icon4.gif Announcement: Forum Move.
By: Eclipse Webmaster on Fri, 25 June 2010
0 6708 Fri, 25 June 2010 14:49
  MAT error on AIX 64-bit
Getting invalid magic number libjvm.so on AIX 64bit
By: Samira on Wed, 20 July 2011
1 17092 Thu, 28 July 2011 06:36
By: Krum Tsvetkov
  MAT on Solaris: SWT not found
By: Scritch on Tue, 15 June 2010
2 5453 Fri, 18 June 2010 15:17
By: Scritch
  Error during the parser
By: roger on Fri, 07 August 2009
3 16602 Fri, 21 May 2010 07:58
By: Baris Evrim Demiroz
  Dumping Memory when VM Heap size is not at maxmemory
By: Pamir Erdem on Thu, 20 May 2010
7 12777 Fri, 21 May 2010 06:53
By: Krum Tsvetkov
  java heap size is only 20MB, but memory usage is 1.7GB
By: John Ye on Thu, 06 May 2010
3 7578 Thu, 20 May 2010 01:27
By: John Ye
  GC Root Unfinalized
How do you find the real GC Root for unfinalized objects
By: Gary Karasiuk on Mon, 17 May 2010
3 7451 Wed, 19 May 2010 07:47
By: Krum Tsvetkov
  An out of memory error has occurred during parsing heap dump
By: Maya Fishkis on Tue, 31 March 2009
7 42635 Tue, 18 May 2010 12:35
By: Krum Tsvetkov
  Memory Analyzer 1.0 Is Released
By: Krum Tsvetkov on Tue, 18 May 2010
0 6240 Tue, 18 May 2010 07:32
By: Krum Tsvetkov
  Reading values of HashMap
Reading values of HashMap(concurrrent)
By: Sudheer Krishna on Tue, 11 May 2010
2 7733 Fri, 14 May 2010 17:04
By: Sudheer Krishna
  Can't access to svn repo
By: Aurélien Pupier on Fri, 14 May 2010
3 5491 Fri, 14 May 2010 11:50
By: Krum Tsvetkov
  MAT enhancement: diff
By: Tom Eugelink on Mon, 28 July 2008
6 9142 Fri, 07 May 2010 12:04
By: Andrew Johnson
  Eclipse Application to generate reports
By: Aurélien Pupier on Mon, 15 March 2010
3 5890 Mon, 19 April 2010 19:31
By: Aurélien Pupier
  Attention writers of plug-ins for MAT - API changes
By: Andrew Johnson on Wed, 14 April 2010
1 4871 Fri, 16 April 2010 19:52
By: Erik Brangs
  download MAT for RAP
By: Rick Trotter on Wed, 21 October 2009
4 8323 Fri, 09 April 2010 06:31
By: Krum Tsvetkov
icon5.gif Extending MAT by providing a new heap dump reader
Outbound and inbound indexes, sizes
By: Erik Brangs on Tue, 23 February 2010
7 8567 Tue, 16 March 2010 07:13
By: Krum Tsvetkov
  class loader held only by finalzation queue ??
By: slaurent on Sat, 27 February 2010
1 5166 Mon, 08 March 2010 14:11
By: Krum Tsvetkov
  How to pass d64 Parameter to the MAT-JVM
By: Rolf on Thu, 25 February 2010
2 9075 Fri, 26 February 2010 11:58
By: Rolf
  MAT library API
Analyze memory dump programmatically
By: No real name on Sun, 24 January 2010
1 6055 Mon, 25 January 2010 11:15
By: Krum Tsvetkov
icon5.gif How to Increase heap size for MAT in IBM ISA?
