  JUnit test cases for ecore models
How to write own test cases for ecore models
By: Manoj Keshavaprakash on Fri, 06 October 2017
2 2189 Sun, 15 October 2017 11:26
  Availability Viewpoint in Sirius
How to get access to Sirius Viewpoint in the new Modelling Project?
By: Leonid Novikov on Sun, 20 August 2017
1 7798 Mon, 28 August 2017 15:38
By: Cedric Brun
  modeling
By: Banafsheh A on Mon, 09 January 2017
3 3413 Thu, 12 January 2017 12:25
By: Banafsheh A
  Sirius / Ecore Tools compatibility in Neon
By: Pierre Gaufillet on Thu, 13 October 2016
3 1443 Fri, 14 October 2016 15:34
By: Cedric Brun
  Load/Serialize JSON data into EMF Model
EMF-JSON for loading and saving JSON data in EMF Model
By: Shwetha Venkatesh on Mon, 03 October 2016
2 920 Tue, 04 October 2016 19:21
  EAttribute "ID" with Auto Increment
By: Alexander Schledewitz on Wed, 27 May 2015
2 4169 Sat, 17 September 2016 08:43
By: Xi Ng
  Illegal argument exception for "Name" property
By: UmaShankar Subramani on Tue, 06 September 2016
1 726 Tue, 06 September 2016 07:46
By: Cedric Brun
icon5.gif Creating an "instance editor" ontop of ECore-model
By: Linus Barth on Fri, 28 August 2015
2 5003 Thu, 01 September 2016 12:41
By: Ralph Gerbig
  [Texo] Install texo in eclipse neon fails - org.json not found
By: Mike Cooper on Wed, 06 July 2016
5 1700 Mon, 08 August 2016 09:02
By: Michael Wyraz
  Transforming Ecore diagrams with mediniQVT
By: Gonzalo Bressan Zuber on Sun, 17 May 2015
1 3434 Wed, 18 May 2016 08:53
By: Cedric Brun
  SPEM2 metamodel defined with Ecore
By: Ismael Halioui on Mon, 05 October 2015
1 4998 Wed, 18 May 2016 08:18
By: Cedric Brun
  Convert Ecore models to UML programmatically
By: André Ribeiro on Thu, 09 July 2015
1 3077 Wed, 18 May 2016 07:53
By: Cedric Brun
  Instantiation in emf
By: Lafleur du versaille on Thu, 15 October 2015
1 4959 Wed, 18 May 2016 07:52
By: Cedric Brun
  EClass information view
By: Pierre Gaufillet on Fri, 08 April 2016
3 6006 Tue, 17 May 2016 15:08
By: Cedric Brun
  Convert Ecore to UML
By: meta model on Thu, 13 August 2015
3 4276 Tue, 17 May 2016 15:08
By: Cedric Brun
  Renaming and regeneration?
By: Ernesto Posse on Tue, 03 February 2015
2 3767 Tue, 17 May 2016 15:08
By: Cedric Brun
  [Texo] Possibility to suppress generating of getter/setter
By: Sebastian Struckmann on Fri, 08 January 2016
1 4359 Wed, 20 January 2016 22:43
By: Martin Taal
  How to use compile-time annotations in ECore model without introducing runtime dependency
By: Andreas Sewe on Fri, 18 December 2015
2 2564 Mon, 21 December 2015 10:24
By: Andreas Sewe
icon4.gif Opening .ecorediagram diagrams in Luna??
By: Rolf Theunissen on Fri, 08 August 2014
6 12184 Thu, 12 November 2015 12:54
By: Cedric Brun
  Accessing external meta-models and code generation
1 3405 Wed, 19 August 2015 07:55
By: Thomas Lieser
  Error loading representations file in Mars (regression?)
