| Problem exporting to excel [message #365617] |
Thu, 16 October 2008 10:15  |
SuperTime Messages: 45 Registered: July 2009 |
Member |
I am on the BIRT 2.2.2 version
The report contains two nested table elements. And each nested table
contains fields from a single dataset.
When I preview the report in the webviewer, html, pdf it runs perfectly.
However when I run it as XLS it gives me the following window:
Problems During Load
Problems came up in the following areas during load:
Table
This file cannot be opened because of errors. Errors are listed in
C:\Documents and Settings\username\Local Settings\Temporary Internet
Files\Content.MSO\C4DD6BO.log
But I was not able to find Content.MSO file in that folder. I even made
sure that all the hidden files are also shown.
Please advice whats wrong here. Does BIRT not support exporting nested
tables to excel? Because when I removed the two nested table the export
goes through fine. Is there a workaround to using nested tables?
FUDForum. Page generated in 0.01562 seconds