By: Jeroen on Wed, 13 January 2010
4 28287 Fri, 15 January 2010 16:18
By: Andrew Johnson
  Need help to analyse result given by MAT
By: Aurélien Pupier on Thu, 14 January 2010
5 8925 Fri, 15 January 2010 11:22
By: Krum Tsvetkov
  Same Class on different line in histogram
2 5037 Fri, 15 January 2010 08:10
By: Aurélien Pupier
  Request For Alternate View Of LinkedList
By: Deerpark on Thu, 07 January 2010
3 7597 Mon, 11 January 2010 16:48
By: Andrew Johnson
  How to setup MAT in Eclipse SDK
By: Jamal on Tue, 05 January 2010
2 16949 Wed, 06 January 2010 08:53
By: Jamal
  Retained heap in histogram view
By: No real name on Mon, 28 December 2009
1 8001 Mon, 28 December 2009 22:55
By: Krum Tsvetkov
  References hold by Finalizer
By: Stefan on Mon, 30 November 2009
1 4631 Mon, 30 November 2009 18:54
By: Andreas Buchen
  DTFJ adapter doesn't show attributes and values
By: Eclipse User on Mon, 10 August 2009
7 13689 Fri, 27 November 2009 14:06
By: Andrew Johnson
  New resolvers URL, Point, Rectangle
By: Chris Grindstaff on Tue, 28 April 2009
1 5223 Fri, 20 November 2009 13:35
By: Krum Tsvetkov
  Getting heap dump using JDK 1.5
By: Arya_01 on Mon, 10 August 2009
1 8823 Fri, 20 November 2009 13:31
By: Krum Tsvetkov
  Any plans to support C++?
By: Marc on Wed, 02 September 2009
4 7168 Fri, 20 November 2009 13:25
By: Krum Tsvetkov
  Perm gem space taken by classloader or class definition
By: Jose Fermin Alvarez on Mon, 16 November 2009
1 7901 Mon, 16 November 2009 20:00
By: Andreas Buchen
icon5.gif using "dominatorof" in query
By: riaz on Mon, 21 September 2009
1 5227 Tue, 03 November 2009 10:36
By: Krum Tsvetkov
  Heap Dump from Solaris gcore jdk 1.4.2.11
By: Bill Clark on Sun, 11 October 2009
1 8805 Tue, 03 November 2009 10:25
By: Krum Tsvetkov
  File monitoring tool
By: Pascal Rapicault on Thu, 29 October 2009
1 4529 Sat, 31 October 2009 20:07
By: Andrew Johnson
  Direct contact need
By: bjprog on Wed, 30 September 2009
2 4843 Mon, 12 October 2009 09:05
By: bjprog
  test
0 5351 Wed, 30 September 2009 08:40
By: bjprog
icon5.gif viewing amount of instances in class histogramm / dominator tree
By: riaz on Tue, 22 September 2009
1 6037 Thu, 24 September 2009 08:48
By: Krum Tsvetkov
  java.lang.Integer: 16 bytes or 24?
By: Randall Theobald on Tue, 08 September 2009
1 5457 Tue, 08 September 2009 19:34
  Analyzing from 64bit to 32bit
By: royrusso on Thu, 03 September 2009
1 4944 Thu, 03 September 2009 18:11
By: Andreas Buchen
  can we use Ant to run the memory analyzer
By: Eclipse User on Tue, 25 August 2009
1 5457 Tue, 25 August 2009 12:20
By: Andreas Buchen
  cmdline way to open MAT with a dump and save reports in default format
1 4586 Tue, 25 August 2009 12:18
By: Andreas Buchen
  Eclipse MAT JVM heap size?
By: Eclipse User on Tue, 18 August 2009
1 6178 Tue, 18 August 2009 19:53
By: Andrew Johnson
  OutOfMemory while parsing heap dump file
By: James on Thu, 13 August 2009
1 7412 Fri, 14 August 2009 08:31
By: Andrew Johnson
  commandline way to open MAT with a dump
By: Randall Theobald on Wed, 12 August 2009
0 6119 Wed, 12 August 2009 16:28
  OQL Syntax for getting particular array element
By: Sam on Tue, 04 August 2009
1 6410 Thu, 06 August 2009 10:37
By: Krum Tsvetkov
  Request for comments: MAT next steps
By: Krum Tsvetkov on Thu, 23 July 2009
0 4914 Thu, 23 July 2009 08:32
By: Krum Tsvetkov
  Classes from rt.jar loaded by different loaders ?