By: Ernesto Posse on Tue, 02 June 2015
5 3512 Thu, 13 August 2015 16:16
By: Cedric Brun
  problem with the installation of ecore diagram editor
By: Lafleur du versaille on Fri, 24 July 2015
1 5221 Wed, 05 August 2015 13:49
By: Cedric Brun
  How can I get changes on Ecore Model
By: Serhat Celik on Tue, 21 July 2015
1 4629 Wed, 05 August 2015 13:46
By: Cedric Brun
  Ecore diagram editor does not load when I click the (aird) file
By: Hamid Qartal on Wed, 27 May 2015
1 2548 Wed, 15 July 2015 16:13
By: Cedric Brun
  How to serialize default values with domain specific editor
By: Thanh Liem Phan on Fri, 22 May 2015
1 3243 Wed, 15 July 2015 09:51
By: Cedric Brun
  Extending EcoreTools with new EAnnotation-based layers
By: Francois Cabrol on Mon, 08 June 2015
1 2463 Wed, 15 July 2015 09:47
By: Cedric Brun
  containment node problem
By: 55 66 on Thu, 04 June 2015
1 2528 Wed, 15 July 2015 09:36
By: Cedric Brun
icon5.gif IllegalArgumentException: Can only deactivate the active transaction
Exception thrown when altering a model using Ecore Tools 2.0
By: Sebastian Lehrig on Tue, 31 March 2015
1 2670 Sat, 11 April 2015 22:15
  Adding custom EMF metamodel validation rules
By: Francois Cabrol on Thu, 19 March 2015
0 2231 Thu, 19 March 2015 17:44
By: Francois Cabrol
  Instantiation of an ecore model
Cannot instantiate an own built ecore model
By: Beat Lussi on Sun, 08 February 2015
0 1445 Sun, 08 February 2015 21:01
By: Beat Lussi
  Transforming Ecore-models via XSLT
Is using XSLT to change references etc. a good idea?
By: Thomas Busch on Thu, 18 December 2014
0 2670 Thu, 18 December 2014 12:17
By: Thomas Busch
  opposite reference in property view for bidirectional references
By: Sivka Burka on Sat, 29 November 2014
0 3480 Sat, 29 November 2014 18:57
By: Sivka Burka
  Ecore tools 2.0.3 Issue with generic ETypeParameter
In diagram editor cannot specify T extends SomeClass for type parameter T
By: Marcello Vitaletti on Thu, 27 November 2014
0 9445 Thu, 27 November 2014 00:11
  Ecore Modeling Tools - missing create ecore Diagram
By: Eclipse User on Tue, 11 November 2014
1 6979 Fri, 14 November 2014 14:01
By: Cedric Brun
  .genmodel file lost its editor association in RSA
Can't reload .genmodel from .emx or see .ecore editor
By: Edmund Reinhardt on Mon, 03 November 2014
0 5549 Mon, 03 November 2014 02:11
  syncing to xcore model
By: Neil Mackenzie on Sat, 25 October 2014
0 3649 Sat, 25 October 2014 13:54
By: Neil Mackenzie
  Unexpected EOpposite validation error
By: Johan Van Noten on Tue, 21 October 2014
2 1098 Thu, 23 October 2014 15:47
By: Cedric Brun
  Sirius - viewpoint bug?
problem on launching viewpoint specification project
By: andrea scarpa on Sun, 05 October 2014
0 2721 Sun, 05 October 2014 22:27
By: andrea scarpa
  Eclipse Modelling Tools - Ecore
Unable to access Ecore Diagram Editor
By: monika bhave on Mon, 15 September 2014
2 1956 Thu, 18 September 2014 09:37
By: Cedric Brun
  Reference field UpperBound
It is impossible to put a star in this field
By: Philippe Revellat on Sun, 20 July 2014
1 2932 Fri, 12 September 2014 10:11
By: Cedric Brun
  Ecore Tools 2 The XYZ class has more than 3 super types
how to avoid this error: The XYZ class has more than 3 super types
By: joss Pf H on Thu, 21 August 2014
1 4890 Fri, 12 September 2014 10:06
By: Cedric Brun
  Ecore Tools 2.0 SuperType Relation name
two SuperType Relation
By: joss Pf H on Wed, 03 September 2014
1 4453 Fri, 12 September 2014 10:01
By: Cedric Brun
  Ecore Tools 2.0 Project Creation Wizard - Sirius 1.0.1 problems
Sirius 1.0.1 prevents new Ecore Tools 2 projects from creating class diagrams
By: Suleiman Shehu on Sat, 06 September 2014
2 3965 Fri, 12 September 2014 09:59
By: Cedric Brun
  model ecore
order of elements in model ecore
By: imen Mising name on Mon, 08 September 2014
1 2180 Fri, 12 September 2014 09:50
By: Cedric Brun
  ecore EMF and Model creation wizards
the example in Example EMF Model creation wizards is apprearing but missing some information
By: walma gharbi on Fri, 05 September 2014
0 2336 Fri, 05 September 2014 13:49
By: walma gharbi
  Ecore Tools 2.0 bidirectional reference issue
how to select only one reference to add annotations
By: joss Pf H on Mon, 01 September 2014
0 4195 Mon, 01 September 2014 04:38
By: joss Pf H
  Ecore Tools 2.0 how to select all classes into a package?
