Re: birt y office 2000 [message #365898 is a reply to message #365893] |
Tue, 11 November 2008 05:31 |
Originally posted by: johnw.innoventsolutions.com
Mary,
Lo siento pero mi Espanol es malo. Solo puedo pedir comida por mi esposa :)
No entiendo su problema. Office 2000 solo lee el formato de XLS, y Birt
escribe el formato de XLS. El formato de XLSX es para Office 2007. Trata
de exportar al el formato CSV usando dataextract.
Suerte!
John
Mary Luz Suarez wrote:
> No se si alguien puede colaborarme con esto.
> Tengo un equipo con office 2000 y no puedo abrir los reportes generados
> por birt que exporto a Excel. Intente lo de cambiar el formato a
> *xlsx pero aun asi no me funciono ni tampoco al intalar el programita
> de FileFormatConverters para compatibilidad de archivos de office.
> Si alguien me puede ayudar le agradezco
Re: birt y office 2000 [message #365914 is a reply to message #365908] |
Wed, 12 November 2008 05:49 |
Are you using the BIRT Web Viewer, or just the BIRT Designer to view
reports?
John
> hello john.
> I donŽt know much english, but I go to try.
> Thank you for your message, but I donŽt understand much.
> Birt only generates files of format xls and
> How can generate the file csv?
> dataextract is other program ? I must first install it?
> Thanks
Re: birt y office 2000 [message #365939 is a reply to message #365917] |
Thu, 13 November 2008 23:39 |
Mary,
Es OK, su englis es muy bien. Mejore que mi espanol, yo saber un poquito :)
I do not believe there is a way to do the data extract to CSV through
the URL parameters. You will have to do it with the interactive page
itself inside the BIRT viewer. The third icon at the top of the page
will say "Export Data", and that will allow you to export to CSV, which
is supported by all versions of Excel.
Depending on what your needs are, it is possible to build an exporter in
Java. You can also take a look at E-Spreadsheet, which is made by the
same company that makes BIRT. ESpreadsheet is built to work specifically
with data to create Excel Spreadsheets.
John
> I am using the BIRT Web Viewer for export the report from my browser. I
> install two plugins in the eclipse
> org.eclipse.birt.report.data.oda.csv and
> org.eclipse.birt.report.data.oda.csv.ui.
> after I run the url report and I adding &__format=csv but it show the
> error:
> org.eclipse.birt.report.service.api.ReportServiceException: The output
> format csv is not supported.
> Escuse me for my english
Re: birt y office 2000 [message #468023 is a reply to message #365898] |
Mon, 03 August 2009 16:40 |
Originally posted by: lilipvj.yahoo.es
I have a computer with Office 2000 and I can not open the reports
generated by Birt to export to Excel.
If anyone can help me thank you
Re: birt y office 2000 [message #468472 is a reply to message #468023] |
Wed, 05 August 2009 15:40 |
ya encontre la solución para ver reportes de birt en Excel 2000, es la
siguiente:
1. Ingresar al link http://support.microsoft.com/kb/924074/en-us para ver
el siguiente enlace con el paquete de compatibilidad que debe ser
instalado
http://www.microsoft.com/downloads/details.aspx?FamilyID=941 b3470-3ae9-4aee-8f43-c6bb74cd1466
2. Guardar el informe con tipo de archivo *.xls en el escritorio o en la
carpeta donde se desee.
3. Hacer click derecho sobre el archivo que se guardo, seleccionar
"Guardar como ..." y salvar como tipo de archivo *.xlsx Hacer caso omiso
de la advertencia y dar click en el boton Si.
4. Hacer doble clic en el archivo nuevo creado con extensión .xlsx para
visualizar el reporte.
FUDForum. Page generated in 0.02779 seconds
