Home » Eclipse Projects » Eclipse Platform » reverse/undo dirty state in an editor?
reverse/undo dirty state in an editor? [message #336097] Thu, 21 May 2009 10:39 Go to next message
Kris Missing name is currently offline Kris Missing nameFriend
Member
I have a simple EditorPart implementation (a few text input fields).
When the user changes one of the the text fields, the implementation
a.) lets the isDirty method return true
b.) fires a firePropertyChange(IEditorPart.PROP_DIRTY);
As effect the editor gets its dirty flag '*' in the name and the save
action which has been added to the toolbar [via
ActionFactory.SAVE.create(window) in the ActionBarAdvisor implemenation]
gets enabled. Fine so far.
If the user reverses its change (e.g. removing a character previously
added in a text field), my EditorPart implementation
a.) lets the isDirty method return false
b.) fires a firePropertyChange(IEditorPart.PROP_INPUT);
As effect the editor gets its dirty flag '*' removed again.
However, the save action in the toolbar doesn't get disabled
automatically. Am I doing something wrong when trying to reverse the
dirty state of the editor or do I have to care about the save action by
myself when reversing the editor to 'un-dirty' state?
Kris
Re: reverse/undo dirty state in an editor? [message #336105 is a reply to message #336097] Thu, 21 May 2009 13:26 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
your second (b) says firePropertyChange(IEditorPart.PROP_INPUT) instead
of PROP_DIRTY. Is that really in your code?
PW
Paul Webster
Re: reverse/undo dirty state in an editor? [message #336108 is a reply to message #336105] Thu, 21 May 2009 14:46 Go to previous message
Member
ah - now I got it - always fire PROP_DIRTY - also to indicate that the
editor is not dirty anymore!
Thanks!
> PW
Previous Topic:How to disable Plugin in Eclipse 3.4.2
Next Topic:Build before launch bug
Current Time: Sun Feb 25 20:19:25 GMT 2018
Powered by FUDForum. Page generated in 0.05089 seconds