0 2085 Thu, 21 August 2014 15:50
By: joss Pf H
  How to generate impl classes and edit, and editor projects
By: Arunkumar Ramaswamy on Tue, 22 July 2014
1 2000 Fri, 25 July 2014 10:03
  EType : java.util.Collection
By: Yugi Muto on Wed, 16 July 2014
1 1571 Thu, 17 July 2014 06:50
By: Yugi Muto
  Ecore Tools 2.0 Outline "link with Editor" button
Ecore Tools 2.0 Outline link with Editor
By: joss Pf H on Wed, 25 June 2014
4 3662 Sat, 12 July 2014 00:39
By: joss Pf H
  Ecore Tools 2 problems
By: joss Pf H on Fri, 27 June 2014
2 2738 Sat, 12 July 2014 00:21
By: joss Pf H
  Trouble installing/using Ecore Tools SDK
By: Radoslav Asparuhov on Tue, 16 October 2012
5 9297 Mon, 07 July 2014 11:48
By: Cedric Brun
  Ecore Tools 2 Icon path problem
By: joss Pf H on Thu, 26 June 2014
2 1644 Fri, 27 June 2014 15:25
By: joss Pf H
  Error in xcore file in eclipse kepler
Couldn't resolve reference to XAnnotationDirective 'GenModel'
By: Md.Shariful Islam on Tue, 10 September 2013
1 6489 Thu, 26 June 2014 10:33
By: Marco Descher
  Creating Diagrams for a subset of objects in the Ecore Model
By: Ranjith Chungath on Mon, 01 October 2012
5 6419 Fri, 06 June 2014 12:23
By: Cedric Brun
  What means setGenerateCustomClasses in org.eclipse.emf.mwe2.ecore.EcoreGenerator
By: Markus Oley on Wed, 28 May 2014
0 56143 Wed, 28 May 2014 23:28
By: Markus Oley
  [SOLVED] Which package contains the presentation-relevant classes for the EMF Diagram editor?
By: Stephan Druskat on Mon, 05 May 2014
2 1796 Tue, 06 May 2014 12:21
By: Cedric Brun
icon5.gif Load and use ECore resources with ECore Editor 2.0
By: Aleksandar Toshovski on Wed, 23 April 2014
2 10091 Mon, 28 April 2014 16:19
  Ecore Tools 2.0 support no generics in the new UML class diagram editor
By: Aleksandar Toshovski on Mon, 10 February 2014
2 8697 Wed, 23 April 2014 08:43
  Latest builds are missing from the download site?
By: Sándor Juhász on Fri, 22 February 2013
2 3667 Thu, 17 April 2014 12:14
By: Cedric Brun
  Fragment and partially load EMF models in xmi format
By: Balaji Kadambi on Mon, 24 February 2014
1 1842 Wed, 12 March 2014 17:07
By: Cedric Brun
  Resource creation ignores an attribute while saving to output file!
By: Parsa Pourali on Tue, 25 February 2014
0 973 Tue, 25 February 2014 18:36
By: Parsa Pourali
  [teneo]recover bad connections
By: Rachna Bakhru on Tue, 18 February 2014
0 12863 Tue, 18 February 2014 19:47
By: Rachna Bakhru
  Tool for creating metamodel graphic
By: Phil H on Sat, 01 February 2014
0 29476 Sat, 01 February 2014 21:04
By: Phil H
icon5.gif Automatically generate EMF, Help!
By: javs javs on Mon, 16 December 2013
1 6577 Thu, 30 January 2014 15:56
By: Salome Maro
  Populating a drop down list with existing classes
Noob
By: Gary Worsham on Thu, 07 November 2013
1 2823 Thu, 05 December 2013 10:39
By: Cedric Brun
  Metamodels in Ecore
By: Nasser Mustafa on Fri, 01 November 2013
1 2355 Thu, 05 December 2013 10:38
By: Cedric Brun
  Autosave changed referenced objects possible?
