Home » Eclipse Projects » SWTBot » SWTBot test wizard without workbench(SWTBot test wizard without workbench)
icon5.gif  SWTBot test wizard without workbench [message #999155] Fri, 11 January 2013 08:18
christin nitsche is currently offline christin nitsche
I created an eclipse wizard which i want to test now with the SWTBot. I already used the SWTWorkbenchBot which finally works but i want to test the wizard now without the eclipse workbench. Thats why i created a shell in my testclass where i want to put on my wizardpage, but all i could see, was a empty shell without my wizardPage.
So i created a new shell class which included this code:
	public static void main(String args[]) {
		try {
			Display display = Display.getDefault();
			HorrorShell shell = new HorrorShell(display);
			shell.open();
			shell.layout();
			while (!shell.isDisposed()) {
				if (!display.readAndDispatch()) {
					display.sleep();
		catch (Exception e) {
			e.printStackTrace();
	 * Create the shell.
	 * @param display
	public HorrorShell(Display display) {
		super(display, SWT.SHELL_TRIM);
		setLayout(new FillLayout());
		createContents();
	 * Create contents of the shell.
	protected void createContents() {
		setText("SWT Application");
		setSize(450, 300);
		ManualSettingsWizardPage page = new ManualSettingsWizardPage();
		page.createControl(this);
With the shell class it works, my wizardpage was shown but if i try to run my testclass as SWTBotTest or as JUnitTest it wont show me anything but a empty shell.
Here's the code in my testclass:
private ManualSettingsWizardPage wizard;
	private SWTBotShell botShell;
	private Shell shell;
	private Display display;
        private SWTBot bot;
	@Before
	public void setUp() {
		botShell = new SWTBotShell(shell);
		bot = new SWTBot();
		wizard = new ManualSettingsWizardPage();
		shell = new Shell(display);
		shell.open();
		shell.layout();
	@Test
	public void bot() throws Exception {
		bot = botShell.bot();
		shell.setBounds(200, 200, 400, 400);
		shell.setLayout(new FillLayout());
		wizard.createControl(shell);
Previous Topic:sync after AbstractSWTBot#pressShortcut() ?
Next Topic:Do you want a recorder for SWTBot ?
Current Time: Thu May 23 18:42:43 EDT 2013
Powered by FUDForum. Page generated in 0.02308 seconds