By: Satish Burnwal on Fri, 17 July 2009
3 6556 Tue, 21 July 2009 17:51
By: Andreas Buchen
  Could not parse big heap file
By: Michael Wang on Fri, 17 July 2009
1 6695 Sun, 19 July 2009 15:45
By: Andreas Buchen
  Setting up MAT with eclipse
By: Satish Burnwal on Wed, 15 July 2009
2 6715 Fri, 17 July 2009 10:04
By: Satish Burnwal
  DTFJ queries
By: Andrew Johnson on Tue, 07 July 2009
1 3976 Wed, 08 July 2009 12:00
By: Andreas Buchen
  update site zip
By: Alex on Fri, 26 June 2009
3 4496 Sat, 27 June 2009 00:18
By: Alex
  MAT not in Galileo?
By: Arnauld Van Muysewinkel on Fri, 26 June 2009
3 5038 Fri, 26 June 2009 10:30
  Histogram and Dominator_Tree
By: lsq on Wed, 17 June 2009
2 5692 Thu, 18 June 2009 09:19
By: lsq
  cannot run MemoryAnalyzer on hp-ux
By: Jaechul Yoo on Fri, 05 June 2009
3 6305 Thu, 11 June 2009 11:34
By: Andreas Buchen
  New versions of DTFJ adapter and DTFJ
By: Andrew Johnson on Fri, 27 March 2009
6 18697 Mon, 25 May 2009 19:03
  No Overview Pane for WebSphere 6.0.2 IBM SDK 1.4.2 generated Heap Dump
By: Andrew Plata on Mon, 18 May 2009
1 6733 Sat, 23 May 2009 13:58
By: Andrew Johnson
  How can I get the snapshot window after opening heap dump?
By: Andrew Plata on Tue, 19 May 2009
1 3582 Wed, 20 May 2009 16:11
By: Andreas Buchen
  Analyser 'loosing' over half of the used memory
By: Matthew Seaborn on Mon, 18 May 2009
4 5952 Wed, 20 May 2009 15:37
By: Andreas Buchen
  All ObjectIds of Heap dump
By: M.S.Alavi on Thu, 14 May 2009
1 3723 Fri, 15 May 2009 06:57
By: Krum Tsvetkov
  hprof stacktrace info support
By: Taras Tielkes on Tue, 10 March 2009
4 6948 Mon, 11 May 2009 10:28
By: Krum Tsvetkov
  Eden v Old
By: Michael on Sun, 03 May 2009
1 5405 Tue, 05 May 2009 19:56
By: Andreas Buchen
  New inspector feature: Show SWT widget and whether they're disposed
By: Chris Grindstaff on Wed, 29 April 2009
1 3493 Tue, 05 May 2009 19:49
By: Andreas Buchen
  Leak suspect newer end
By: Pavel Hora on Wed, 22 April 2009
1 3199 Thu, 23 April 2009 08:57
By: Erwin Margewitsch
  Inconsistent display of HashMap-keys
By: Stefan Lotties on Tue, 14 April 2009
3 4903 Tue, 14 April 2009 16:02
By: Stefan Lotties
  IOException with (MAT+DTFJ) when reading a phd file
By: Rohit Kelapure on Fri, 06 March 2009
2 7976 Sat, 04 April 2009 20:10
By: Andrew Johnson
  CorruptDataException with (MAT+DTFJ) when reading a jextracted core
By: François Mercier on Wed, 25 March 2009
3 7861 Sat, 04 April 2009 20:09
By: Andrew Johnson
  How to get all objects which class implements specific interface?
By: Samuel Cai on Wed, 01 April 2009
1 4126 Thu, 02 April 2009 12:20
  can not get heap dump on win32 ?
By: nanao on Wed, 25 March 2009
5 5062 Thu, 26 March 2009 21:17
By: Taras Tielkes
  Save value to file: support specific encoding
By: Taras Tielkes on Wed, 04 March 2009
4 5221 Thu, 12 March 2009 23:59
By: Taras Tielkes
  Query on Heap Dump
By: udaysankarp on Mon, 23 February 2009
3 10173 Tue, 10 March 2009 09:57
By: Andreas Buchen
  Unreachable Objects
By: Bernd Eckenfels on Wed, 11 February 2009
3 8487 Thu, 26 February 2009 10:38
By: Andreas Buchen
  New version of the IBM DTFJ Adapter - with PHD reader
By: Andrew Johnson on Tue, 10 February 2009
1 4288 Thu, 12 February 2009 19:16
  Load 3,4 GB 64 bits dump on 32 bits
By: Claudio Miranda on Wed, 11 February 2009
1 5469 Wed, 11 February 2009 18:02
By: Andreas Buchen
  Leak Suspects org.apache.xalan.templates.ElemTemplate
By: Matteo TURRA on Tue, 10 February 2009
1 2855 Wed, 11 February 2009 10:09
By: Krum Tsvetkov
  What does the objectid mean?