By: Jens Rabe on Fri, 29 November 2013
2 2539 Thu, 05 December 2013 10:38
By: Cedric Brun
  Strange EOpposite references behaviour
By: Jens Rabe on Tue, 03 December 2013
1 1893 Thu, 05 December 2013 10:37
By: Cedric Brun
  How to create one model from several XSDs?
By: Gunnar Arndt on Wed, 21 November 2012
1 4108 Fri, 08 November 2013 11:01
By: Dominik foobar
  Correct way to override the accessors for an eAttribute
By: Corby James on Mon, 07 October 2013
0 1885 Mon, 07 October 2013 14:22
By: Corby James
  "Ecore Tools" called "Ecore Diagram Editor" since Eclipse Kepler / 4.3?
By: Till F. on Wed, 24 July 2013
2 5589 Wed, 14 August 2013 10:43
By: Mikhail Kalkov
icon5.gif Getting an exception while loading a model
By: eshal shah on Fri, 02 August 2013
0 1664 Fri, 02 August 2013 19:16
By: eshal shah
  Ecore Model Does Does Not Create
Following Tutorial and get error in Indigo and Juno
By: Matthew Cunliffe on Thu, 07 March 2013
1 2588 Tue, 09 July 2013 10:22
By: Elvio Perino
  Texo: list of annoying details
By: Olaf Burdziakowski on Thu, 17 May 2012
1 5382 Sun, 02 June 2013 08:20
By: Martin Taal
  [TEXO] getting started with texo.web.example
exception when starting tomcat
By: Ludwig Moser on Thu, 16 May 2013
2 9310 Thu, 23 May 2013 09:41
By: Martin Taal
  [TEXO] texo skips to generate EOperations from ecore
By: Ludwig Moser on Wed, 08 May 2013
2 3499 Wed, 15 May 2013 13:01
By: Martin Taal
  Diff 2 EObjects of the same ecore model
By: Andrew Whelan on Tue, 07 May 2013
0 2832 Tue, 07 May 2013 14:23
By: Andrew Whelan
  [TEXO] move from normal EMF to TEXO
By: Ludwig Moser on Thu, 11 April 2013
2 5310 Mon, 15 April 2013 05:05
By: Ludwig Moser
  Ecore parser ?
I'm looking for a way to easily parse an ecore file.
By: loic Gammaitoni on Tue, 26 March 2013
0 2311 Tue, 26 March 2013 15:24
By: loic Gammaitoni
  Test case generation from Ecore model
Automated Test case generation from Ecore model for model based testing
By: Fisseha Wond on Fri, 01 March 2013
1 4061 Fri, 08 March 2013 14:23
By: Marina Knieling
  Ecore Tools on Kepler M5a
By: Pierre Gaufillet on Mon, 25 February 2013
1 1989 Mon, 25 February 2013 20:41
  Ecorediag: how to add classes (or packages) from the ecore model
By: Davide M on Thu, 21 February 2013
0 3108 Thu, 21 February 2013 11:15
By: Davide M
  Is EMF Index a dead project?
By: Eric Rizzo on Wed, 06 February 2013
0 2460 Wed, 06 February 2013 19:28
By: Eric Rizzo
  Binding two EMF objcets
How to bind two EMF domain objects
By: Ramesh Nachimuthu on Wed, 06 February 2013
0 1803 Wed, 06 February 2013 03:25
  Documentation for EMF Query Required
By: Farsheed Farian on Tue, 05 February 2013
0 2346 Tue, 05 February 2013 13:37
By: Farsheed Farian
  Reading elements of a ecore file
By: Philipp El on Wed, 09 January 2013
0 12120 Wed, 09 January 2013 11:46
By: Philipp El
  How to get files from Preject Explorer and Pakage Explorer to new View on Eclipse?
By: Saif Mfarrij on Mon, 17 December 2012
0 3064 Mon, 17 December 2012 12:10
By: Saif Mfarrij
  ecore diagram: IllegalArgumentException on loadup
By: Simon Schimansky on Wed, 12 December 2012
0 2789 Wed, 12 December 2012 17:15
  Initialize ECore diagram file only goes down one level
How can I get the "Initialize ECore diagram file" to travel farther then one level?
