Re: Javascript: WEB_event can not be resolved to a type [message #35119 is a reply to message #35085] |
Tue, 13 January 2009 09:34 |
Johannes Weberhofer Messages: 15 Registered: July 2009 |
Junior Member |
You could be right,
I'm using several plugins, it could also come from the Webtools Plugin - unfortunately I can not easily find out which plugin causes which messages (or is there a way?)
Thank you for the quick response,
Johannes Weberhofer
Am 12.01.2009 08:28, schrieb Alex Panchenko:
> Hi Johannes,
> I am not sure if this message come from the DLTK Javascript, probably
> you have other plugins installed?
> Alex
> Johannes Weberhofer wrote:
>> Hi!
>> I started testing the dl toolkit some weeks ago and like it a lot.
>> But I have one problem: Lines like "var caller = new
>> WEB_event(event);" are marked as error "WEB_event can not be resolved
>> to a type", even when there is a JS file profiding this function in
>> the same directory. Is there any way to suppress this message?
>> Thank you,
>> Johannes Weberhofer
FUDForum. Page generated in 0.02902 seconds
