| 5009: AUT start failed [message #990467] |
Wed, 12 December 2012 10:49  |
emre ergun Messages: 3 Registered: December 2012 |
Junior Member |
I installed Guidancer,connected PostgreSQL and started AUT successufly. When I close the Guidancer and restart it, I can connect to my db, however I get the exception :
"An error occured.
Reason:
>> details:
Establishing connection to AUT failed.
Please check the AUT configuration"
I do not change any configuration.
For starting AUT,I have to delete everything about Guidancer and reinstall it, or open a new workspace.
| Re: 5009: AUT start failed [message #994075 is a reply to message #990812] |
Wed, 26 December 2012 05:15   |
Junior Member |
Hello again,
Sorry for the late comment.
I use embedded agent and Java written AUT. I am sure that just one AUT starts at that time. These are the steps:
1 - I install GuiDancer.
2 - Open it.
3 - Open a new work space.
4 - Cofigure it's PostGreSQL option. (My test cases are stored in a PostGreSQL database)
5 - Start AUT.
6 - Make new test cases.
7 - Close the AUT.
8 - Stop the agent.
9 - Close GuiDancer.
If I restart Guidancer with the previous work space, the agent is connected but I get the 5009: AUT start failed exception. However if I close the AUT, disconnect the agent do not close Guidancer and then reconnect the agent again AUT starts successfully. To solve this problem I open a new work space or uninstall everyting about Guidancer and do the steps above.
Thanks for your help.
[Updated on: Wed, 26 December 2012 05:15] Report message to a moderator
| Re: 5009: AUT start failed [message #1002138 is a reply to message #999136] |
Thu, 17 January 2013 21:21  |
posia han Messages: 39 Registered: December 2012 |
Member |
some suggestion for you ,I have meet the problem before, at the end I confirmed The AUT configuration and found that there is some problem at the configuration,such as the excutable File name configurated error or the file is not exit in the configurate path.I hope that my answer can help you a little.
posia
[Updated on: Thu, 17 January 2013 21:22] Report message to a moderator
FUDForum. Page generated in 0.01715 seconds