By: Paul Roubekas on Sat, 24 November 2012
0 3456 Sat, 24 November 2012 22:25
By: Paul Roubekas
  Missing EMF Ecore diagram editor + Indigo JEE package 32 bit
By: Pradeep Badiger on Thu, 22 November 2012
0 5848 Thu, 22 November 2012 07:00
By: Pradeep Badiger
  Resolve Ecore Cross Reference
By: Florian B. on Thu, 18 October 2012
0 3093 Thu, 18 October 2012 16:04
By: Florian B.
  Ecore editor doesn't find a file
By: Alexey Romanov on Tue, 02 October 2012
0 4486 Tue, 02 October 2012 08:21
By: Alexey Romanov
  Persisting ecore model in DB takes too long time!!!
By: Harshagiri Kondavagilu on Fri, 14 September 2012
0 4522 Fri, 14 September 2012 11:41
  Validation errors in Ecore metamodel
By: Stefan W. on Thu, 13 October 2011
1 20615 Thu, 12 July 2012 09:47
By: Sandra B
  JAXB annotation in Ecore
By: Kosala Yapa on Mon, 09 July 2012
0 4305 Mon, 09 July 2012 09:05
By: Kosala Yapa
  problem when trying to open my ecore with oclin ecore editor
By: frank fotso on Mon, 02 July 2012
2 2455 Mon, 02 July 2012 12:44
By: frank fotso
  How to create a user defined attribute
By: pllab Missing name on Wed, 30 May 2012
1 3563 Wed, 20 June 2012 08:08
By: Cedric Brun
  [Resolved] EMF diagram editor for Juno ?
How-to open diagrams created with Indigo, using Juno ...
By: Bernard Sarter on Thu, 17 May 2012
1 3091 Fri, 25 May 2012 20:09
By: Bernard Sarter
  [Texo] Hard-coded date time format ...
Any way to change?
0 4615 Thu, 17 May 2012 09:21
  Association class
how can I create a new association class ??
By: Jomaa Narjes on Mon, 30 April 2012
0 4775 Mon, 30 April 2012 21:07
By: Jomaa Narjes
  Limiting access to generated collections
By: Hayden Marchant on Thu, 16 February 2012
0 4450 Thu, 16 February 2012 16:32
By: Hayden Marchant
  Is Ecore tools development dead ?
By: Benoit Cantin on Thu, 09 February 2012
3 3790 Tue, 14 February 2012 14:18
By: Cedric Brun
  [ecoretools] Problem creating opposite ERelation through the graphical editor
By: Benoit Cantin on Fri, 10 February 2012
1 4494 Fri, 10 February 2012 08:29
By: Benoit Cantin
  UI Acceleo Launcher Project fails
Acceleo ecore eclipse plugin
By: acquigio on Fri, 02 December 2011
2 4633 Thu, 02 February 2012 13:21
By: Ribeiro Campelo David
  Extension Point Modeling Framework
Using EMF to make extension point development a lot easier?
By: Duncan Krebs on Fri, 30 December 2011
0 5104 Fri, 30 December 2011 01:17
By: Duncan Krebs
  [ECore] How to reference fixed Ecore classes as well as model instances
By: Glenview Jeff on Sat, 12 March 2011
3 6052 Mon, 12 December 2011 09:00
By: Algar fr
icon5.gif Is it possible to reference eClasses from xmi instances?
Referencing ecore eClasses (meta-model level) from instances in xmi (model level)
By: Algar fr on Tue, 06 December 2011
1 3340 Mon, 12 December 2011 08:58
By: Algar fr
  Code gen problem
generate a very long do switch statement
By: liangzhao.zeng on Tue, 22 November 2011
0 4812 Tue, 22 November 2011 22:33
By: liangzhao.zeng
  Ecore Diagram Manipulation
By: Alex on Mon, 21 November 2011
0 4332 Mon, 21 November 2011 22:07
By: Alex
  How to set an class extended attribute
By: Patricia Espada on Mon, 21 November 2011
0 4316 Mon, 21 November 2011 17:20
By: Patricia Espada
  Proper API documentation in javadoc of generated classes
How can I annotate a model with documentation? How can I get rid of "there really should be more of a description here"?
