse 1.0M6 to 1.0: IllegalAccessError [message #376882 is a reply to message #376881] Tue, 22 July 2008 09:41 Go to previous messageGo to next message
Ensure you removed the old jar completely. There should not be any
classpath issues using stand-alone other than classpath, so this is very
odd. You could try debugging it.
Also try removing the agent, and see if you still get the error.
You could also try running outside of Eclipse where you may have more
control over what is on your classpath.
In general the mergeMaps method is public, so you should not be getting an
access error, unless you have and older version of the class on the
classpath that had the method as not public.
-- James
Re: eclipse 1.0M6 to 1.0: IllegalAccessError [message #376884 is a reply to message #376882] Tue, 22 July 2008 11:06 Go to previous message
Ah, I forgot that another project was included and it also had the eclipselink jar. Now it works; only some minor changes in the programmatic configuration.
Thanks.
Tom
Previous Topic:StaticWeavingAntTask didn't weave my classes
Next Topic:JBoss Seam: FlushModeType.MANUAL for EclipseLink/TopLink
Current Time: Wed Jun 19 09:06:55 EDT 2013
Powered by FUDForum. Page generated in 0.01557 seconds