By: Kristof Szabados on Thu, 05 February 2009
3 3380 Thu, 05 February 2009 19:36
By: Andreas Buchen
  Query plugin API
By: Chris Grindstaff on Wed, 04 February 2009
1 2508 Thu, 05 February 2009 12:55
By: Andreas Buchen
  MAT demonstration example
By: mike on Thu, 22 January 2009
1 2177 Fri, 23 January 2009 16:55
By: Andreas Buchen
  Creating a query plugin with graphs
By: Andrew Johnson on Thu, 15 January 2009
2 2482 Tue, 20 January 2009 15:17
By: Andreas Buchen
  MAT not showing entire HEAP ?
By: chamaster on Mon, 19 January 2009
1 2549 Tue, 20 January 2009 12:11
By: Andreas Buchen
  Finding (ascii) strings in byte[] data
By: Taras Tielkes on Sat, 13 December 2008
3 4021 Tue, 16 December 2008 20:32
By: Taras Tielkes
  Strange OOM error when running MAT + DTFJ on *some* jextract'ed zips
By: Paul E. Keyser on Tue, 16 December 2008
1 2851 Tue, 16 December 2008 11:13
By: Andrew Johnson
  freshly-installed MAT+DTFJ unable to read any extracted DMP-files
By: Paul E. Keyser on Mon, 15 December 2008
2 3139 Tue, 16 December 2008 11:09
By: Andrew Johnson
  MAT + DTFJ Crash on re-opening extracted zip
By: Paul E. Keyser on Fri, 12 December 2008
1 4336 Tue, 16 December 2008 05:27
By: Paul E. Keyser
  Review Results for Memory Analyzer 0.7 Release Review
By: Anne Jacko on Tue, 09 December 2008
0 3622 Tue, 09 December 2008 20:31
By: Anne Jacko
By: Will Taylor on Mon, 08 December 2008
1 2297 Tue, 09 December 2008 09:17
By: Andrew Johnson
  How to get executing stack and local variable information?
By: Sebastien Tardif on Fri, 05 December 2008
1 3601 Sat, 06 December 2008 07:28
By: Andreas Buchen
  Error opening jextract'ed dump
By: Mark Macdonald on Fri, 28 November 2008
2 5044 Mon, 01 December 2008 19:52
By: Mark Macdonald
  help interpret results - finalize() making memory leak worse?
By: Brian on Tue, 25 November 2008
1 7435 Wed, 26 November 2008 20:54
By: Andreas Buchen
  error in instructions: no way to get HPROF from Sun JVM 1.5
By: Paul E. Keyser on Thu, 20 November 2008
3 5035 Tue, 25 November 2008 22:02
By: Andreas Buchen
  jextract error => DTLJ failure?
By: Paul E. Keyser on Sat, 22 November 2008
2 3633 Tue, 25 November 2008 02:34
By: Paul E. Keyser
  Gray part in Overview pane
By: Geon Goo on Mon, 24 November 2008
1 2277 Mon, 24 November 2008 12:18
By: Andreas Buchen
  MAT+DTLJ crash on reading jextract'ed DMP
0 5644 Sat, 22 November 2008 23:43
By: Paul E. Keyser
  can MAT use PHD? (or only HPROF?)