By: Martin Domig on Thu, 20 October 2011
0 5281 Thu, 20 October 2011 08:40
By: Martin Domig
  How to set EDateTime in ecore editor?
By: Mike Cooper on Tue, 20 September 2011
0 4438 Tue, 20 September 2011 19:55
By: Mike Cooper
  [EMF Query]: get the query from the selection
By: El Arbi Aboussoror on Sun, 21 August 2011
0 5010 Sun, 21 August 2011 08:51
  removed to correct ng
By: js Missing name on Thu, 11 August 2011
0 4621 Thu, 11 August 2011 14:21
By: js Missing name
  Graphical visualization of Ecore
By: djozef87 on Thu, 11 August 2011
0 5095 Thu, 11 August 2011 14:03
By: djozef87
  generating model code without reflective api
By: thedug on Tue, 09 August 2011
0 4503 Tue, 09 August 2011 02:47
By: thedug
  "Manually" setting xsi-type
By: Georg G. on Mon, 08 August 2011
0 4639 Mon, 08 August 2011 21:10
By: Georg G.
  Modelling exceptions /w emf
Howto model exceptions
By: Peter Parker on Thu, 26 May 2011
0 5650 Thu, 26 May 2011 17:07
By: Peter Parker
  Ecore models for download
By: waqar on Wed, 25 May 2011
0 4919 Wed, 25 May 2011 15:20
By: waqar
  Ecore Diagrams and Loaded resources
How to get Ecore Diagrams persisting visual references to elements from other .ecore files?
By: Christy Haragan on Tue, 24 May 2011
0 4637 Tue, 24 May 2011 15:31
By: Christy Haragan
  [EMF4Net] What ist the status of the project? Anyone still interested?
By: Martin Kirst on Mon, 23 May 2011
0 4606 Mon, 23 May 2011 22:05
By: Martin Kirst
  Extract all attributes from ecore metamodel
By: Carlos on Tue, 03 May 2011
0 7814 Tue, 03 May 2011 13:56
By: Carlos
  Text element of a class
By: Ton Tu on Mon, 18 April 2011
1 2858 Tue, 19 April 2011 06:48
By: Ton Tu
  XMI saving is very slow...
By: Antoine on Mon, 11 April 2011
2 3609 Wed, 13 April 2011 08:06
By: Antoine
icon5.gif EMF Show model attributes as rows in a table/tree
By: Martin Domig on Fri, 08 April 2011
0 5525 Fri, 08 April 2011 06:38
By: Martin Domig
icon5.gif [EGF] Problems with egfbuild example
By: Pierre Gaufillet on Wed, 30 March 2011
1 3136 Thu, 07 April 2011 16:33
By: Benoit Langlois
  How to specify database generated ID value in Ecore Editor?
By: Mike Cooper on Wed, 06 April 2011
0 4984 Wed, 06 April 2011 22:47
By: Mike Cooper
  ecore diagram & ecore tools
no ecore diagram is seen under ecore tools
By: Cindy Wang on Thu, 31 March 2011
0 5077 Thu, 31 March 2011 17:03
By: Cindy Wang
icon9.gif EMF automatically change "pathmap:/" by "platform:/plugin"
By: Marc Gil on Thu, 31 March 2011
1 3594 Thu, 31 March 2011 09:08
By: Marc Gil
  Setting List<String> Attribute for XML-Element
By: Dennis sui on Wed, 23 March 2011
0 5354 Wed, 23 March 2011 10:53
By: Dennis sui
  [Teneo] Teneo 1.0.3 generates foreign key index names too long for Oracle
Teneo
By: No real name on Tue, 22 March 2011
0 5111 Tue, 22 March 2011 23:57
By: No real name
icon10.gif create a independent emf project rather eclipse plugins project
emf
By: liunx on Sat, 22 January 2011
0 5485 Sat, 22 January 2011 05:40
By: liunx
  URI Hierarchy Handler
By: Michel Parisien on Fri, 17 December 2010
0 4970 Fri, 17 December 2010 17:39
By: Michel Parisien
  Weaving a new model from existing ones
By: Steffen on Wed, 08 December 2010
0 4495 Wed, 08 December 2010 12:16
By: Steffen
  accessing ecore model content
By: waqar on Mon, 18 October 2010
1 2942 Sat, 27 November 2010 17:13
By: readingflyer
  [EMF/Ecore] Generated editor projects always break after metamodel modifications?
