Home » Eclipse Projects » EclipseLink » Problems with sequences
Problems with sequences [message #376351] Wed, 16 July 2008 09:41 Go to next message
Originally posted by: daniel.ortega.gmail.com
Hi there,
All of the primary keys of my entities are set by a sequence created on
the database.
I read the the default allocation-size of JPA is 50 so our sequences are
defined this way on the database:
CREATE SEQUENCE SEQ_ADJUNTO START WITH 1 INCREMENT BY 50;
And the entity:
@Id
@Column(name="ID_ADJUNTO", updatable=false)
@GeneratedValue(strategy=GenerationType.SEQUENCE, generator = "attachment")
@SequenceGenerator(name="attachment", allocationSize=50,
sequenceName="SEQ_ADJUNTO")
private Integer id;
It actually works fine but, when the database is just created, on the
first insert on any table we have this error:
Exception [EclipseLink-7027] (Eclipse Persistence Services - 1.0 (Build
1.0 - 20080707)): org.eclipse.persistence.exceptions.ValidationException
Exception Description: The sequence named [SEQ_ADJUNTO] is setup
incorrectly. Its increment does not match its pre-allocation size.
Just repeating the operation that triggered the insert it works, and all
subsequent inserts too.
Not really a big problem, but we're going into production in a few weeks
and now I think it's time to fix it up.
Any clue of what might be happening?.
Thanks in advance
Re: Problems with sequences [message #376352 is a reply to message #376351] Wed, 16 July 2008 10:15 Go to previous message
Forget my question, creating the sequence starting with 50 makes it work
fine. :)
> Hi there,
> the database.
> And the entity:
> @Id
> private Integer id;
> Thanks in advance
Previous Topic:maven2 support?
Next Topic:Problem with persistence cache using JPA
Current Time: Tue May 22 02:44:40 GMT 2018
Powered by FUDForum. Page generated in 0.01608 seconds