By: Paul E. Keyser on Tue, 18 November 2008
5 24202 Thu, 20 November 2008 14:40
By: Paul E. Keyser
  New inspectors
By: Eclipse User on Wed, 19 November 2008
3 2379 Thu, 20 November 2008 13:17
  Minor CSVOutputter patch - 1 attachment
3 2742 Thu, 20 November 2008 13:16
  Save Value to File
By: Eclipse User on Fri, 14 November 2008
2 3198 Fri, 14 November 2008 08:09
By: Andreas Buchen
  Problems checking out src
By: Eclipse User on Thu, 13 November 2008
3 5102 Thu, 13 November 2008 22:19
  OQL: find objects with no inbounds from package
By: Bernd Eckenfels on Sun, 09 November 2008
3 6035 Mon, 10 November 2008 15:59
By: Andreas Buchen
  What does Thread Status mean
By: Nevar on Fri, 07 November 2008
1 4012 Fri, 07 November 2008 12:30
By: Andreas Buchen
  Performing query within dominator subgraph
By: Taras Tielkes on Tue, 28 October 2008
12 7271 Wed, 05 November 2008 12:08
By: Andreas Buchen
  Stuck on 63%
By: Eclipse User on Mon, 25 August 2008
6 5078 Fri, 31 October 2008 07:47
By: Andreas Buchen
  JVM Terminates immediately under Mac OS X w/ J2SE 6.0
By: Ryan Delucchi on Wed, 29 October 2008
8 8647 Fri, 31 October 2008 07:46
By: Andreas Buchen
  Help understanding Heap Analysis
By: Nirmal Kumar on Thu, 16 October 2008
13 10689 Thu, 30 October 2008 07:56
By: Taras Tielkes
  Saving content of char[]/byte[]/String/StringBuffer to file
By: Taras Tielkes on Wed, 03 September 2008
4 3832 Wed, 22 October 2008 16:23
By: Andreas Buchen
  Interned strings compete in the PermGen space.......
By: Nirmal Kumar on Tue, 21 October 2008
1 4137 Tue, 21 October 2008 14:11
By: Krum Tsvetkov
  Using pre-indexed dump
By: B R on Wed, 15 October 2008
3 2890 Fri, 17 October 2008 22:25
By: B R
  Configuring JRE for running MAT
By: Taras Tielkes on Tue, 14 October 2008
2 6554 Fri, 17 October 2008 08:02
By: Taras Tielkes
  Help understanding a heap dump
By: Steve Gray on Fri, 10 October 2008
2 2342 Tue, 14 October 2008 12:22
By: Krum Tsvetkov
  Error launching Memory Analyzer
By: Claudio Miranda on Fri, 03 October 2008
5 7685 Wed, 08 October 2008 11:19
By: Claudio Miranda
  Announcement: IBM DTFJ adapter for Memory Analyzer Tool
By: Andrew Johnson on Fri, 03 October 2008
0 4225 Fri, 03 October 2008 09:07
By: Andrew Johnson
  calculation of retained size for primitive arrays
By: Taras Tielkes on Tue, 16 September 2008
1 2508 Wed, 17 September 2008 19:39
By: Andreas Buchen
  Dumping a running process
By: Taras Tielkes on Wed, 10 September 2008
1 1885 Wed, 17 September 2008 19:27
By: Andreas Buchen
  Announcement: New Version Uploaded (5 September 08)
By: Andreas Buchen on Wed, 10 September 2008
0 3473 Wed, 10 September 2008 07:58
By: Andreas Buchen
  Performing initial analysis/conversion using command line tool
By: Taras Tielkes on Tue, 26 August 2008
5 4079 Mon, 08 September 2008 07:59
By: Andreas Buchen
  OQL Parser
By: Thomas Winkler on Fri, 05 September 2008
1 2490 Fri, 05 September 2008 09:01
By: Andreas Buchen
  Exploring all GC roots in dump
2 3283 Wed, 03 September 2008 19:17
By: Taras Tielkes
  understanding size for jagged byte[][]
By: Taras Tielkes on Tue, 02 September 2008
2 2648 Wed, 03 September 2008 17:00
By: Taras Tielkes
  Huge heap dump files - takes hours to parse
By: barak on Wed, 03 September 2008
2 3192 Wed, 03 September 2008 13:44
By: barak
  error report
0 3880 Tue, 02 September 2008 22:06
By: Taras Tielkes
  help to interpret results
By: Clovis Wichoski on Tue, 02 September 2008
1 4819 Tue, 02 September 2008 15:43
By: Krum Tsvetkov
  Allegedly invalid HPROF file
By: Eclipse User on Thu, 28 August 2008
5 7938 Mon, 01 September 2008 15:02
By: Krum Tsvetkov
  Thread details view: meaning of "Status" field
By: Taras Tielkes on Sun, 31 August 2008
1 2901 Mon, 01 September 2008 09:44
By: Andreas Buchen
  class histogram presented as package treetable
1 2384 Mon, 01 September 2008 09:35
By: Andreas Buchen
  Finding top n largest strings
By: Taras Tielkes on Sat, 30 August 2008
3 3436 Mon, 01 September 2008 09:26
By: Andreas Buchen
  IllegalArgumentException In OQL Statement
By: Erik Onnen on Wed, 27 August 2008
1 3296 Thu, 28 August 2008 07:31
By: Andreas Buchen
  Any known issues with analyzing huge heap dumps?
