Home » Eclipse Projects » BIRT » BIRT 2.3.1 using connection profile, no SQB
BIRT 2.3.1 using connection profile, no SQB [message #365747] Thu, 30 October 2008 05:01 Go to next message
Originally posted by: jackh.jackh.com
I've tried with both RCP and the all-in-one. I'm creating a new dataset off
of a datasource from a connection profile. The new sql query builder (SQB)
is not there. It only has the old manual SQL entry tool. Any ideas??
Re: BIRT 2.3.1 using connection profile, no SQB [message #365751 is a reply to message #365747] Thu, 30 October 2008 15:55 Go to previous messageGo to next message
Can you try the following:
1 - create a new datasource
2 - choose the radial for create connection from connection profile
3 - Select next, then new.
4 - Choose BIRT Classic Models Sample Database
5 - Put in a file name, such as c:/tmp/myprof
6 - Finish
create a dataset and see if the SQB is available.
Jason
> Thanks
Re: BIRT 2.3.1 using connection profile, no SQB [message #365764 is a reply to message #365751] Fri, 31 October 2008 06:08 Go to previous messageGo to next message
Yes that works. My db is postgres. Is it a bug?
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:geclfa$a68$1@build.eclipse.org...
> 6 - Finish
> Jason
>> off of a datasource from a connection profile. The new sql query builder
>> (SQB) is not there. It only has the old manual SQL entry tool. Any
>> ideas??
>> Thanks
Re: BIRT 2.3.1 using connection profile, no SQB [message #365770 is a reply to message #365764] Fri, 31 October 2008 14:11 Go to previous messageGo to next message
postgres should work as well. Can you try to open the Data Source
Explorer view:
window->show view->other->Connectivity->Data Source Explorer
and add your data source under databases. As a test supply username and
password. Once you create it swap step 4 with your new database.
Jason
>> 6 - Finish
>> Jason
>>> ideas??
>>> Thanks
Re: BIRT 2.3.1 using connection profile, no SQB [message #365820 is a reply to message #365770] Wed, 05 November 2008 04:21 Go to previous message
Linda ChanFriend
Using the Data Source Explorer view to create a postgres connection profile
would work, but not really required.
Alternatively,
>>> 4a - In the "Create a Connection Profile Store" dialog, select "New..."
>>> button
4b - In the "New Connection Profile" dialog, select PostgreSQL,
press Next to specify your JDBC driver definition and connection profile
properties. Press Finish.
4c - The connection profile that you just created is now added to
the check box list. Select the checkbox of that profile.
>>> 6 - Finish
Linda
news:gef3o8$oh8$1@build.eclipse.org...
> Explorer view:
> Jason
>>> 6 - Finish
>>> Jason
>>>> dataset off of a datasource from a connection profile. The new sql
>>>> query builder (SQB) is not there. It only has the old manual SQL entry
>>>> tool. Any ideas??
>>>> Thanks
Previous Topic:Get the datasource URL in the property binding ?
Next Topic:Problems providing BIRT a JDBC connection using ODA driverBridge
Current Time: Tue Feb 20 06:10:00 GMT 2018
Powered by FUDForum. Page generated in 0.02420 seconds
