Home » Eclipse Projects » Eclipse Platform » ERROR: ‘Not implmented in this version’ for xml transfom.-Please help
ERROR: ‘Not implmented in this version’ for xml transfom.-Please help [message #336117] Fri, 22 May 2009 06:04 Go to next message
govind Mising name is currently offline govind Mising nameFriend
Member
Recently i upgraded java version from 1.5 to 1.6.
I Use eclispe 3.4.
I use Xml transformer to read the contents of the file.
Now when i run my rcp – product it give error when
Source source = new DOMSource(MyDocument);
StreamResult result = new StreamResult(newStringWriter());
Transformer xformer = TransformerFactory.newInstance().newTransformer();
xformer.transform(source, result);
String xmlString = result.getWriter().toString();
Its gives me
javax.xml.transform.TransformerException: org.w3c.dom.DOMException: Not
implmented in this version at
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl .transform(TransformerImpl.java:717)
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl .transform(TransformerImpl.java:313)
Please help..
I use javax.xml_1.3.4.v200806030440.jar of eclipse.
Is there way where i can i ask to run with this rather than jre.
Govind R
Re: ERROR: �Not implmented in this version� for xml transfom.-Please help [message #336124 is a reply to message #336117] Fri, 22 May 2009 23:10 Go to previous messageGo to next message
Ben Vitale is currently offline Ben VitaleFriend
Generally speaking, to override the default Java implementation of
various APIs, you should use the java.endorsed.dirs property.
http://java.sun.com/j2se/1.4.2/docs/guide/standards/
Hope that helps,
Ben
> I Use eclispe 3.4.
> Now when i run my rcp � product it give error when
> Its gives me
> at
> Please help..
> Regards
> Govind R
Re: ERROR: �Not implmented in this version� for xml transfom.-Please help [message #336140 is a reply to message #336124] Tue, 26 May 2009 14:02 Go to previous message
Nitin Dahyabhai is currently online Nitin DahyabhaiFriend
You want different bundles from the Orbit project, most likely the
org.apache.xerces and org.apache.xalan bundles. The javax.xml
bundle contains mostly API code without implementation, so that you
have your DOM interfaces present.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:org.eclipse.debug.ui.consoleLineTrackers
Next Topic:Problems generating a headless build application
Current Time: Thu Feb 22 21:02:47 GMT 2018
Powered by FUDForum. Page generated in 0.01307 seconds