By: Glenview Jeff on Thu, 18 November 2010
0 4436 Thu, 18 November 2010 16:29
By: Glenview Jeff
  Howto make a bidirectional linking between two classes
By: Brandenburgerin on Sun, 31 October 2010
1 3689 Fri, 12 November 2010 15:02
By: waqar
  How to use EType "Sequence"
By: hutzu on Wed, 20 October 2010
1 3524 Sat, 06 November 2010 10:24
By: mercedes
  Checking the syntax of EMF query...
By: Carlos on Wed, 03 November 2010
0 4284 Wed, 03 November 2010 06:18
By: Carlos
  Ordering Siblings
Ordering siblings in the ecore Editor
By: Martin Harrigan on Fri, 29 October 2010
0 4061 Fri, 29 October 2010 13:16
By: Martin Harrigan
icon4.gif Problem creating a model
By: Marina on Sun, 24 October 2010
4 3684 Wed, 27 October 2010 09:37
By: Marina
icon5.gif How to override the label provider of a referenced model element
By: Tom Knipphals on Wed, 20 October 2010
0 4690 Wed, 20 October 2010 13:30
By: Tom Knipphals
  Top xml element in ecore
How to find Top xml element in ecore?
By: Volodymyr Gryshko on Tue, 05 October 2010
1 2710 Wed, 06 October 2010 06:41
  How to add child nodes using the reflective API of EMF?
By: Adrian Aichner on Mon, 04 October 2010
0 4436 Mon, 04 October 2010 16:51
By: Adrian Aichner
  ecorediag and ecore mismatch
By: Tianfu Ma on Sun, 03 October 2010
0 4861 Sun, 03 October 2010 16:59
By: Tianfu Ma
icon5.gif How to deploy a generated editor plug-in
By: Kai Maschke on Fri, 01 October 2010
1 2762 Fri, 01 October 2010 12:39
By: Kai Maschke
  [Teneo] No primary key in table for multi-valued string attribute
By: Lemao on Tue, 21 September 2010
2 3195 Fri, 24 September 2010 13:12
By: Lemao
  Add attribute/reference to diagram which is part of model
By: Edaurd Bauer on Mon, 20 September 2010
0 4852 Mon, 20 September 2010 16:22
By: Edaurd Bauer
  Create a snapshot of ResourceSet
By: Stephan Au. on Fri, 10 September 2010
0 3920 Fri, 10 September 2010 08:25
By: Stephan Au.
  attribute dependencies
Attribute Dependency in attributes belonging to different classes
By: Santhosh Injineri on Thu, 02 September 2010
0 3745 Thu, 02 September 2010 10:46
  Example of EMF-EclipseLink integration
By: Barbara Rosi-Schwartz on Mon, 23 August 2010
0 3794 Mon, 23 August 2010 08:56
  Interdependent attributes
By: Amit on Fri, 13 August 2010
0 3343 Fri, 13 August 2010 23:06
By: Amit
  EMF Serialization/Loading question
EMF
By: Loic JULIEN on Sat, 07 August 2010
0 3563 Sat, 07 August 2010 05:32
By: Loic JULIEN
  Do bounds (lower and upper) of EReference have any effect?
I set EReference lower and upper bounds, but generated Java code lets user to create unappropriate referenced objects count
By: Oleg Bolshakov on Fri, 06 August 2010
0 3583 Fri, 06 August 2010 15:10
By: Oleg Bolshakov
  attributes in ecore model
By: wiwi on Thu, 29 July 2010
5 4162 Fri, 06 August 2010 14:37
By: wiwi
  Displaying blank value in the properties window
By: Milind on Thu, 29 July 2010
0 3823 Thu, 29 July 2010 09:47
By: Milind
icon10.gif How to impl my own quick fix after EMF validation?
By: Kevin on Thu, 29 July 2010
0 2935 Thu, 29 July 2010 02:58
By: Kevin
  Integration with EMF Validation
By: Juan Cadavid on Sun, 28 March 2010
0 3922 Sun, 28 March 2010 11:08
By: Juan Cadavid
Current Time: Wed Jan 17 13:22:31 GMT 2018
Powered by FUDForum. Page generated in 0.01542 seconds
