Home » Modeling » ATL » ATL Transformation Error(Exception)
ATL Transformation Error [message #999283] Fri, 11 January 2013 13:15 Go to next message
Basma Moukhtar is currently offline Basma Moukhtar
Dears,
I am new to ATL.
I was making a simple transformation (flowchart node to java statement).
I use this rule:
rule Node2Statement
from
node : Flowchart!Node
to
stmt : Java!JavaStatement(
text <- node.title
I got this exception :
org.eclipse.m2m.atl.engine.emfvm.VMException: -1
at __matchNode2Statement#0(FlowChartMM2JavaMM.atl)
local variables: self=FlowChartMM2JavaMM : ASMModule
at __matcher__#1(FlowChartMM2JavaMM.atl)
at main#22(FlowChartMM2JavaMM.atl)
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:564)
... 13 more
I can't understand what's wrong. Could you please help me?
Re: ATL Transformation Error [message #1000176 is a reply to message #999283] Mon, 14 January 2013 02:37 Go to previous messageGo to next message
El Arbi Aboussoror is currently offline El Arbi Aboussoror
Member
can you attach a self contained ATL project ?
Re: ATL Transformation Error [message #1000472 is a reply to message #999283] Mon, 14 January 2013 16:04 Go to previous messageGo to next message
Dennis Wagelaar is currently offline Dennis Wagelaar
Member
Op 11-01-13 20:13, Basma Mising name schreef:
> Dears,
> I am new to ATL.
> I use this rule:
> rule Node2Statement
> from node : Flowchart!Node
> to stmt : Java!JavaStatement(
> text <- node.title
> ... 13 more
That's a stack underflow error in the VM, which means it's likely a compiler
bug. Can you provide the full transformation file and the version of ATL
you're using?
Dennis
Re: ATL Transformation Error [message #1000962 is a reply to message #1000472] Tue, 15 January 2013 14:36 Go to previous messageGo to next message
I use ATL 3.2.1
The ATL file is as follows :
module FlowChartMM2JavaMM;
create OUT : JavaMM from IN : FlowChartMM;
rule Node2Statement
	from
	to
			text<-node.title
The Flowchart Metamodel is as follows:
www.imageshack.us/photo/my-images/22/flowchartmm.jpg/
The Java Metamodel is as follows:
www.imageshack.us/photo/my-images/545/javamm.jpg/
I got an error in the rule declaration line saying that "Flowchart is not a source model".
Re: ATL Transformation Error [message #1000986 is a reply to message #1000962] Tue, 15 January 2013 15:27 Go to previous messageGo to next message
Member
Op 15/01/13 20:36, Basma Moukhtar schreef:
> I use ATL 3.2.1
> module FlowChartMM2JavaMM; create OUT : JavaMM from IN : FlowChartMM;
> rule Node2Statement
this should be FlowchartMM!Node, as you labeled your metamodel that way in the
"create" clause.
same here: JavaMM!JavaStatement
Dennis
> text<-node.title
> source model".
Re: ATL Transformation Error [message #1001002 is a reply to message #1000962] Tue, 15 January 2013 15:58 Go to previous messageGo to next message
Member
"Flowchart is not a source model" because you have named your source model "FlowChartMM".
Re: ATL Transformation Error [message #1001033 is a reply to message #1001002] Tue, 15 January 2013 17:16 Go to previous message
It worked Smile
Thanks a lot.
Previous Topic:Running the Class2Relational examples from the zoo
Next Topic:calling java in a query
Current Time: Sat May 25 14:21:30 EDT 2013
Powered by FUDForum. Page generated in 0.01849 seconds