By: Eclipse User on Tue, 19 August 2008
3 3993 Wed, 27 August 2008 16:17
By: Andreas Buchen
  Namespace reporting is not ebavled
By: barak on Sun, 24 August 2008
6 5694 Wed, 27 August 2008 15:47
By: Andreas Buchen
  Error running reports on Linux
By: Adam on Wed, 27 August 2008
1 2852 Wed, 27 August 2008 07:54
By: Andreas Buchen
  Group by java.lang.ref.Finalizer.referent class name
By: Mark Mandel on Wed, 13 August 2008
1 10583 Wed, 13 August 2008 18:22
By: Andreas Buchen
  Unsupported segment type 254 at position 366,014,124
By: Eclipse User on Tue, 15 July 2008
3 4134 Mon, 21 July 2008 09:26
By: Andreas Buchen
  OQL Preferences
By: Eclipse User on Mon, 30 June 2008
2 3527 Tue, 01 July 2008 08:50
By: Andreas Buchen
  finding the size of a single object (& more)
By: Eclipse User on Sat, 28 June 2008
1 3672 Sun, 29 June 2008 11:51
By: Andreas Buchen
  missing tracing tab
By: Eclipse User on Tue, 03 June 2008
1 2691 Tue, 03 June 2008 14:58
  Version of BIRT Chart Engine?
By: Brian Brooks on Thu, 29 May 2008
1 2682 Fri, 30 May 2008 06:19
By: Andreas Buchen
  Webinar a/b Memory Analyzer
By: Andreas Buchen on Wed, 28 May 2008
0 3707 Wed, 28 May 2008 12:30
By: Andreas Buchen
  No application id has been found.
By: Eclipse User on Wed, 28 May 2008
2 4777 Wed, 28 May 2008 11:51
By: Andreas Buchen
  Static fields and heap usage
By: Mariot Chauvin on Wed, 30 April 2008
2 4050 Fri, 02 May 2008 07:10
By: Mariot Chauvin
  Blog: Immortal Objects - Or: How to Find Memory Leaks
By: Andreas Buchen on Mon, 21 April 2008
2 3589 Tue, 22 April 2008 11:27
By: Andreas Buchen
  EclipseCon Long Talk a/b Memory Analyzer
By: Andreas Buchen on Fri, 14 March 2008
0 4307 Fri, 14 March 2008 10:10
By: Andreas Buchen
  Synergy with tptp
By: Oliver E Cole on Thu, 07 February 2008
1 2496 Fri, 08 February 2008 15:32
By: Andreas Buchen
  Uses of the Memory Analyzer for Eclipse Development
By: Andreas Buchen on Mon, 04 February 2008
0 4549 Mon, 04 February 2008 17:14
By: Andreas Buchen
  Is it eclipse memory analyzer or everything?
By: Sundaramurthi on Thu, 03 January 2008
3 3387 Fri, 04 January 2008 17:35
By: Bert Hyman
  Welcome to eclipse.technology.memory-analyzer
By: Eclipse Webmaster on Thu, 03 January 2008
0 4163 Thu, 03 January 2008 14:36
Current Time: Mon Feb 19 19:51:05 GMT 2018
Powered by FUDForum. Page generated in 0.01923 seconds
