Home » Eclipse Projects » BIRT » scale / stretch barcode font
scale / stretch barcode font [message #361278] Thu, 20 March 2008 03:51 Go to next message
Eclipse User
Originally posted by: georg.raffer.salomon.at
Hi guys,
Until now I've tried several things to get barcodes running in BIRT (PDF
export). Current solution:
Use fonts to render the barcode. Checksums are calculated with an
EventAdapter. This works pretty good, one problem is still left:
It is not possible to scale (without keeping the ratio) / stretch the
barcode. I need the barcode in a different ratio than the font. It should
have a height of 50 pixels and a width of 70 pixels (Code 128). Anybody an
idea how I can achieve this?
I could not find a style / formatting option.
Thanks in advance for your help!
bye, Georg
Re: scale / stretch barcode font [message #361330 is a reply to message #361278] Tue, 25 March 2008 02:11 Go to previous messageGo to next message
sissi is currently offline sissi
Hi Georg,
I think you can use Text item to reach the goal. Insert a text item, and
choose "HTML" type, select "Formatting" subtype, and set your barcode style
in it. That will set the barcode format different with the other items.
sissi
"Georg Raffer" <> wrote in message
news:5ea89ca2ed78d79369dfc7b12ea590ec$1@www.eclipse.org...
> Hi guys,
> bye, Georg
[Updated on: Wed, 16 November 2011 09:11] by Moderator
Report message to a moderator
Re: scale / stretch barcode font [message #361334 is a reply to message #361330] Tue, 25 March 2008 04:25 Go to previous messageGo to next message
Eclipse User
Hi Sissi,
Thank you for your reply.
But for me it didn't work. I need to stretch a text. I could not find a
style for that. Any other idea?
I want to format a text, such that it has 100 px height and 40 px width
(the ratio is not proportional to the font metrics). This is needed to
print barcodes (using fonts).
bye, Georg
Re: scale / stretch barcode font [message #756833 is a reply to message #361334] Tue, 15 November 2011 05:03 Go to previous message
Adam Barlow is currently offline Adam Barlow
Find a .NET Code 128 Reader
Previous Topic:Birt Missing images on ProxyPass
Next Topic:How to display empty columns in a crosstab
Current Time: Sat May 18 10:44:04 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
